Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
I have kenmore elite gas range 790 series getting error code f93 the oven door is locked
    President:
  • 1,653 Answers
The F93 shows that the Maximum oven door lock time has been exceeded.
Turn off the range and turn off the AC power and wait for up to 10 mins. The door should reopen. Turn on the AC power ans see if the error persists. If it does then check the following.
1. Check the wiring between EOC & Lock Motor Micro Switch.
2. Replace the Motor Door Latch assembly if necessary.
3. Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. Lock Motor continuosly runs - if Micro Switch is open, replace Lock Motor Assembly.
6. Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
Posted on Nov 12, 2009
What does the F93 code mean and how do we fixt it
i know that it can be very difficult to have issues with your oven. the f93 on this model of kenmore range indicates that you have a problem with the oven door lock assembly (see image below). this can be caused by a failed oven door lock assembly, a wiring failure or a bad electronic oven control board.
i recommend that you unplug the range and check the wiring between the components first. you can remove the upper back panel of the range to access the electronic oven control board in the console. you may need to remove the lower panel to access the door lock assembly on the back of the range. the image below shows the wiring diagram and other information that should help you check the wiring connections. check for a mechanical binding of the door lock assembly as well. if the wiring connections are okay, you will likely need to replace the oven door lock assembly. if you need further assistance, please reply to this thread. thank you for using manage my life.
May 23, 2015 | Kenmore Elite 30" Slide-In Gas Range White
I continue to get code F11 on my Kenmore Elite Gas Range Oven and therefore, I am unable to unlock / open my oven door. I have pressed and held down the STOP button as well as the oven light button.
Your model number should be much longer than 790 30 Open drawers and doors to look for the whole model number around the frame.
With the whole model number you can get more information at Sears Parts Direct. There are parts diagrams and user manuals and you can order parts.
http://www.searspartsdirect.com/
This site gives instructions for repairing F11 and recommends checking the temperature probe and tells how to do it.
How to fix Frigidaire oven error code F10 F11 F30 F31 etc AskGene com
Sep 10, 2014 | Kenmore ELITE 790 30 FREESTANDING DUAL...
My Kenmore Elite gas range is beeping and flashing F90, the door is locked. What can I do to clear this?
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&^#$%
Aug 28, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore elite range, model 970-698593, Error Code E015
Just asking if your model number is correct. I do not find 970 models but do find 790 models. If it is a 790 model there can be aproblem with the door lock on the oven door. You may want to check to see if all the shipping materials have been removed from the door lock / latching area. I would recommend that you review the installation instructions in the owners manual, paying particular attention to the removal of shipping materials.
Adittionally if the problem presists it says to replace the Electronic Range Control (ERC) This is not a cheap part! Good thing it will be at their expense including the repair service call..
Hopefully you have already called for warranty service? We both know a brand new oven should not be producing any error codes. If you have not called for warranty service you do so now. Make sure to tell them that you already have talked to customer support and that unplugging the unit for ANY period of time made no difference in the error code.
Thanks for choosing FixYa.
Kelly
Aug 01, 2010 | Kenmore Kitchen Ranges
Oven locked
F93 - Maximum oven door lock time exceeded
Door lock is jamed . or faulty let me know
Dec 25, 2008 | Kitchen Ranges
F93 error
F93 error code means Maximum oven door lock time exceeded. Check oven door lock/door lock switchs.hope this helps
Dec 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
What does the errror code F90 mean?
unplug the range.
wait 1 minute.
wait 2 minutes.
Nov 18, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Self Cleaning
unplug the range.
wait 1 minute.
wait 2 minutes.
Mar 03, 2008 | Kenmore 94220 / 94221 / 94222 / 94224 /...
Kenmore Gas Range/Freestanding/ Electronic Ignition
I have an electronic ignition Kenmore Gas Range. The Model Number is 790.78573407.
Am getting the error code F93 in the oven control panel. The manual says the likely cause is "Maximum oven door lock time exceeded". When I plug the oven the "door lock light" flashes and then the "F93" error code flashes. Am not able to use the bake or broil.
Aug 31, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
553 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
