Question about Brother IntelliFAX 1840C Plain Paper Inkjet Fax
Reception error need code to get fax out of memory, keep putting in yellow cartridge and says it want yellow
  • 1,959 Answers
To send or cancel a fax in memory, do the following:
  1. Press Menu/Set, 2, 6.
  2. Using the up/dwn arrows, select the job you wish to either send or cancel
  3. Once your fax appears in the LCD window, Press 1 to cancel the fax or Press BLACK/START to send the fax
Hope this solves your problem. Best of luck!
Greg
Posted on Nov 12, 2009
When recevie fax their is nothing document but error code coming 242
This link covers all error codes. http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu02549&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN#Error232
Error Code: 242 Definition
The remote fax machine is attempting to receive instead of send. Both machines have attempted to start a reception at the same time. On many fax machines, it is possible to accidentally initiate a fax reception in the following cases:
  • There is no paper in the machine.
  • The paper is not correctly loaded and the document sensor cannot sense it.
Solution
Contact the sender to make sure that a document is ready and correctly loaded in the sending fax machine. Also make sure that the remote machine is attempting to initiate a transmission and not a reception.
Feb 28, 2011 | HP Computers & Internet
I have a brother Fax-1860C and it telling me to install a yellow cartridge. I have done this over & over a nothing happens it keep telling me the same thing. I purchased this fax from Office...
ok...when you put that yellow in, you'll need to do a clean and calibrate, before it will 'see' it..try that from the printer management panel
Apr 27, 2008 | Office Equipment & Supplies
I need assistance with fax error codes # 322 and # 358. What do they mean?
Error code 322- There was a communication error with the receiving fax machine due to poor telephone line conditions.
Solution
Set the receiving machine to receive at a slower transmission speed
If the session fails after sending several pages of a large document, resend the document as several smaller documents.
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Error code 358--
The remote user pressed the Stop key,
The remote machine encountered a system problem such as no paper or a paper jam.
Try
Configure the local fax machine to use a slower reception speed.
Disable ECM mode on your machine.
Try sending a fax to another location.
Mar 03, 2010 | HP Officejet Pro L7680 All-In-One Printer
I am still unable to receive faxes that are printed automatically when they arrive. they mst be going to memory and i cannot get them to print out of memory. can yo please help me. i paid for this service...
If you are getting a low ink message no you will not be able to fax until this is resolved. Once you replace the ink cart. then you can get to the steps where you can clear the fax memory until then the steps that we would give you will not work.
You can visit www.canon.com click on your printer model then on support and you can download the manual in this manual there will be step by step instructions on how to clear the memory on the fax. this can also be cleard once you print them keep that in mind. so first purchse ink then your going to print your faxes by hitting that button twice the reason why it will not work now is because your low on ink.
If you like this solution please hit accept.
Thanks
Jul 17, 2009 | Canon MX310 Office All-In-One Printer
How do you turn off the in use/memory light?
This of course depends on why the light is on! If you had a fax come in and it is in memory, you will need to print the fax and clear the memory before the light will go out. The LCD Display should be telling you why that light is on.
1. There is a fax or print job in memory waiting to be printed.--> See steps below
2. There is a paper jam --> Open printer - Remove all paper - Close printer - press OK button
3. You are out of ink or the cartridges are low. - Change Cartridges
Solution: Printing reports and lists MX310
The table below shows the reports and lists that can be printed from your machine.
Report or List Description ACTIVITY REPORT Shows recent facsimile transactions performed by your machine. You can enable or disable automatic printing of this report after every 20 transactions. You can also manually set the machine to print it. CODED SPEED DIAL
LIST
Lists the destination numbers and names registered for coded dial speed dialing. USER'S DATA LIST Lists the current settings of your machine and the registered sender information. MEMORY LIST Lists the documents currently stored in the machine's memory. TX (Transmission)
REPORT
Prints after transmission of a document.
You can enable or disable this feature, or set the machine to print a report only when an error occurs.
You can also set the machine to print the first page of the document under the transmission report to remind you of the contents of the document.
RX (Reception)
REPORT
Prints after reception of a document.
To print the Activity Report, Coded Speed Dial List, User's Data List or Memory List: 1 . Press <FAX>, then press <Menu>.
2 . Use leftright.gif to select [PRNT REPORT/LIST], then press <OK>.
3. Use leftright.gif to select the desired report, then press <OK>. The report or list is printed.
Mar 24, 2009 | Canon PIXMA MX310 All-In-One Printer
UF-788 Error Codes...
You have a bad laser unit, no parts are available anymore.
Nov 20, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Reception error
Do you have a DSL phone line?
Sep 12, 2008 | Brother IntelliFAX 2800 Laser Fax
Faxes
hmmm..with faxes in memory, that message means emptying out the memory, not the print cartridges..poor use of the word on Lexmarks' part.
do you have their print manager installed? if not, you can most likely find it through this link
Mar 04, 2008 | Lexmark X5470 All-In-One InkJet Printer
Printing what is in memory
It probally wants ink to print the stuff in memory, if this has been corrected you can make it print from its memory or you can delete each file, it takes a little doing but this is what you need I think to do so you can free up the memory, to delete a item from memory, press menu, then scroll to a memory item, ok , scroll to delete, ok to delete, ok to delete, menu to get out quickly, standing on one leg :-)
You should be aware that this printer has a serious "ink low" behavior. When any ink cartridge is getting low (which still means a lot of ink left by the way), it changes the Fax reception model. Instead of printing your faxes as they arrive, it dumps them into memory. So, even though yellow (say) is low, it will not print your B&W fax!
It takes more than 5 steps to print the fax and delete it (menu, scroll to memory item, ok, scroll to print, OK document, scroll to print all pages, ok, menu to go up, scroll to delete, ok to delete, ok to delete, menu to get out).
Worse, after a couple of these, the memory is mixed up. So, when you want to send a Fax, it will say "memory full" even though the memory is empty. You then have to power cycle the printer (hold down on/off for 1 second, wait 10 seconds, power on, wait for it to get ready (another 10-20 seconds).
This means you either have to waste ink by throwing out cartridges before they are empty, or you have to deal with this mess.
Nov 29, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Canon laser class 2060p super g3 fax machine
The error keeps flashing and the machine will not work. The error reads, "check cover/cart". We put the cartridge in and out about 10 times and the same error message keeps flashing. the fax machine is still not working. Help!
Apr 24, 2007 | Canon LaserClass 2060P Plain Paper Fax
Brother IntelliFAX 1840C Plain Paper Inkjet Fax Logo
75 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
