Question about HP w1907 LCD Monitor
I have an HP vs17e flat sceen monitor that will not power up. Checked the power supply cord and it is fine, just acts like it is not getting power ????
I'm working on exactly this board right now, same problem. Two of the capacitors (c822 and c824, right at the top edge center of the board) are bulged and blown, causing my power-fail situation. They're available for about thirty cents a capacitor from any specialty electronic place. Piece of cake to solder in with the right tools and a bit of care. Hope it might be another clue to your problem. Good luck.
Posted on Dec 04, 2009
  • 3 Answers
COULD BE BAD CAPACITORS, MINE HAD NO POWER,WHEN I TRIED TO BOOT IT FROM THE POWER BUTTON. OPENED IT UP AND IT WAS THE CAPACITORS THEY WERE NOT FLAT THEY WERE SWELLED UP. REPLACED NEW ONES AND IT WORKED FINE .
Posted on Mar 17, 2010
  • 72 Answers
HI,
ITS PROBLEM WITH URS LCD SMPS (SWITCH MODE POWER SUPPLY)
IF U R FAMILIAR WITH ELECTRONICS CHECH AC INPUT WHICH IS GOING TO LCD SMPS,IF IT IS OK CHECK SMPS DC OUT,IT SHOULD BE 12 VOLTS DC WHICH IS SUPLLY TO LCD INVERTER,
WHEN VOLTAGE IS PERFECT THEN ONLY THE LCD LIGHTS UP....
TNKS
RABBANEES
Posted on Nov 12, 2009
Why is my HP vs17e monitor blue power light blinking?
the blinking of power led means that the power supply is not working fine, this can be caused by:
  1. a puffed capacitors in the secondery side of the power suplly
  2. a shorted transistor in the inverter section
  3. a damadged flyback transformer in the inverter section
to solve the problem, unplug the LCD from the power source, wait for 30 mn to discharge the main filter capacitor (150 uf, 400 V), look at the capacitors, if they looks good, check the transitors, if you find a shorted one (0 ohm read) change it. don't forget to test the continuity of the flyback transformer (primery and secondery). i hope that this will help you to solve the problem.
Dec 12, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Have 10 Broken monitors with simalar problems. 1. Dell e153FPB- Video for 2 seconds than screen goes blank. 2. Dell e153FPB- After 20 mins, Display stops working. 3.Dell e1724FPB-Video for 2 Seconds than...
Pleasec look through my albums so you will know what to look for.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Dell bd: http://www.lcdrepair.us
Apr 24, 2010 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
HP vs15 monitor Flickers then blacks out.
Hello
This monitor has 5 capacitors in the power supply that age prematurely. I can repair this for $50.00 +parts + shipping. Or you can take it to a local repairperson.
Jul 28, 2009 | HP Vs17 17" LCD Flat Panel Monitor
HP vs17e My screen went black for a few moments and when it
Switch off and on your PC and hold down the F5 key and this should bring up your PC in Safe Mode. If this fails, then find a PC repair shop to replace the power supply.
Mar 22, 2009 | Computers & Internet
Monitor in sleep mode
my computer is on but screen is black and has power. How can I fix it?
Aug 27, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Flashing monitor
Sounds like the power supply can't keep up with the demand. It starts to work and then shuts off and then right back on repetedly? Probably bad electrolytic capacitors in the power supply, a pretty easy fix if you can identify which ones are bad and have a soldering iron with the right type of solder and some soldering skills. Good Luck
Aug 26, 2008 | HP Pavilion F1703 17" LCD Monitor
LCD monitor dirty
please give me a power supply smd ic nomber please MODEL NO. HP VS17E
Jun 26, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Hp monitor power cord
I purchased a HP Pavillion Slimline computer that was accompanied by and HP flat screen monitor: HPw1858. My problem is that the power cord is missing. Can you help me locate somewhere I can purchase this cord?
Oct 26, 2007 | HP Pavilion F1523 15" LCD Monitor
Supplying power to the monitor to get it to work
I think what you need is a "D" shell connector.. see if the one that fits your PC Power Supply will fit into the Monitor.. if so then purchase another the same. It's called a "D Shell" Power Cord.
Aug 20, 2007 | HP Pavilion F50 17" Flat Panel LCD Monitor
HP w1907 LCD Monitor Logo
753 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
