Question about Brother IntelliFAX 1840C Plain Paper Inkjet Fax
Reception problem. need code for stored memory faxes
What is the unless of risograph machine?
Posted on Nov 12, 2009
How do I clear the in use alarm on a canon mx340 printer?
The in use alarm appears to be related to fax reception and printing. There are some options below that you could try:-
Memory Reception If the machine receives a fax under one of the following conditions, it will not be able to print the received fax and will store it in its memory. The In Use/Memory lamp is lit and Received in memory is displayed on the LCD. When the problem is resolved as described, the fax stored in memory is printed automatically.
  • Ink has run out: Replace the FINE Cartridge.
    i_green_arrow.gifRoutine Maintenance
    i_note_e.gifNote
    • You can set the machine to forcibly print a received fax even if the ink has run out.
      However, part or all of the fax may not be printed since the ink has run out.
      Also, the contents of the fax will not be stored in memory.
      If the ink has already run out, we recommend that OFF be selected for Auto print in FAX user settings to store the received fax in memory and print the fax manually after replacing the FINE Cartridge. After you replace the FINE Cartridge and select ON for Auto print, the fax stored in memory will be printed automatically.
  • Paper has run out: Load the paper and press the OK button.
  • A different size of paper from that specified by Page size is loaded:
    Load the same size of paper as that specified by Page size, then press the OK button.
  • Page size is set to other than A4, 8.5"x11"(LTR), or Legal (or 8.5"x14"):
    Set Page size to A4, 8.5"x11"(LTR), or Legal (or 8.5"x14").
  • Media type is set to other than Plain paper:
    Set Media type to Plain paper.
  • You pressed the Stop button to cancel printing of a fax:
    Press the FAX button
Alternatively turn the printer off, open the devices and printers section of Control Panel, right click on your printer and select "see what's printing" and left click on this. A window will pop up which may or may not contain a list of documents. If it does these must be cancelled (Menu - Printer - Cancel all documents). Once all documents have gone from the list turn the printer on and try to print.
Other than the above suggestions I would need to know more about your OS and exact problem. Hope this helps.
Aug 06, 2014 | Canon PIXMA MX340 Wireless Office...
Can't receive large faxes
This is not a UK model but the same principles apply. When you receive a fax it is stored in the memory until the whole page is received, then it will start to print. The memory is not split so if you have a lot of faxes to transmit stored in the memory, they will gobble up the memory and reduce the size for receptions to be stored in. Check to see what is stored and delete them to free up memory. If this does not resolve the issue then the machines memory will need to be cleared by the service mode. As I don't know the UK version I cant advise any further.
Mar 12, 2014 | Canon Laser Class 830i Plain Paper Fax
Our Konica Minolta BIZ HUB C10 message in window is MEM.RX. Can you explain what this means. Thanks
In the Fax/E-mail - Fax Configuration - Reception Operation page, set-
tings for receiving faxes can be specified.Memory RX Mode:
Select whether to allow ("On") memory reception or not
("Off"). In cases when confidential faxes are being
received, the received document can be stored in the
memory and printed at a specified time or when memory
reception is set to "Off". A password can be set to spec-
ify the starting time or ending time of memory reception,
or to cancel the function. The set starting time and end-
ing time are valid every day until memory reception is
turned off.
Choices: On, Off
Default: Off
Configuration Menu Equivalent:
RX SETTING - MEMORY RX MODE
Mar 27, 2011 | Konica Office Equipment & Supplies
Sharp fax machine UX30 memory is full. How to empty fully?
If the memory becomes full while the document is being scanned, MEMORY IS FULL will appear in the display. This may occur during fax reception if too much data is received before the pages can be printed out.
  1. Press these keys: (function) 6 # #
  2. The display will show: RECEPTION RATIO
  3. Press 1 to turn automatic reduction on.
  4. Select the reception ratio to be used in the event that the memory becomes full (automatic reduction is not possible when the memory is full). Press 1 for 93% or 2 for 100%.
  5. Press the STOP key.
If you are attempting to transmit from memory:
  1. Press the START/MEMORY key if you want to transmit the pages which have been stored up to that point in memory. The remaining pages will be ejected from the feeder.
  2. After transmission, the memory will be cleared and you can transmit the remaining pages.
  3. You will also need to transmit the page which was being scanned when the memory filled up.
  4. Press the STOP key if you want to cancel the entire transmission.
Here is a copy of the User Manual for the Sharp UX30:
http://www.docshare.com/doc/227849/Sharp-UX30-User-Manual
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jun 30, 2010 | Computers & Internet
Reception error need code to get fax out of memory, keep putting in yellow cartridge and says it want yellow
To send or cancel a fax in memory, do the following:
  1. Press Menu/Set, 2, 6.
  2. Using the up/dwn arrows, select the job you wish to either send or cancel
  3. Once your fax appears in the LCD window, Press 1 to cancel the fax or Press BLACK/START to send the fax
Hope this solves your problem. Best of luck!
Greg
Nov 12, 2009 | Brother IntelliFAX 1840C Plain Paper...
I am still unable to receive faxes that are printed automatically when they arrive. they mst be going to memory and i cannot get them to print out of memory. can yo please help me. i paid for this service...
If you are getting a low ink message no you will not be able to fax until this is resolved. Once you replace the ink cart. then you can get to the steps where you can clear the fax memory until then the steps that we would give you will not work.
You can visit www.canon.com click on your printer model then on support and you can download the manual in this manual there will be step by step instructions on how to clear the memory on the fax. this can also be cleard once you print them keep that in mind. so first purchse ink then your going to print your faxes by hitting that button twice the reason why it will not work now is because your low on ink.
If you like this solution please hit accept.
Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jul 17, 2009 | Canon MX310 Office All-In-One Printer
How can i get a fax from memory.
Solution: Printing reports and lists MX310
Printing reports and lists The table below shows the reports and lists that can be printed from your machine.
Report or List Description ACTIVITY REPORT Shows recent facsimile transactions performed by your machine. You can enable or disable automatic printing of this report after every 20 transactions. You can also manually set the machine to print it. CODED SPEED DIAL
LIST
Lists the destination numbers and names registered for coded dial speed dialing. USER'S DATA LIST Lists the current settings of your machine and the registered sender information. MEMORY LIST Lists the documents currently stored in the machine's memory. TX (Transmission)
REPORT
Prints after transmission of a document.
You can enable or disable this feature, or set the machine to print a report only when an error occurs.
You can also set the machine to print the first page of the document under the transmission report to remind you of the contents of the document.
RX (Reception)
REPORT
Prints after reception of a document.
To print the Activity Report, Coded Speed Dial List, User's Data List or Memory List: 1 . Press <FAX>, then press <Menu>.
2 . Use leftright.gif to select [PRNT REPORT/LIST], then press <OK>.
3. Use leftright.gif to select the desired report, then press <OK>. The report or list is printed.
Mar 24, 2009 | Canon PIXMA MX310 All-In-One Printer
Faxes being sent but stuck in memory, How do I Print them out?
Printing Documents in Memory: From B640 Manual
Except when you run out of paper, the faxphone will automatically print out the contents in memory when you remedy the cause of the problem.
If running out of memory caused memory reception, adding recording paper and press {STOP} to begin printing the stored page(s).
After printing the page(s) in memory the faxphone erases the documents from memory.
Jan 19, 2008 | Canon FAXPHONE B640 Plain Paper Bubblejet
Brother IntelliFAX 1840C Plain Paper Inkjet Fax Logo
46 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
