Question about Samsung SPH-M300 Cellular Phone
Powering up causes screen to flash on and off
The power up screen flashes on and off
2 Suggested Answers
graysand
  • 558 Answers
SOURCE: power button flashes on and off nand the screen is
the internal power supply is bad.
Posted on Oct 17, 2009
Rca hdtv dlp screen flashing
Sounds like it could be the power supply. Try changing the brightness of the screen and changing picture modes like movie or standard. If this causes the flashing to change in severity, it will most likely be the power supply board
Dec 13, 2013 | Televison & Video
Emerson flat screen won't power off and screen flashes blue ,green, red and black?
Sounds like the main board causing that type of symptom. You can get replacement main boards from www.tvrepairworld.com
Jan 10, 2013 | Televison & Video
Screen only flashes colors, no controls function
remove power from the set and any box being used with it, after a while power both back up, a box or the set can cause this issue.
Dec 18, 2012 | Sylvania 32" Lcd Hdtv Dvd Combo - 720p...
JVC TV has flashing red light in front. TV won't turn on when red light starts flashing. After unplugging tv for a while, TV sometimes turns on but screen is shaking violently. Any flashing lights...
sometimes a leaky filter capacitor in the power supply primary section could caused this problem,or a loose solder connection in the power supply section
Jul 18, 2011 | JVC AV-32230 32" TV
Screen black. Power light on unit flashes red slowly. Power light on switching adaptor power supply flashed green slowly.
Sounds like the battery might be low which would cause the red flashing light and dark screen. Let it charge for a little bit then try turning it on again. If it still does it with the power supply plugged in, make sure there isn't a lens cover on it, and switch modes or try getting into the menu to see if you can get anything to come up. If that still doesn't work then it sounds like there might be a problem with the camera.
May 03, 2011 | Cameras
Power button turns green, flashes and then turns red and flashes.
While working it stops and flashes red approximately 2 seconds interval
Causes
Protection circuit is activated depending on the temperature of the surroundings
Remedy
Switch off the power supply and power on after the temperature have reduced.
While working it stops and flashes red approximately 0.5 seconds interval
Causes
1.Using speakers having less impedance than the specified.
2.If speaker core wire touch each other Protection circuit is activated
Even applying power red flashes 0.5 seconds interval
Cause
Amplifier circuit has failed
Remedy
Switch off the power and contact denon service centre
Thank You
Sep 07, 2010 | Denon AVR-789 Receiver
Flash not working
Hi there and welcome to FixYa.
Bad batteries can cause that. The flash module needs alot of power to charge. Your camera will still work, but without enough power to charge the flash module, it may take along time. Again.
Try fresh batteries.
Rob
Feb 25, 2009 | Pentax Optio T10 Digital Camera
Dell E151FPp LCD Monitor
Next time you reset, check both the monitor settings and your BIOS settings for wake up
Feb 24, 2008 | Gateway FPD2275W LCD Monitor
Flashing Power Light
When this occurs an inverter, backlight, vga connectiosn, etc could be the cause, my suggestion is connect it to some other device, if you get the same result then your monitor is bad!
Nov 26, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
Powerbutton flashing yellow
If the main power button LED is flashing or solid yellow, this could indicate a hardware problem.
Was it running good before?
Are the diagnostic LED lights all green?
Here is what dell says:
If the power light is blinking amber  —
 The computer is receiving electrical power, but an internal power problem might exist.
  • Ensure that the voltage selection switch is set to match the AC power at your location (if applicable).
  • Ensure that the processor power cable is securely connected to the system board.
Do you remember what the BSOD said?
Oct 22, 2007 | Dell OptiPlex GX620 PC Desktop
Samsung SPH-M300 Cellular Phone Logo
71 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
