Deskstar 1TB SATA started making ''uncommon'' noises.Now I can't find or access any of the data on the drive. It starts making noise as soon as I put power to it(Heads crashing???)!
    President:
  • 414 Answers
It seems ur hdd is old, while the pc is powered on, bring ur ear closer to the hdd n make sure that it does not make any noise (like 'tuk tuk' or 'kirr kirr')..in such case itz probably gone bad n need to b replaced..
Posted on Nov 12, 2009
  • Subhradip Chakraborty
    Subhradip Chakraborty Nov 12, 2009
    1 tb hdd is however not too old at all..!!..
    it may also happen by the followings:
    a) lack of care...
    b) sudden or imperfect switch/power off..
    c) bad ground/earthing..
    d) shock or thud..esp. when ur hdd is operating..
    if itz under warranty, contact ur system admin/vendor immediately....
How do i transfer data from hard drive if it is vroken
Hi, if you can hear the drive spinning up but then making a clicking noise this means the heads have failed, this would need to be opened up (ideally in a clean room), if the platters are okay you can replace the heads... but if your data is precious to you I would reccomend sending it to a data recovery company Digital Recovery (www.digitalrecovery.co.nz) are fairly good.
Dec 28, 2013 | Hitachi Deskstar 7K1000.C HDS721010CLA332...
Hitachi Deskstar causes a Power Error on my Gigabyte GA-Z68AP-D3
test all leads that attach to your hard drive including electrical extensions, SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
make sure the CPU central processing unit has thermal grease and a dust free secure seating
even something as small as an electrical extension or a faulty fan lead can cause this problem computers need all of the data and electrical current to travel through every working device and to have an end for a computer to be able work properly
could be a memory dump you might have to many programs running at one time putting to much stress on the CPU not having enough ram will do this
might be getting to hot make sure the CPU has a dust free secure seating and has THERMAL paste
if you right click in the bottom toolbar select task manager applications you will see whats running also processes you will see whats ticking over if you see something running that should not be select end now you might even uninstall that program and some unnecessary programs
check your computer ram and cmos battery to make sure they are securely seated and the battery has plenty of charge
some motherboards cmos batteries are soldered in
hope it helps
May 08, 2012 | Hitachi Deskstar 35 1TB 7200RPM SATA II...
Seems to be on a loop - just makes working noises and will not connect to computer. Have tried on another computer, checked "secure-ness" of wire attachments and still nothing. A new wire...
Unfortunately, that definitely sounds like your hard drive is starting to go. If you can't access the data at all then you may be out of luck.
You may be able to retrieve some data off of the hard drive, if you take it to an expert at a local PC shop.
Aug 20, 2011 | Hitachi 1TB External USB 2.0 Hard Drive
My son knocked my 1Tb lg external hard drive off his bed. the computer no longer picks up the drive and I can hear the drive searching . Is it possible to retrieve the data
If you've got deep enough pockets you can send the drive off to a data recovery company who will run diagnostic tests in order to assess the damage that's been done and give you an estimate as to how many megabytes of data they can retrieve but this can be very costly. If you can't access the drive through the operating system because it can't be physically seen can you get to the drive through DOS? If you can you might be able to run some disk repair utilities such as Uneraser or Active@ but the general rule of thumb is as soon as a drive starts making noises such as excessive whirring or clicking it's normally a good indication that something untoward has happened to one or more of the internal components. Good luck.
Apr 11, 2011 | LG Computers & Internet
I have a Lacie 1TB Big Disk Extreme. It has recently developed a loud regular whirring noise, that goes on and off every few seconds. What should I do? Thanks! Adrian
The irregular clicking or chunking sound usually indicates that your hard drive is suffering from physical damage. immediately backup your data, your hard disk will die soon.
This problem can be caused by the following:
  • Head Crash
  • Bad Sectors
  • Mechanical Faults
If your hard disk is under warranty then you contact your manufacturer.
Hard disk drive occasionally produces a whirring sound when it searches for a file which is heavily fragmented. This is caused by the spinning platters as the read-write heads zoom back and forth to access the sectors where the data is stored. It is important to distinguish the whirling sound from the clicking sound. This whirring sound can be reduced by periodically defragmenting your hard drive. Defragmenting reorganizes the scattered data on the hard drive to make files and programs run faster. It relocates the commonly accessed files to the beginning of the hard disk where data can load at a faster rate.
Apr 08, 2011 | LaCie Big Disk External USB 2.0 1TB Hard...
Hi, I have problem here. I just bought Hitachi Deskstar 7K1000.C. It works fine at first, but one day latter some clicking noise appear. It detected in BIOS, but then make my Windows take a very long time...
The short answer is the drive is having trouble calibrating itself, and should be sent back under warranty for replacement.
There are things you could try to recover the unit, but why risk voiding the warranty only to wind up with a questionable drive afterward?
Mar 17, 2011 | Hitachi Deskstar 7K1000.C HDS721010CLA332...
My LaCie 1TB external drive (inside is a Hitachi Deskstar, i think so) does not spin up. Its still turning on, but not spinning up. It will make some sounds whatsoever. I believe its jammed.
I have had a LaCie too i tried all manner of diagnostic tools and formating etc none worked so i took the Hitachi drive out and put in another case and by some act of GOD it worked. I will never by , use , recomend LiaCe to anyone.
Jan 12, 2011 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Maxtor 3000LE makes noise and will not show up on my computer
You will need a data recovery specialist. Hard drives making noise need to be taken apart and put into a special machine to pull what data is not damaged. The more you leave the drive on or play with it the more data is destroyed.
Jun 18, 2009 | Maxtor Hard Drive
SATA INSTALLATION TB HITACHI DESKSTAR
I would recommend you check the website for the latest "bios" (also known as firmware) for the motherboard. Or, see their support to verify you can install a drive this large. Check the Logical Block Addressing (lba) and make sure your bios has it enabled. Older bio's offer several options ..If you need further help, contact us at http://techrxgb.com If you find this helpful, please give me a hands up
Jan 21, 2009 | Hitachi Deskstar 7K1000 1 TB SATA II Hard...
Computers & Internet Logo
102 people viewed this question
David Payne
David Payne
