Question about Equator EZ 1612 V Front Load Washer / Dryer
Any advice on how to reinstall the door on one of these? I took it off after breaking the handle...but the threaded backers that held the screws in fell down into the machine...
    Genius:
  • Equator Master
  • 1,474 Answers
Unplug 1st/ partly tip machine put in hand retreive screws backplate/ you may require to partly remove door seal to refit this ..Good luck
Posted on Nov 12, 2009
How do you fix a passenger door handle on a Ford Explorer 1999
inside or outside????????. either way remove the door panel. the rest is easy
Apr 24, 2015 | 1999 Ford Explorer
How do I remove the driver side front door panel to repair the power window?
The panel is held on with screws and clips. The screws are usually located in the armrest portion and possibly one around the door handle. Once the screws are removed you grab the door panel from the bottom and pull. The clips will release from the door. It is not uncommon for some of the clips to break or seperate from the door panel. Just reinstall the clips back into the panel and replace any that may break
Apr 06, 2015 | 1998 Oldsmobile Cutlass
Microwave door handle replacement
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see any screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
Jan 16, 2013 | Microwave Ovens
I have a 1992 Buick LeSabre and cannot open the drivers door from the inside. How do I remove the door panel?
All screws have to be removed and the window switch panel has to be disconnected. It may have hidden screws or simply snaps into place. Pull the inner door handle out and there should be a screw holding the escutcheon plate on the door, The arm rest is also held with at least two screws, remover these. Use a flat tool to pry along the edge of the door and door panel, pop the panel away slightly, the snapping point are the places where the panel is held with nylon panel snaps that screw in to the door panel. If you break these you can buy them at an auto parts store.
The door handle pulls on a rod that pulls on the door latch, this is held in place with a bell crank hook / lock. This is usually the part that fails.....
Feb 13, 2010 | 1992 Buick LeSabre
How remove the rear inside door panel on a 2001 oldmobile aurora
The inner door panel is held in by clips and screw.
Look at the door near the door handle there should be screws holding it in and along the outer edge of the door. Once loose, and the door handle removed or the arm rest removed. The door panel then prys out , because of the clips that hold it on. Then pops out by applying pressure to the panel upward to the top of the door. The clips always break because of the design and plastic.
Good luck
Mar 21, 2009 | 2001 Oldsmobile Aurora
How to replace the head gear
i'm going to assume your 7" is like my 9" and say that after you remove the backer pad and expose the spindle you should have access to the gearbox cover that's held in with 4 screws. if you remove those 4 screws and remove the cover you should have the bevel gear exposed.
of course the handle and guard will have to be removed to make it easier.
hold down the spindle lock when unscrewing the backer pad.
Nov 21, 2008 | Makita 7" Electronic Sander - Polisher...
Broken door handle
no matter what you do door panel has to come of if it is a two piece top and bottom better for you once it is off make sure window is up all the way disconnect handle rod most are held on with a lock clip from one of access holes in top of door then remove two mounting nuts on the handle bolts that come from the outside to the in the vhandle should come right out then have someone on the outside install handle threw door will you reinstall the two nuts on the threaded bolts on the inside reinstall rod to handle then door panel your done
Sep 11, 2008 | 2000 GMC Sierra
Microwave handle replacement
How to replace handle on GE Advantium SCA1001DSS.
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2008 | Microwave Ovens
Bosch Door Handle: Loose
I had the same problem with my Bosch dishwasher.I came to this web site to find out how to get the door off.I took the experts advice,placed 4 pillows on the floor in fromt,opened the door,took out the screws and the front panel dropped down.It was so easy,the plastic spacers stayed in place.I put a little J B weld on the handle screws and tighted the handle and put everything back together,12 minutes tops.Thanks for the help,thankful in Georgia
Jun 09, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Equator EZ 1612 V Front Load Washer / Dryer Logo
67 people viewed this question
Top Equator Washing Machines Experts
Heartland Ho
Level 1 Expert
Gerry Harvey
Gerry Harvey
Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
