Question about Xerox Document Centre 265ST Printer
Printing fault I have 2 copiers with the same problem. Message on the screen says "Copier not available. Printing fault. Call for service." I replaced the Xerographic unit and Developer collector. No change. Can't get into the tools pathway to run a Xerograhic set-up. Any suggetions?
  • Alian04 Jan 10, 2008
    Good call. Cleaned both developer housings. The problem went away on the first machine. Second machine still had the problem. Replaced toner motor. That solved it. Thanks for the help.
  • Anonymous Mar 19, 2014
    Problem with Xerographic system and does not print
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 78 Answers
Clean your backer bar
Posted on Dec 02, 2009
    President:
  • 2,072 Answers
What usually causes that problem is a bad roller in the developer housing. It builds up ink and will not set up correctly.
The second problem in that area is a bad toner dispenser.
I mostly suspect the developer housing donor roll is bad.
Posted on Jan 08, 2008
  • Rick Kasper Jan 10, 2008
    Your welcome.
    Actually, you can remove those donor rolls and clean them with scotch brite or emery cloth.
    Just gently remove the impacted toner with the sanding material then wipe. You will see the roller turn slightly gray instead of black.
    The toner impacts to the surface of the roll causing it to not set up properly.
    Glad to be of assistance.
Cant get copier to copy anything. i've done 2 nozzle checks and 4 deep cleans & all tanks have ink in them.5100 comes up on screen????????????????????
how about printing? is it also doing it on printing? if it is only on the copier's end, you may need to send it to cannon for servicing unfortunately. You have done everything you can, some mechanical problem may be causing it.
Jun 25, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Error Box on Scree with Error SC-545
Hello sir; According your message, I guess your copier should be Ricoh, any way need to reset your machine, just follow following steps;
1, press "clear mode", "107", and hold down "clear/stop" key until screen change message.
2, turn power off and back on,machine should be in working now.
May 29, 2009 | Ricoh Office Equipment & Supplies
Machine error 7a on brother mfc8640d
Same problem with mine! You can replace cheaper than repair!!!!!
Apr 28, 2009 | Brother DCP-8040 Copier
Try to print--scanner failure appears
I think your printer has been, for some time now, trying to tell you something and the scanner failure message
is the last in a series of messages.
First, the copier and the printer and the scanner worked fine, "for years",
Then, the copier stopped accepting scans, while printing from data sent by your computer.
Then, you received a scanner failure message again, and will not accept data from your computer, and
"won't print at all"
Your printer/scanner/copier/fax has needed service for some time after years of continuous service.
Evaluate now, based on its initial cost and the lesser cost of All In Ones whether you have already
obtained sufficient service to amortize the cost over time, and you may conclude that service is eitherr
cost effective or ineffective at this time.
Apr 17, 2009 | HP Office Equipment & Supplies
Sharp copier printer error: PostScrip printing not licensed for t
what is you OS? check you printer drivers. are they properly installed?, what is your connection between your PC to your printer?, AR 275 can be connected thru network, parallel port, and a USB... they have different printer drivers
Feb 01, 2009 | Sharp AR-275 Copier
Hammer voltage 2
A high resistance coil fault has likely occurred in one or more of the hammer coils. Note: this fault message will have been preceded by printing slow-down attempts associated with On-The-Fly thermal monitoring of hammer bank temperature.
Check the hammer bank for defective coils.
Replace the
Controller Board
Jan 08, 2009 | TallyGenicom 6312 Matrix Printer
Canon 3300i prints / process very slow
These machines can print slowly for a varity of reasons. First and foremost is using the incorrect driver. The correct driver can be downloaded here:
http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2275&modelid=6349
Also slow printing can be a symtom of a hard drive about to fail (e602 codes).
Fastest printing speeds can be achieved using the following basic assumptions:
1) The copier is printing thru a standard cat5 cable; not thru the parallel port.
2) The network the copier is on is healthy and operating normally.
3) The network settings on the copier are configured correctly.
I am a Canon trained authorized tech on these machines and have been working in the field on the ImageRunner 3300 series since their release. I'm not sure if a ram upgrade is available but I haven't installed one in the six plus years of servicing this machine to fix a slow print problem.
Nov 09, 2008 | Canon imageRUNNER 3300i Printer
It doesn't print some pdf files from our computer
you can try to use the postscript driver, it should proccess it better. If you need to use pcl driver change the driver setup... under the properites of the driver click port tab... click config port....click lpr and in the Queue name type...print
this should help if not you may need the service tech. to upgrade software rp
Mar 19, 2008 | Canon imageRUNNER C3220 Color Copier
System Fault
9-357.
Black toner problem.Probably You have low toner sensor defect.
But try first to vacuum and clean black toner dispenser.You must vacuum whole path wich is used to transport black toner to developer unit.Then if printing B/W print only, you must print 10 full color sheets every 100 copies.
Jan 29, 2007 | Xerox DocuColor 12 Printer
Xerox Document Centre 265ST Printer Logo
185 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
