Question about Cell Phones
How do I pair samsung C 3050 with Jabra S P 500
How to pair the samsung galaxy s4 to the jabra cruiser
  • Touch Apps
  • 2.Scroll to and touch Settings
  • 3.Ensure Bluetooth is turned on
  • 4.Touch Bluetooth
  • 5.Slide the Power switch to turn the JABRA CRUISER on
  • 6.Press and hold the Multifunction button until you have a rapid flashing blue LED
  • 7.Touch the JABRA CRUISER in the list of devices
  • 8.The JABRA CRUISER is now paired
  • 9.The JABRA CRUISER and Galaxy S4 are now ready to be used
  • 10.Press the FM button in order to start streaming audio via the FM transmitter. The FM LED will turn red
Oct 01, 2014 | Jabra Cruiser InCar Speakerphone Black
I have a samsung phone and i am trying to pair it with my jabra vbt185z but i don't know the passkey...i tried using 0000 but that didn't work. so what else can i do to make it work?
You do need the passcode. It should "auto pair" but the default passkey or pin is 0000 (4 zeros.)
Here is a link to the user manual
http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT2010/Documents/UM/VBT185z_UM_6198.pdf
Headset Pairing Readiness Instructions:
1. Fully charge headset for two hours.
2. The headset will automatically go into pairing mode if no device has
been previously paired.
3. Set your mobile phone to 'discover Jabra VBT185Z'.
4. Enter passkey or PIN = 0000 (4 zeros), then press Yes or OK.
dw
Dec 31, 2010 | Jabra BT150 Wireless Headset
How do i pair sp 500 to my nokia n95 mobile
The Jabra user manual is located below - you'll need to reference it to determine which button is the Pairing button. After you turn on the Jabra, press and hold the pairing button until the blue light is solid (approximately 2 seconds). Set your phone to discover mode as follows:
Go to the Bluetooth menu under the Tools menu item
Select Options > New Paired device.
Select the device and enter 0000 as the passcode.
If you want the device to automatically pair when they are within range of each other, select the device and select Set as authorised.
That's all there is to it.
Feb 20, 2010 | Lands Phones
Trying to pair jabrabt125 with a samsung moment
Go to this site, choose your headset, and then choose your phone and it will walk you through each step. Moving your mouse over the steps will show you exactly what your phone will look like as you pair it with the Jabra.
http://jabra.pairx.co.uk/
Dec 10, 2009 | Jabra BT125 Headset
SAMSUNG SGH-C417 ASK FOR A CODE TO PAIR
The password to pair the Jabra bluetooth is 0000.
Nov 07, 2009 | Jabra BT125 Headset
Jabra BT125 headset not connecting to Samsung F480
you have to switch the bluetooth headset to pairing mode not just swithcing it on. Hold the power on button continuously even after it switches on then the light will remain on. Then you switch on the bluetooth in the mobile and start searching for bluetooth devices. You will find your bluetooth headset in the mobile. Select it and pair. Usual code will be 0000, but it might differ check with the manual which can be found online too. This will definitely solve your problem.
Sep 10, 2009 | Jabra BT125 Headset
I just bought 2 Jabra handsfree sp700s and cannot seem to pair either one of them with either mine nor my husbands's phone. what could be the problem? I have a Samsung Eternity & my husband has LG...
I also have 2 sp700s. They worked fine for a while but now are very finicky. One of the problems is that the phone will sometimes say it is paired but the Jabra will not. I have found I can get them to pair correctly, if I disconnect the charger cable, so the SP700 is running on its battery, and then pair the phone. It will pair and work fine for a while after that. Repeat as necessary.
I suspect this is not your problem, but perhaps my work-around will help others.
Aug 22, 2009 | Jabra SP700 Bluetooth Headset
Can i pair jabra bt125 with samsung blackjack ??
Mine is a Blackjack II, but i did get it to connect. Hold the clear button down on the Jabra until it lights solid blue, keep holding it with one hand while you use the other hand to operate your Blackjack. I went to Settings, then Connections, then Bluetooth, then "Add new device". As long as my Jabra was lit solid blue, the phone found the headset. Then it will ask you for the pin code, which i found by accident (0000 - four zero's).
Jul 11, 2009 | Jabra BT125 Headset
Pairing with a phone
this happened to me too.. i googled a user manual for it.. if i recall it said, turn the headset power off, then once the phone is in pairing mode, hold the power button on the headset till the light stops blinking and becomes a solid blue light. then the headset is in pairing mode as well and your phone should find it
Mar 20, 2007 | Jabra BT250 Consumer Headset
Cell Phones Logo
186 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
