Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Icemaker is dripping
I was told to check the inlet switches continuity but im not sure what test ports i am suppost to use iwithout looking i think there is maybe six each with a different letter by the way this is a kenmore coldspot model#59227990 any help would be greatly appreciated my wife hates warm soda
  • bigbad Jan 08, 2008
    hey thanks for the respons and yes the mold is flaking apart so i guess i have to replace the whole thing just curiuos what exactly happened so i guess you cant relpace certain parts on these particular modules?
  • 90 Answers
You may need to replace icemaker. Pull icemaker out and look at the mold to see if it is flaking apart.
Posted on Jan 08, 2008
  • Douglas Woods Jan 09, 2008
    part # for the mold crosses over to icemaker
Not getting water to ice maker
Directions for testing an icemaker water inlet valve.
Before you begin to test your icemaker's water inlet valve, make sure you disconnect the appliance's power supply. The easiest way to do this is to unplug the unit from the wall. Alternatively, you could trip the appropriate switch in the circuit breaker panel, or you could remove the appropriate fuse from your home's fuse box.
Consult with an appliance repair technician if you do not feel you have the skill or the ability to successfully complete this test.
  1. Locate your icemaker's water inlet valve, it is typically located behind a refrigerator. Gently pull your refrigerator away from the wall. You may want to place scraps of carpet, of some other soft material below the fridge to prevent damage to the floor. Turn of the water valve's water supply by closing the shut-off valve in the waterline leading to the water valve. Remove the lower access panel on the back of the refrigerator using a screwdriver or a nut driver.
  2. Place a container under the valve to catch any water that may spill from the water valve and its fill tube. Remove the water valve's fill tubing. Loosen the flare nut on the brass fitting that is found on the inlet side of the water valve. You can use a wrench to loosen the flare nut.
  3. Your water inlet valve is held in place on your refrigerator by means of a metal bracket. Use a screwdriver or a nutdriver to remove the screw that holds the water valve's bracket to the refrigerator cabinet. Gently pull the water valve out of the cabinet, and remove the tube from the outlet port.
  4. There are two wires connecting to the terminals of your water inlet valve. If yours is a double solenoid water valve, it will have four wires. Be sure to label each wire so that you know where to reconnect them later. Firmly grasp the metal connector of the wires in order to remove the wires. You may need to use a pair of needle-nosed pliers. Do not pull on the wires themselves.
  5. Set your multitester to the R X 1 ohms setting to test for continuity. Place each of the multitester's leads on a terminal. Your multitester should display a reading between 200 and 500 ohms. Closely examine your water inlet valve. The exact ohm resistance rating you should test for may be marked on the valve.
  6. If the test you conduct with your icemaker water inlet valve does not produce these results, then you should replace the component.
Oct 12, 2012 | GE WR57X10033 GE Refrigerator Water Valve
Ice Maker doesn't work, condenser fan was not running
It could be the the control board or a broken wire in the door.
But if you hear the timer motor running then you are getting power to the ice maker.
Have you check the temperature in the freezer?
The freezer must be 5 degrees or below for the ice maker to work.
Here is a link on how to test the ice maker.
Jul 20, 2008 | GE GBS22HCR Bottom Freezer Refrigerator
Water leaking from icemaker
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Aug 30, 2011 | Kenmore Refrigerators
Icemaker not making ice
Hi
Please check the water inlet valve, it might be frozen or blocked with mineral deposit. Use a hair dryer to remove the blockage. Make sure the water inlet valve's screen is not blocked. If the issue persists, then the water inlet valve has gone bad, use a multimeter to test the water inlet valve's continuity. Use a multimeter to test the continuity. Hope this helps...please post back for further assistance.
Daniel
Aug 24, 2011 | Maytag Refrigerators
ICEMAKER OVER FILLS TRAY
Nov 04, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Icemaker in refrigerator overfills with water
If it continuously drips after it is supposed to stop, replace the water inlet valve on the back where the house water supply comes in.
Oct 14, 2009 | Kenmore 53642 / 53644 Side by Side...
GE adora side by side refrigerator DTL181C5RRBS
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Sep 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker overflows into holder freezing
Sep 07, 2009 | Refrigerators
Lg refrigerator icemaker leaks
Aug 30, 2009 | LG LSC26905TT Side by Side Refrigerator
My Kenmore icemaker seems to be leaking water under the icemaker and it drips and freezes
Aug 10, 2009 | Kenmore Refrigerators
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
101 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
