My projection tv has blue spots what causes this
  • 5,138 Answers
If it is DLP Bad engine light. Call Encompass Parts 1-800-638-3328
Posted on Nov 13, 2009
5 Suggested Answers
SOURCE: color spots on panasonic projection screen
Move anything magnetic or any sound producing electronics away from you television. This includes stereo speakers or alarm clocks. Give your TV 30min. to 1hr. to cooldown completely and see if that fixes your problem.
Posted on Jul 31, 2008
  • 65 Answers
SOURCE: Blue & green star like spots on Panasonic rear projection LCD TV
The EEPROM needs to be reprogrammed. You should contact Panasonic customer care as they may fix this at no charge to you.
Posted on Aug 09, 2009
techman007
  • 1112 Answers
SOURCE: Hitatchi 52" rear projection TV has blue spot in middle of screen
Hello :
I suggest u retrace you the steps u took to replace your lamp make sure no foriegn objects got on the prism where the light shines throung the optics engine, if you remove the lamp compartment througly. If you had a perfect picture prior to replacing the lamp, then retracing your steps you might find something that does not belone. One final note: Did you purchase the right lamp 120watts anything higher than this wattage could damage your optics engine. I suggest never vacuuming the compartment because particals fly around from the suction and could get on the glass of the color wheel asembly.
Posted on Sep 25, 2009
  • 1039 Answers
SOURCE: lg rear projection tv has blue spots on screen,
Replace light engine.
Posted on Nov 25, 2009
Blue spots on Sony WEGA KDF60XS955
Thats caused by a bad optical block. The cost of that repair will almost always be greater than replacing the TV.Thats a very common issue with alot of Sony DLP models which suffered that optical block issue with the blobs of color usually blue or green
Dec 10, 2012 | Sony Grand WEGA KF50WE610 50" Rear...
Sony tv proyection have blue spots on tv screen
Blue spots is usually a optical light engine--what is the model number of your Sony TV?
May 27, 2012 | Panasonic PT-50LC13 50" Rear Projection...
Have a blue spot on the screen. started just
Hi,that's an issue with the light engine.Basically there's 3 chips blue,green and red they create the image on the tv ,when they start to fail you'll get those spots all over, mostly in the corners.God bless you!
Oct 05, 2009 | Mitsubishi WD52527 52" Projection HDTV
We have a blue spot just below center, not extremely annoying just there. Light engine was replaced 2 1/2 yrs after tv bought. TV only 3-4 yrs old. Thanks for any help.
This blue is caused by magnetic fields. Either the speakers of tv is faulty or demagnatziser not working. Switch of tv and remove powercord from wallsockets. Leave for about 10 hours and plug in powercord and switch on. if demagnatiszr is working the blue will be gone. if not have youre tv demagnetized
If hometheatre or radio speakers are closer than ½ meter this could also generate coulouration of screen. move speakers further away. If tv is on and and being moved your static electricity can also cause this. So switch of if if you move your tv.
Aug 09, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Jul 07, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Blue spots
This is a Light Engine problem. Call a good TV Tech and explain the problem. These can be rebuilt for around $450. New ones are $800 to $1200.
Jun 30, 2009 | Sony Grand WEGA KDF-70XBR950 70" Rear...
TV issue
There are many causes for spots on top of an LCD rear projection tv, you are probably in the first two cases, both require part replacements and repair job.
If the spots are faint blue, green or pink shadows, then it can be a problem with the anti polarization panel placed on top of the LCD.
Similar spots (colored shadows) may be caused by a problem with the light engine, in that case the fix will be expensive.
If the spots are bright lights, like an aura, that is a problem with the color wheel.
Problems on the light tunnel can cause static gray shadows.
If the spots are static dark stains than that is lcd liquid, the LCD panel must be replaced.
Oct 15, 2008 | Televison & Video
Blue spot
the model number KP-51WS510 deosnt use a bulb or lamp. and touching the face of the lamp will not cause color problems in the picture. if your tv is an LCD projection then i would suspect the optical engine as the culprit. to check when you turn the tv off do you still see the blue distortion? if so then you have a bad optical engine.......as long as it is an LCD projection.
Apr 04, 2008 | Sony KP-51WS510 51" Rear Projection...
Blue Spots on my Zenith D52WLCD TV
are these blue spots as stated in the first line of your complaint or is the blue over powering the rest of the picture?? And are they spots or small blue particles?? Need more info please!
Mar 24, 2006 | Zenith D52WLCD 52" Rear Projection...
Televison & Video Logo
393 people viewed this question
Top Televison & Video Experts
Electro Med Services...
