Question about Sony MDR-V700DJ Professional Headphones
Right Earphone has stopped working.. left one works perfectly. there does not seem to be a loose connection. I have not dropped them or used them at stupidly loud levels.
  • Sony Master
  • 5,391 Answers
Sometimes the lead can break clean, internally, but most often it's inside the plug. If you are good with a soldering iron cut the plug off and fit a new one. But I would open the Right headphone first and see if you can see if the speaker works. They look like you will have to take off the pad first, remove any foam from the front, you should see screws to open it up.
Test the speaker with a low voltage battery, it will pop if connected to the terminals.
Posted on Nov 30, 2009
How can I fix my phone cause now it let me listen through my left earphone only.
that should indicate to you that it needs to be properly diagnosed and/or repaired by a technician in a phone repair shop
Oct 04, 2016 | Cell Phones
Earphone jack doesn't seem to work
tried to hooked up with other earphone jack first, if still doesn't work check the earphone jack of the tv which may have loose contact joint in the board.
Oct 14, 2012 | ViewSonic Televison & Video
The sound is coming out perfectly in the right earphone but it is barely coming out in the left earphone
Then you need to adjust the earphones plug in, adjust it gently and it will sound right on both earphone. It is the plug that is causing the problem. Adjusting it will solve the problem for you.
Jan 11, 2011 | ILuv Audio Players & Recorders
Left earphone just stopped working -
I just solved my problem. My left earphone wasn't working or would work some of the time with it cutting in and out depending on my head position or if I moved quickly. What I did follows:
1. Took ear pad off
2. Took black liner off of the inside of earphones. Glued on 2 spots.
3. Below the silver band of material is a clear plastic lining that covers the speaker.
4. I pressed that clear liner to see if it helped make the left earphone work and it did.
5. I had to fiddle with it to get it perfect but it worked for me.
I'm sure this would void any warranty and work on your own headphones at your own risk.
Aug 26, 2009 | Bose QuietComfort 2 Consumer Headphones
The sound comes and goes from right part of headset
The left/right problem could be a bad connection on the red/white XBOX cables. Check to see that they're plugged in properly and not loose. You can also try plugging an MP3 player into the red/white jacks to see if the problem is with the headset or the XBOX. If it works ok with your MP3 player, then the headset is working fine.
You can get a new headset controller cable on our web site. Click on Replacement Parts in the left menu for the headset model you own (X1, X3, or X4).
Jul 04, 2009 | Voyetra Turtle Beach Ear Force X3 Wireless...
Right earphone wont work.
It is very likely that the problem is in your MP3 player and not your ear phones. If it is still under guarentee, then take it back to where you bought it. If not it may be that the earphone jack plug is faulty? It is a trade off between the cost of repair against the cost of a new one. These things are often glued together so opening it could break it anyway - sorry
Jul 02, 2009 | Nextar MA933A MP3 Player
Right part of the earphone is not working
THE RIGHT SPEAKER OF YOUR EARPHONE HAVE TO BE CHANGED
Aug 08, 2008 | Radio Communications
Sansa E250 Left Earphone Issue
I have the same problem and read on other forums that it was because of a MusicEQ glitch and that if you swtched it to a non-Normal mode and then back to Normal, the problem would fix itself. This didn't work for me, but maybe it will for you.
(Just got off the phone with Sandisk Tech Support and they basically told me to update to the latest firmware, but that didn't work either so they said that they didn't know what else to tell me and let me go. Not exactly helpful.)
Feb 17, 2008 | SanDisk Sansa e250 MP3 Player
Earphones stop working
I had this very problem. The Sansa worked great for over 1 year, but then I started getting some dropping out of sound on the left side. Today I went to an electronic shop and they opened up the unit. There was a small crack in the solder of the earphone jack on one side. So the electrician just used a fine point solder and fixed that, then strengthened the other solder points of the jack to make sure it won't happen again... I hooked in the earphones....and it is PERFECT again!!!! So, don't lose hope...just take it in to a decent electronics shop and they will most likely be able to fix your problem. And he only took around US$10 for the job. Beats buying a new player...
Mar 28, 2007 | SanDisk Sansa e270 MP3 Player
Sony MDR-V700DJ Professional Headphones Logo
811 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
