Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Whirlpool Side by Side (33 inch across) Lights work, but neither side is cooling. No compressor running.
  • Whirlpool Master
  • 1,606 Answers
I would suggest replacing the overload/relay , which is pluged onto the side of the compressor . You will need your complete model number to get the correct replacement . This part is easily replaceable , with only 2 or 3 wires pluged onto it .
Posted on Nov 13, 2009
  • 2,237 Answers
It's either in defrost mode and the timer is stuck, or the relay or fuse is shot on the main board. might also be the thermostat. find the timer (usually under the fridge near the front). there will be a dial on it- turn it to see if the compressor comes on. if it does not, check the main board (also underneath, but towards the back).
Posted on Nov 12, 2009
The strip between the two doors of my whirlpool refrigerator model ed5ntgxlt00 hot to touch the fridge side runs at 60 degrees the freezer side runs at about 33 degrees plus the compressor is hot to touch
That is a very bad sign, but before you unplug it pull the machine out from the wall and check to see if it feels hot back there as well. Then remove the lower cover and find the condersor fan motor. Its the only fan back there. I'd willing to bet that the fan is not running. The purpose of the the fan is draw air across the compressor and blow it through the condensor therefore lowering the temperature on both parts. When its not working/ running, the heat from the compressor and the condensor is pass onward to the machine and the machine then acts as a heat sink.
May 21, 2012 | Whirlpool Refrigerators
The refrigerator is approx. 4 years old (side by side model). It was recently moved 100 miles. It was working fine in its old location, moved it 100 miles and now it does not cool or freeze. The lights...
if you laid it on it's side you could have damaged the sealed system.the machine has to be standing upright just like when it's in your kitchen or the compressor can get damaged,if you stood it back up and didn't run it for a few days the oil might go back down into the compressor but if it was moved on it's side and started most likely you damaged the compressor,or a wire or something got knocked off while moving it if it was moved correctly.is the compressor running?
Apr 13, 2011 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Frig not cold
It is possible that the gas has run off but we need to confirm. Sicne your fridge is working after being shut the compressor must cool without us thinking of any parts that can create the cooling fault. Since you mentioned the motor noise was more, it is possible that the compressor is not working well. There is not much we can think of unless the compressor is checked and the pressure of the gas within the system. I hope you will do accordingly. Good day
Jul 27, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My Whirlpool side by side fridge and freezer not working
Most likely, if you can hear the compressor running, the fan inside the freezer is not working. When the compressor is running, open the freezer and listen for the fan running. If you don't hear it, locate it and, with a voltmeter, test for voltage across the terminals. If you have voltage present, replace the fan. You can buy replacement fans at a local appliance parts store, internet parts suppliers, even ebay.
Jan 29, 2010 | GE Refrigerators
The Unit does not cool. The fan, lights, etc run
check if the compressor working if it working and you get frost in your freezer back panel then your problem is in your freezer area but if your compressor not working then and the fan next to it working then the starter unit for the compressor is bad....let me know if you need more help
911service today . com
Jan 01, 2010 | Whirlpool ES5FHAXS Side by Side...
Whirlpool refrigerator model ED5LHAXMQ10 AFTER A STORM WITH LIGHTINGS AND LIGHTS WENT OFF ITS NOT COOLING AND THE COMPRESSOR STARTS AND TURNS OFF IN LESS THAN 10 SECONDS.NOT COOLING IN FREEZZER OR...
You need to replace the overload/relay , on the side of the compressor . Pt # 2262185 . This part starts the compressor and keeps it running .
Aug 26, 2009 | Refrigerators
Works fine, but every couple of days I will notice that it will not be cooling, as the fan or compressor will not be working. I will turn the temp controler off, then back on and the compressor and fa
Check the condenser coil to make sure it is free of any dust, which will cause the compressor to overheat. The fan underneath may still be running, but until the compressor cools down it will not start.
If the unit always immediately begins running when you turn the control off and back on, then it may be you have a bad control. Have a servixe tech look at it, as you cannot repair the control...it's a throw away device.
May 29, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool ultraease warm on left side, dispenses warm water
not dangerous, i would recommend vacuuming coils under and behind refrig, make sure the fan behind the unit( cooling for compressor) is running full speed. the water is probably "warmer" then usual because the waterline runs across the bottom of the refrig, which appears to be overheating as it is. this should rectify your issue
Nov 20, 2008 | Whirlpool ED2FHEXNS 21.8 Cu. Ft....
Freezer / Refrigerator not cooling
When the fans are running the compressor should also be running. If the compressor is hot but not running you have a compressor problem. If the compressor is running check for frost on back wall of the freezer compartment which would indicate a defrost system problem. At five years old have you cleaned the condenser where the heat is transferred to the outside air in the room?
Nov 19, 2008 | Whirlpool ED5FHEXMQ Side by Side...
Whirlpool gold side by side
if the fans are working, can you detect if the compressor is also working/running?
the compressor is located at the back side , lower portion. remove the back cover and observe the compressor if it is running.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
202 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
