Question about Frigidaire ATF6000ES Front Load Washer
Spin Cycle missing. - Frigidaire ATF6000ES Front Load Washer
  • 770 Answers
Could be a couple of things, depends on the age of the washer. On Newer models, When you close the lid it pushes a switch, try this, stick a pencil in that hole and see if the washer then spins, if it does, that switch will need replacing. If it does not, it could be a celenoid that is not switching you to the spin cycle. You could have a dirty or bad clutch that is either not working, or overheating on spin and causing your motor to shut down. You could have worn brushes on your armeture. Good Luck, I hope this is helpful.
Posted on Nov 12, 2009
  • Hal Hallman Nov 12, 2009
    Did you get my solution? I saw the problem re-posted...may have been someone else?
The machine is not spin after wash, motor pump is work, and for wash is turn one shot left and one shot right and stop,...where is the problem???
Reasons Why Your Washing Machine Won't Spin
losangeleswasherdryerrepairservice.com > News
Apr 16, 2012 - When the washer enters the spin cycle but does not start to spin, you will need to see if there is ... West Los Angeles Washer and Dryer Repair Service ....After the water has drained, the spin cycle will start. .... Drive Motor, GE, Maytagwashing machine won't spin, spin bearing, washing machine clutch worn ...
Spin Cycle Not Working on Washer ' ThriftyFun
www.thriftyfun.com/Spin-Cycle-Not-Working-on-Washer-1.html
My washing machine will wash but the spin cycle will not spin or drain the tub what do I do to repair that? By Shelly H. ... Question: Washer Stops After It Fills for Rinse Cycle and Does Not Spin. By henryj ... Our GE washer will not spin when it has a load of clothes. It washes .... I have a Frigidaire stackable washer and dryer.
How to fix a washer that will NOT spin ONLY. THE EASY ...
? 3:56
https://www.youtube.com/watch?v=_8myOfPzGfM
Aug 4, 2012 - Uploaded by Brad Hyman
My washer did not spin but the belt drive worked to agitate the ...How to Fix a Washing Machine That Does Not Spin (Fast and Easy) - Duration: 8:45. ... Washer Top Load Not Spinning - Repair & Diagnostic- GE, General ...Missing: dryers
Feb 09, 2016 | GE Dryers
Whirlpool wont spin on rinse cycle
What is the model number??
Jun 28, 2013 | Washing Machines
Machine will rinse but wont always spin
Possible that the program controller is not proceeding sequentially to the program cycle and so there is a missed spin at some point.
Check the connections from the program controller, before it can be suspected.
Jan 22, 2013 | Whirlpool Estate TAWS750PQ 27-Inch Washer
My whirlpool ultimate care 2 will not spin clothes completly out unless it runs a spin cycle a few times?
after the first spin cycle check to see if there is any water at the bottom of the tub if you find a couple of inches the problem is probably something plugging the pump tou know that sock your missing. if know water it could be the clutch that drives the spin tube may have oil on it or worn out if oil you will have to replace the spin tube seals and maybe the trans.
Mar 08, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Spin cycle is hit and miss,
It could be the timer but don't rule out a loose lid switch. You have to remove the knob to get the timer off. To do so you have to pull the retaining rod out a bitdd8bcfd.jpg
To get inside the controls
Apr 19, 2010 | Whirlpool Inglis IP4400 Washer
Loud clanking noise during spin cycle. Will not
If it is a front loader, then remove the rear panel, remove the belt, and soin drum by hand, if it feels rough, or is noisy and rumbling, then the main drum bearings have failed.
This is a major repair.
Feb 01, 2010 | Whirlpool LHW0050PQ Front Load Washer
Kenmore washer 80 series misses spin during wash.
You may need to replace the motor coupling between the pump and motor...
Apr 07, 2009 | Kenmore Washing Machines
EXTREME SHAKING DURING SPIN CYCLE
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 27, 2008 | Washing Machines
MALBER WD 1000 - UNSPUN HERO
use the rinse cycle on the machine in conjunction with the spin that should solve the problem
Apr 16, 2008 | Malber WD1000 Front Load Washer/Dryer
Frigidaire ATF6000ES Front Load Washer Logo
26 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
