Question about Whirlpool LSR9434PQ Top Load Washer
How to install the rear clip on the whirlpool washer lsr9434pq4
  • 5,911 Answers
Follow these steps:
1. First, make sure you have the washer casing seated correctly on the frame. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make sure the back of the washer fits into the washer casing on each side by leaning over the front of the washer and grasping the back panel and pull towards you.
3. Reinsert the brass clips by placing the 90 degree bend of the clip into the slot on the back of the washer first. With the clip inserted on the back panel, forcefully push the J-hook end of the clip down into the opening on top of the washer. The clip should snap back into place and the washer casing should fit tight against the back panel and frame.
If you have any questions, please let me know. I hope this helps you.
NOTE: Each clip has a 90 degree bend at one end, and a j-hook end at the other. The 90 degree bend fits into the back panel slot, the j-hook fits into the top panel. Make sure the clip is properly oriented, or it won't fit properly.
Posted on Nov 12, 2009
My 2005 Avensis sedan front windscreen washer does not work - wipers do still opperate. Where is the fuse for this located and what else could cause this problem?
PROBABLE CAUSE Impact to the front bumper pushes the bumper back far enough to break the washer pump hose fitting. CORRECTIVE ACTION Replace the windshield washer reservoir and washer motor with updated parts. REPAIR PROCEDURE 1. Turn the ignition switch to ACC (I) to unlock the steering column. 2. Raise the vehicle on a lift. 3. Remove the right front inner fender. Unhook and pull back the bumper for better access. CLIPS (6 places.) SCREWS (6 places.) RIGHT FRONT INNER FENDER 4. Release the hooks on the upper right side of the front bumper. 5. Remove the clip from the filler neck, then remove the filler neck. FILLER NECK CLIP WINDSHIELD WASHER RESERVOIR CLIP WASHER MOTOR CONNECTOR BOLT BOLTS WASHER TUBES 6. Remove the right front fender trim, and disconnect the washer hose from the 90-degree fitting. CLIP FRONT FENDER TRIM FRONT HOSE 7. Disconnect the 2P connector and the two washer tubes from the washer motor. 8. Remove the washer reservoir clip and the three bolts, then pull out the reservoir. 9. Assemble the new reservoir components, but do not install the filler neck. 10. Trim 85 mm off the end of the 1,260 mm washer tube only. 11. Route the washer tubes on the reservoir. NOTE: The black fitting is for the front windshield nozzles, and the white fitting is for the rear nozzle. 85 mm 12. Install the reservoir. 13. Connect the rear tube to the straight fitting in the wheelwell. 14. Connect the 2P connector to the washer motor. NEW RESERVOIR Connect the rear washer tube. CLIP BOLT 9.8 N•m (7.2 lb•ft) 15. Install the filler neck with the original clip. Connect the front washer tube to the 90-degree fitting. Then reinstall the front fender trim. WASHER FLUID DIPSTICK 2P CONNECTOR FRONT FENDER TRIM FILLER NECK CLIP
May 15, 2011 | Toyota Passenger Cars & Trucks
How to change rear barke shoes
Brake Drums & Brake Shoes Removal & Installation To Remove:
  1. Raise and safely support rear of vehicle.
  2. Release parking brake.
  3. Remove rear wheel assemblies. NOTE: If brake drum is stuck, install two 8 mm bolts into threaded holes and tighten evenly.
  4. Remove top return spring, front and rear shoe spring clips and hold-down pins.
  5. Remove anti-rattle spring and adjuster spring. NOTE: Note position of operating lever prior to removal.
  6. Remove bottom return spring.
  7. Remove clip and washer and detach parking brake cable from rear shoe.
  8. Remove brake shoes.
To Install:
  1. Lubricate all brake shoe contact points with appropriate grease.
  2. Place operating level into position on hub.
  3. Install rear brake shoe and connect parking brake cable to rear shoe with washer and clip.
  4. Install front brake shoe and install bottom return spring.
  5. Install hold-down pins and spring clips.
  6. Position operating lever and install top return spring.
  7. Install anti-rattle spring and adjuster spring.
  8. Install brake drum and screws.
  9. Adjust brakes and install rear wheel assemblies.
Jan 21, 2011 | 2003 Kia Spectra
No water comes in
The soleniod valve may be bad.... here is a tip that will help...
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
heatman101
Apr 17, 2010 | Whirlpool LSR5132PQ Top Load Washer
WASHER PROBLEM
top panel flips up, two clips on each side under it releases the cabinet, pull foward on cabinet and take it off then two clips holding pump and two holding motor
Jul 07, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Need to know how to put shell back on washer
If this is a Whirlpool top-loader, follow these steps:
1. While looking down through the lid opening of the case, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
Let me know if you still have questions. I hope this helps you.
Apr 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How to replace the gear case for whirlpool washer lsn1000kq0
remove 2 screws on rear of console lift console forward and roll back remove the lid switch connector remove the 2 clips on each side pull rear of cabinet forwardand slide cabinet off remove screws in center of agitator under cap and pull off ..lean washer backward remove pump clips and hoses remove 2 screws in motor clamps remove clamps and motor remove 3 1/2 in bolts holding gearcase to bottom slide gearcase out remove clutch and reinstall on new gearcase if you go slow and take note reassembly not that hard
Nov 26, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Top load whirlpool washer
you don't remove the 2 screws on rear of console lift and roll console back remove 2 brass colored clips on eack corner remove lid switch plug pull cabinet forward and off
Nov 14, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Remove shell to washer
easy, find two screws at front corners of control panel bottom, remove and lift panel (may slide forward then up) panel is hinged in rear. See two brass clips, use flat screwdriver on front end of clip and pry out both, unplug lid switch, and tilt cabinet back and off- hooked under front and over side rails.
Jun 02, 2008 | Whirlpool Washing Machines
Whirlpool washer cabinet reataining clip
its a weird clip ill give you that, theres a side with a 90 degree angle to it?? that end will hook up and into the **** cut in to the rear panel of the unit. then the 2 curved humps should kinda sorta line up with the 2 small rectangle cut outs in the cabinet, they should just about line up and witha slight push down with the heel of your hand it will snpa in, if it doesnt line up just right it means thecabinet is not on correctly]
Apr 28, 2008 | Whirlpool LBR5432PQ Top Load Washer
Whirlpool LSR9434PQ Top Load Washer Logo
123 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
