Question about McCulloch Garden
I have a Mini Mac Model 13-24475, Ser 600093C and I need to repair or replace the starter pawls or assembly. Can you advise me as to part numbers and sources?
    President:
  • 2,220 Answers
Atta boy! You got your numbers reversed but the right ones none the less (serial number 13-24475, Model 600093C).
A downloadable IPL (IPL number at any McCulloch parts source is 13-600093C) and can be found here:
http://www.mymowerparts.com/pdf/McCulloch_Parts_Service_Repair_Manuals/Gas_Powered_Chain_Saws/McCulloch_Gas_Chain_Saws_Parts_Manuals_13_600093C_MINI_MAC_25_12_73_to_04_77_IPL_92290_02.pdf
Not available at K&T Parts House above
On the "Powerhead Assembly" detail
Item 28; pn 69103
Not available here: http://www.ordertree.com/modelinfo/MCC/13-600093C-MINI-MAC-25-12%2F73-to-04%2F77-IPL-92290-02/139.13-600093C-MINI-MAC-25-12%2F73-to-04%2F77-IPL-92290-02.1.59.1.html Ordertree.com
Not available through the "EMPARTweb" they recommend you contact:
M & D Mower
http://www.m-and-d.com/parts.html
I’ll add a couple too:
Chain Saw Collectors Corner (parts sources)
http://www.acresinternet.com/cscc.nsf/673d78ec01557aea88256b00005457e6/53fd90eee11e3fe8882572a300167f51?OpenDocument
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
I did a search for “Mini Mac 25” and got 29 hits. She appears to be a popular Lady. Good Luck
Lou
Posted on Nov 12, 2009
  • dontbother10
    dontbother10 Nov 12, 2009
    I've found Mac parts at M & D Mower i can find no where else. Give them a try, and again GL.
    One other trick to try, find the highest letter suffix.
    Lou
    There was a change after model 600093C. Maybe a flywheel and starter cover for a D or above will correct this. EMPART use follows.
    Click “Illustrated Parts Diagrams ON LINE”
    Click “Click Here for Parts Lookup”
    Changes to “Select OEM” Window reads “Briggs & Stratton ▼” Click the arrow and select “McCulloch Power”
    Click “Gasoline-Powered Chain Saws”
    Click “13-600093Letter"
    Read some of the notes on 13-600093U, item 24 & 25. I think you can see what I mean. HTH
    Lou
  • 486 Answers
The recoil starter on my stihl br420 backpack blower doesn't engage.
Replace the entire starter assembly on both sides...
May 02, 2017 | Cars & Trucks
Repairing a Briggs and Stratton Quantum 35 mower engine. How do you replace the metal starter pawls in an older Briggs & Stratton mower engine
take cap off drive the pin out the bottom from the top replace starter pawls and springs put back to gether drive the pin back in checking making sure not to thight if it is drive pin back some until it spins freely
Aug 22, 2014 | Garden
Pawls don't catch on rancher 455
The starter pawls are held on with small springs. If the springs are broken or installed incorrectly, this can happen. I would suggest replacing the springs and maybe the pawls. Check the recoil assembly to make sure the issue is not with the recoil assembly.
Feb 08, 2014 | Husqvarna , No.455 Rancher, 20" Gas -...
Pull cord for starter is not catching?
There are starter pawls that catch the flywheel when the rope is pulled. They are plastic. You will need to disassemble the unit and remove the starter assembly to inspect the pawls.
Nov 11, 2012 | Ryobi Garden
The pull start broke. A small plastic hook shaped piece broke of What is it called and how do I repair it?f
Parts are easy to find for honda engines at the small engine shop and on the net. All that you need do is to locate the model and spec number of the engine itself and go to the link below for your parts. Some honda parts are available in assemblies only, like the complete starter. Be sure to check ebay for aftermarket parts. You may save some money. Look for a "starter pawl assembly kit" .
http://www.ereplacementparts.com/
Jul 12, 2011 | Honda Pressure Washer PSI 3000
Trans will not shift into fourth or fifth gear. 02 883 sportster
This sounds like you have a shifter pawl problem. The shifter pawl is in the primary behind the clutch. You'll have to pull the primary cover off and then take the primary chain, the engine sprocket, and clutch assembly off to get to the shifter pawl. If you plan on doing this job yourself, I would advise the purchase of a service manual. The shifter pawl must be aligned with a drill bit inserted in hole in the part. A picture is worth a thousand words in this case.
Good Luck
Steve
Jun 02, 2011 | Harley Davidson XL Sportster 883...
I have a TroyBilt series 560 self propelled mower with a Honda engine. The other day I was half finished with the lawn, stopped for a minute, and went to start the mower put my starter string was still...
hi there
csimonis
it is quite likly that you could need a new pulley and spring
but remove the cover and the starter assy 1st and check that the pawls have not stayed out or jammed , then try winding the spring and pulley up in the direction that the cord is moving when you pull the starter cord - check that end of the spring is still engaged onto the pulley , but if no tension is noted broken spring indicated
sometimes a replacement starter assy is quicker , cheaper
your local mower shop may have a spring & or pawls or starter assy for your model
but just in case get the model codes & numbers off the white tag from your mower
and check out this site for parts
go to troybilt
then select troybilt mower parts
then find your model from the list
then find starter assembly
parts can be ordered on line
cheers paul46
hope it helps
May 28, 2011 | Troy Bilt 5.5hp Self Propelled Mower
I have a 20000 electra glide clasic with a stock trannie the spline on the shaft were the linege conects is stripped what part is that ,were can i fine it and what kind of job is it to replace it
I think you're talking about the shifter pawl shaft where the shifter linkage connects. It's called a shifter pawl shaft. You can buy a replacement either OEM or aftermarket. Jim's is probably the best one on the market these days.
To change the shaft is a MAJOR job. You must pull the entire primary drive, including the primary chain, clutch assembly, and the inner primary. The starter must come off. The top of the transmission and shifting mechanism. The exhaust system must come off and the clutch release mechanism off the right side of the transmission. Then, the "trap door" with both the mainshaft and the countershaft of the transmission must come out. Then, you can get the shifter pawl shaft out. Not a job for a beginner unless you are a master mechanic on something else. Even then, I'd advise the purchase of a service manual. There are some special tools involved but they're are various torque wrenches.
Good Luck
Steve
Oct 15, 2010 | Harley Davidson FLHTCUI Electra Glide...
Fuel line from fuel tank to throttle switch ? broke need to order eager ****** mini pro 2.1 ci 16 inch cant find part #er thanks for your time
On the bottom of your saw is a tag with the serial number (i.e. 13-24475) and model (i.e. 600093C).
An IPL number for any McCulloch parts source can be created using the hyphenated serial number and complete model number (i.e. 13-600093C) = “YourCreatedIPL#”.
Use the IPL number you created here:
M&D Mowers
Click ““YourCreatedIPL#”. HTH
Lou
Typical fuel system:
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly. HTH
Nov 13, 2009 | McCulloch Garden
Bosch Hedge Trimmer AHS 4-16 Starts now and
sounds like you will need to replace starter pulley in the starter cover assy and check that the starter pawls are free to move and the pawl springs are no broken or the pawls are frozen
but your problem is most likley starter pulley
remove the starter cover and check the starter pulley
worn or damage teeth on pulley may be quite evident
cheers pauly46
Sep 19, 2009 | Garden
Garden Logo
413 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
