Question about Dell Inspiron 1525 Notebook
Dell inspiron 1525 battery doesnot charge - Dell Inspiron 1525 Notebook
    Novelist:
  • 225 Answers
1. remove all external peripherals 2. try to use ac adapter alone check if laptop will power on. 3. put back batt in with ac adapter. 4. check bios (power on laptop keep tap on F2) 5. check for the bios version, battery info and battery health. 6. check if batt is 0% or 10% charge 7. check battery health and info if the ac adapter is determine or not. also check if batt is performing normally. 8. if batt has 10% charge then download the latest bios for your system. download it from support.dell.com
Posted on Nov 13, 2009
Dell inspiron 1525 battery not charging
Try to isolate the battery by plugging the power adapter to it. Then remove the power adapter & press/hold the power button for 5 seconds. Insert the battery, turn on the pc & insert the power adapter , check if the battery is charging. If it is still the same, contact their Dell Inspiron tech support 1-800-601-3355 for battery replacement possibly...
May 28, 2010 | Dell Inspiron 1525 Laptop Jet Black
I have a dell inspiron 1525 the battery light was blinking orange and wouldnt come on so listening to an expert i bought a new battery when you first plug it in should the light still be orange??
Hi. Blinking orange light on battery indicator means it's charging. To make sure, point your mouse to the battery icon on the Taskbar located on the lower right-hand corner of your screen...near the system time and speaker icons. It should say plugged in, charging. If you see "plugged in, not charging, then you need to call Dell Phone Support for additional help.
^_^
^_^
May 10, 2010 | Computers & Internet
Dell inspiron 1525 laptop battery wont charge
Hi. Download the latest BIOS from www.support.dell.com and follow the instructions carefully. If the system still doesn't charge the battery, it's either you have a dead battery or the motherboard needs replacement.
^_^
May 10, 2010 | Dell Inspiron 1525 Laptop
Dell 1525 won't run on ac but will on generic battery
Dell systems will not charge the battery without a Dell Branded AC adapter connected to the system (The BIOS looks for the adapter ID and disables the battery charger if not ID'd)
It appears, that since the system will not power on with either AC adapter, that there is a problem with the power connection of the system. You can replace the power board
http://cgi.ebay.com/DeLL-Inspiron-1525-1526-Power-Jack-Board-48-4W006-011_W0QQitemZ380212346664QQcmdZViewItemQQptZMotherboards?hash=item58866bff28#ht_953wt_1165
if that fails to resolve next is the motherboard
http://shop.ebay.com/i.html?_nkw=dell+inspiron+1525+motherboard&_sacat=0&_dmpt=Laptop_Adapters_Chargers&_odkw=dell+inspiron+1525+charger+board&_osacat=0&_trksid=p3286.c0.m270.l1311
Mar 14, 2010 | Dell Inspiron 1525 Notebook
Hi, At my dell 1525 the battery status led flashes 4x orange folowed by a blue flash a.s.o. The dell manual identifies the battery as the cause. But, except for this optical signalisation, the laptop works...
Dell Inspiron 1525 PC Notebook Hi,\r\nAt my dell 1525 the battery... Answer Hi, At my dell 1525 the battery status led flashes 4x orange folowed by a blue flash a.s.o. The dell... (More) Hi, At my dell 1525 the battery status led flashes 4x orange folowed by a blue flash a.s.o. The dell manual identifies the battery as the cause. But, except for this optical signalisation, the laptop works well, the battery is charging, the AC adaptor is working properly. What is happening? Stefan
Feb 19, 2010 | Dell Inspiron 1525 Notebook
I have an Inspiron 1525 Notebook and I turn it on and it starts like it is suppose to and then Right before I get to my sign on page it goes to a blank gray screen, What could be wrong
it could be corrupt windows or your resolution in windows was set to high that your monitor does not support or you may have installed the wrong video driver or if you have daul video outs the secondary may be enebled thru windows causing the monitor on laprop to turn off thinking its on ext video!
Sep 01, 2009 | Dell Inspiron 1525 Notebook
I have a dell inspiron 1525 and it wont charge
If possible could you check output voltage of the charger with a multimeter? If you can get output voltage, then might be something wrong with laptop battery charging circuit. Contact Laptop Repairing Engineer.
Regards;
Hassan
Aug 04, 2009 | Dell Inspiron 1525 Notebook
Dell Inspiron 1525 Battery won't charge
i recommend you to buy new one.. for dell 1525 .. must better
Jun 08, 2009 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 won't charge
The battery has most likely been "Over charged". Most rechargeable batteries can only be charged around 500-1000 times depending on the brand of your computer. I would recommend buying a new one.
May 30, 2009 | Dell Inspiron 1525 Laptop
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1525 Notebook Logo
228 people viewed this question
Alun Cox
