Question about Maytag MMV4205 Microwave Oven
Wiring diagram Problem - Maytag MMV5207A 1100 Watts Microwave Oven
Fixing a broken power connector from the MW unit to the fan/blower. Need to see a wiring diagram so I get the pin out correct. No diagram in my manuals. Where can I download a wiring diagram for my Maytag MMV5207A 1100 Watts Microwave Oven? I tried to get from Maytag. No can do they say. We'll be glad to send a repair man they say. Pete The cooling fan for the Megnetron, etc. start slowly and acclerates after about 50 seconds and as well the fan seems to modulating like the connection is not good. Other wise the microwave works perfectly. I am wondering if the fan is a one speed or does it varies with the temperature of a senor somewhere. For the last 3 years since new the fan has run at a constant speed from the start of "cooking". Upon observation of the fan blade it is running at all times. The fan blade spins freely with no power.
  • Maytag Master
  • 9,098 Answers
If it is the magnetron cooling fan, it should be a one-speed type.
Assuming your AC line power is correct (110-125VAC) then the fan may be bad, or there may be a problem with the relay on the control board or indeed a bad connection in the wiring.
The way I would test it is to disconnect the fan and the connect a line cord directly to it.
I've uploaded the wiring diagram to my site at:
http://207.234.249.73/mwd/mmv5000_wiring.gif
If you think it's the control board, we repair these for $39.95 in most cases.
We have full details, plus *critical* safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our
listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 13, 2008
What is MW power for this unit?
According to my research, the MW power is 600 watts.
Jul 06, 2015 | Goldstar MA-681M Microwave Oven
What size fuse would i need to replace in a emerson microwavw mw#8992rd
It is critical to use exactly the same fuse type and value that was taken out.
Mar 04, 2011 | Emerson MW8102SS 1100 Watts Microwave Oven
Will not heat
No, you would need to do a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
Jan 22, 2009 | Maytag MMV5207A Microwave Oven
Maytag Microwave
Mine is a model UMC5200AAW. Same problem as above, no power. Is there a reste button?
Nubi541
Oct 07, 2008 | Maytag MMV5207A Microwave Oven
Buzzing noise and flashing
Some units have a silica plate covering the waveguide opening. If it get burn spots on it, it'll do that. Remove the plate and try the unit. If it's OK, go to your MW repair shop and order a new plate.
Remember... always cover your food...
Geno
Mar 10, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Setting the clock on Emerson MW 8115SS
Press Clock, press the numbers for hours & minutes, select with AM/PM pad, then press Clock again to set it.
Yours Emerson microwave owner's manual is available for free download here.
Maytag Microwave Power Outage - Model MMV5000BAB
It's almost certain that your magnetron has failed and/or thermostat which is mounted on it. Fist, unplug the oven from the pwer. Then open the door and remove the stirrer cover in the ceiling of the oven. Look for any dark brown burns, charred spots, or "rusty" looking areas. This would indicate that the waveguide has burned, which means the microwave needs to be disposed of. If it passes that test, I'd say the magnetron and/or thermostat area bad. You can find helpful exploded view diagrams and the wiring diagram and order parts by entering your model number here: http://tinyurl.com/gv383 We have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Sep 17, 2007 | Maytag MMV5207A Microwave Oven
This doesn't have the diagram hidden away somewhere inside? Check at the bottom edge of the control panel, transformer brack, or rear of the oven. Otherwise, you can find wiring diagrams of earlier models that may be close enough. Just enter your model number here: http://tinyurl.com/gv383
Sep 04, 2007 | Maytag MMV5207A Microwave Oven
Emerson MW 8115SS
There is a 20 amp replaceable fuse inside the cabinet next to the power cord
Aug 17, 2007 | Emerson MW8102SS 1100 Watts Microwave Oven
Maytag MMV4205 Microwave Oven Logo
382 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
