Question about DLX 500 Remote Car Starter
Remote will not open doors, shows unlocked on remote
  • 563 Answers
Try a fresh battery.
Posted on Nov 12, 2009
Doors not opening even if they are unlocked
My 2009 Sebring does the same thing occasionally but only the drivers door gets stuck (dead locked - even though the locks appear to pop up).
The solution I have found once this happens is:
1) The car needs to be driven (crawl in thru the passenger door) -even just a short distance
2) Engine shut off & doors locked with remote (after you've exited from the passenger door of course)
3) Leave turned off for 10 minutes
4) Doors will now open when unlocked with the remote
Mar 14, 2014 | 2007 Chrysler Sebring Sedan
All my remotes won't unlock passenger doors, why?
this is a problem that can appear after your car battery died, cause the car didn't reset propely, so taking the battery out and putting it back in or letting your car die again would do the trick. I tried a lot of reprogramming procedured for my remote key, none of them worked, what did the trick though was simply unlocking the doors via the all door unlock button on the passenger side door, so simple.
Apr 27, 2012 | Cars & Trucks
Step by step reset the door remote control lexus 400LS
1. sitting in driver seat, with driver's door OPEN, press lock/unlock button ON THE DRIVERS DOOR to lock all doors, then manually unlock driver door only.
2. Insert YOUR key in ignition, DO NOT TURN, then remove key.
3. Using the same lock/unlock button ON THE DRIVERS DOOR, slowly press lock-unlock in 5 cycles
4. Shut door.
5. Open door.
6. Using the same lock/unlock button ON THE DRIVERS DOOR, again slowly press lock-unlock in 5 cycles
7. With the door open insert your key into the ignition, turn to 'on' position (DON'T START), wait 5 seconds. Turn off and remove key.
8. Locks should cycle once (Car will lock and then unlock once by herself). If they don't cycle or they cycle more than once, do steps 1-7 over.
9. Now using the remote, push lock button, hold for one second, then release the button. The locks should cycle once. If not, start over and go slower.
10. Close the door.
11. Open the door.
12. Press the lock button on the remote. The locks should do a lock-unlock cycle.
13. Close the door
14. Press the lock button on the remote, the doors should lock.
15. Press unlock button and the doors should unlock.
Jun 16, 2009 | 1996 Lexus LS 400
Need the steps to programme the remote
Remote Programming Instructions
1. Driver's door OPEN and unlocked, all other doors closed and locked.
2. Insert YOUR key in ignition, DO NOT TURN, remove key.
3. Using the MANUAL lock/unlock button ON THE DRIVERS DOOR, slowly press lock and unlock 5 times (count the lock 5 times and unlock 5 times).
4. Shut door.
5. Open door.
6. Using the lock/unlock button ON THE DRIVERS DOOR, slowly press lock and unlock 5 times (count the lock 5 times and unlock 5 times).
7. With the door open insert your key into the ignition, turn to on position (DON'T START), wait 5 seconds. Turn off and remove key.
8. Locks should cycle once (Car will lock and then unlock once). If they don't cycle or they cycle more than once, do steps 1-7 over.
release. The locks should cycle once. If not, start over and go slower.
10. Close the door. Open the door. Press the lock button on the remote. The locks should cycle. Close the door. Press the lock button on the remote, the doors should lock. Press again and the doors should unlock.
Jun 02, 2009 | 1995 Lexus LS 400
Drivers power lock will not unlock with remote.
the door lock actuator is defective, they get really hard to move when they go bad, that is why the difficulty with the key.
Mar 31, 2009 | 2000 Ford Explorer
The remte control key is not responding with the car
Hi abdumi0f,
Firstly, open your glove box and make sure Valet Mode is not enabled, if it is not, follow these steps.
Step 1: Open drivers door and leave open.
Step 2: Lock and unlock the driver’s door using the power door lock switch on the door.
Step 3: Insert key into the ignition.
Step 4: Turn key to on position and return to off position. (IMPORTANT - use ON position NOT ACC position). Do this 3 times within 10 seconds. Leave key in the ignition.
Step 5: Open and close the driver’s door 3 times. (Door should be left open after this step).
Step 6: ECU should respond by locking and unlocking the doors.
Step 7: Press any button on remote #1 twice. ECU responds by locking and unlocking the car doors.
Step 8: Press any button on remote #2 (etc.) twice. Each time the ECU will respond by locking & unlocking the doors.
Step 9: Remove the key from the ignition and the ECU will respond a final time with a series of door locks and unlocks. You're done!
Hope this helps,
Lazaruselite
Feb 24, 2009 | 2007 Mercedes-Benz E320 BLUETEC Sedan
Programming keyless remote
2003-04 Mazda 6 REMOTE PROGRAMMING
Good Luck.
Jul 12, 2008 | 2003 Mazda Mazda6
Unlock HTS 3555
Press "Door Open"
- after the door opens perform the following sequence with the remote control:
Press STOP-7-3-4-4-6-6
a Region settings page will be displayed showing the current region on the TV (usually the default is region 1), using the remote control select the region number by pressing the number on the remote (select region 0 for region free) and press OK.
May 05, 2008 | Philips HTS-3555 System
Door Opening Problem
Dear friends,
I have solve the problem.power off the player and press and hold STOP+OPEN,CLOSE button.and than power on the player than display shows unlocked.the problem solved.and enjoy
Dec 03, 2007 | JVC THS55 System
DLX 500 Remote Car Starter Logo
143 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
Matthew Spark
Matthew Spark
John
John
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
