Mitsubishi WS-73711 73 in. Rear Projection Television
Problem for Mitsubishi WS-73711 73 in. Rear Projection Television
Won't power up - Leakage Test - Mitsubishi WS-73711
By KariSue on Jan 07, 2008
I've performed a leakage test by shorting the two prongs of the wall plug then measuring between the plug and metal parts on the TV. All but two of the metal parts (heat sinks, screws, plates...) read >1M ohm. The heat sink on two switching mode rectifiers measure about 20 M ohms. After I plug it in, most of the metal parts measure around 1-10 mV from ground (I don't recall if it was hot or cold ground). The two rectifier heat sinks measure around 26 mV. Would this indicate there is a problem with the rectifiers and should be replaced?
Currently, my Mitsubishi doesn't want to power up. I changed the DM cap's which got rid of the 'blinking green light' problem. However, it still doesn't power up. The error code (12) indicates the TV is operating normally. I removed the front panel power switch board and the on switch measures open/close/open when I depress it. I also checked all the fuses indicated on the inside of the chassis (about 10 of them). I measured the standby voltages from the test points and cold ground (6, 12, 28 and 32). If I remember correctly, I think they were all zero except the 6 volt was 7 volts - I will have to verify this. Tonight I will check the output of the bridge and switching rectifiers. However, I'm not real clear on what voltage they should be. I'm just learning about all this stuff - kind of fun - especially if I get it working!
Comments:
Jan 08, 2008
- TV WORKS NOW! I disconnected the front panel cable connector that goes to the power switch. The TV powered up fine using the remote. I need to recheck the power switch. It would appear it is stuck or something. Others have posted this problem keeps the TV from powering up by the front panel button or remote.
I picked this TV up for free on Craigs List a few days ago. Repair costs will be about $40 and I have a 73" TV that went for $7000 a few years ago. I couldn't have done it without all the great information from these tech support sites. You guys are great! Most important, this monster of a TV didn't end up in the landfill. How rewarding.
Jan 08, 2008
Same Problem
Mar 08, 2009
-   Tv won't power up with the remote or the front panel buttons. Pulled power for 12 hrs thinking TV would reset but nothing. What's next. -   Guest
Solution #1
posted on Jan 08, 2008
Somewhat Helpful)
troylove11
Rank: Wiz  Televisions & Videos  Expert
Rating: 84%, 1306 votes
Well it sounds like you enjoy checking things, did you check D9A31 part# 264P045050 and R9A33 a 220 ohm 1/4 watt resistor on the PCB? Try this!
Troy
Was this helpful?
Yes
No
Popular Solutions for Mitsubishi WS-73711 73 in.
Questions and Unsolved Problems for Mitsubishi WS-73711 73 in.
Do you recommend Mitsubishi WS-73711 73 in. Rear Projection Television?
Answer
Answer
where do i get a break down of my 50P8341A philips
Answer
i have a 50 in Pioneer and it shuts down by itself every 15 min and we have to switch outlets to get... (More)
Answer
Recently switched from a trouble free HD-digital satellite to Verizon's HD FIOS bundle. My WS 73711... (More)
Answer
Have mitsubishi model WS 72711. Tried to turn would not go on. Turned it on at the set, then the... (More)
Answer
WS-73711, no HDTV chanels. there chanel # shows up but no pic or sound. SD pic show up but no HD...
Describe your Projection Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(704) 315-5981
Chat Now
Insert Link
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Step 2: Select a product and click on add
I can't find my product
select
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
