Question about D-Link DIR-625 (790069292637) Wireless Router
My laptop cannot see the router at 5gh. At 2.5 gh everything is fine
    Guru:
  • 105 Answers
Its because your macbook doesnt support 5ghz
Posted on Dec 13, 2009
How do I change from 2.4 to 5gh
Page 29 of the owner's manual (ftp://ftp.dlink.com/Gateway/dir628/Manual/dir628_manual_120.zip) illustrates how to enter the web-based administration page.
In the Wireless section, change the 802.11 mode. Be sure to save any changes made.
Jan 09, 2011 | D-Link DIR-628 Wireless Router
My internet keeps dro, i have installed filters ,
There is one case where everything is fine but still connection drops too often.---
This happens when the network type of your laptop is "public" as ublic networks are less secure, routers usually drop connections after sme time. Change the network type to "private". This should solve your problem. There is one more setting in your router where is says something like "automatically login when disconnected". Selecting this option allows automatically login to ISP when connection is dropped from ISP temporarily.
If network connectivity itself is the problem then you can debug followingly.
Step-1:
If ISP company says everything is fine from their side, then you need to check your router. To confirm this first connect the wall outlet of ISP to your laptop and check network connectivity. If there is problem, then ISP has to fix it.
Step-2:
If connection works fine then ISP is fine and you need to check your router settings. Now check network connectivity by connecting the laptop to the router through a ethernet wire. If the network does not work then your router hardware could be wrong and may need servicing or replacement. If this works fine then go to step-3.
Step-3:
Try resetting your router by using a paperclip. Usually the reset button can be found at the backside of your router. This will reset all the settings and there by making as good as a fresh one. Try to access internet from a place close to router where router signal is strong.
Change authentication and other network settings of your router to connect to ISP. Now network should work fine. Ensure that you set router password to avoid unauthorized access to your router by others.
Nov 08, 2009 | D-Link Computers & Internet
Router stopped braodcasting the wireless signal WRT160N
maybe your router got fried somehow. it's a pretty common thing if you didn't disconnect the power scorce first.
Aug 12, 2009 | Linksys WRT160N Wireless Router
Can you please tell me what is more reliable and better?
I'm afraid you need to clarify:
If you refer to (old) Specification 802.11 — it applies to wireless LANs and provides 1 or 2 Mbps transmission in the 2.4 GHz band using either frequency hopping spread spectrum (FHSS) or direct sequence spread spectrum (DSSS). you can compare with 802.11b (also referred to as 802.11 High Rate or Wi-Fi) — an extension to 802.11 that applies to wireless LANS and provides 11 Mbps transmission (with a fallback to 5.5, 2 and 1-Mbps) in the 2.4 GHz band. 802.11b uses only DSSS. 802.11b was a 1999 ratification to the original 802.11 standard, allowing wireless functionality comparable to Ethernet.
But as suggested by ricerz from Wikipedia:
IEEE 802.11 is a set of standards implementing by apple wireless local area network (WLAN) computer communication in the 2.4, 3.6 and 5 GHz spectrum bands. They are maintained by the IEEE LAN/MAN Standards Committee (IEEE 802).
You cannot compare 802.11 with 802-11b: 802-11b is an implementation of part of the 802.11 standard.
You can compare: 11a (using 5Gh band) with 11b (using 2.4 Gh band)
You can compare 11 b with 11g or 11n standard. and select according to environment.
As per my personal experience Industrial or hostile installation was frequently done using 802-11A (less interferences, 54 Mb bandwith) new N standard with a peak of 300 Mb is now changing the scenario.
New accessories: Boosters, external antenna, WDS protocol to bridge WLan router, and new long range Wi-Fi are continuously changing performance, results and configuration
Jan 13, 2009 | Symbol Spectrum24 AP 4121 802.11b
Network has suddenly dissapeered
This is just a problem with the wireless settings of the router, you can try first to reset the router by pressing the reset button for 20 seconds while power is ON and then after that you should be able to find the default wireless name of the router which is linksys, after you reset the router just need to reconfigure it back...
Jan 04, 2009 | Linksys Wireless-G WRT54G Router
GH World Tour problem
clean the laser eye really good
Nov 10, 2008 | Sony PlayStation 2 (PS2) Console
Gh world tour
you need to take the system apart or get a laser eye cleaner.
i took mine apart ( it was easier) and clean the laser eye should work fine after that!
Nov 09, 2008 | Sony PlayStation 2 (PS2) Console
It is possible that my router is blocking some sites
It is quite possible. You may have to access the user interface of your 2wire 1800 gh and then enable secured site access. You may have to open port 443 or lower your MTU to about 1400 or 1300. Please PM if you need further information
Jul 26, 2008 | 2wire 1800HG Router (RG1800HG00)
Buffalo router - have installed everything onto the desktop and net is working fine, but cant work out how to get the laptop to connect wirelessly!
Help us help you...
1. What brand and model of laptop?
2. Did you put an WEP key on the buffalo wireless router?
3. Are you sure the WiFi is turned on, on your laptop?
Jul 01, 2008 | Computers & Internet
D-Link DIR-625 (790069292637) Wireless Router Logo
194 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
