Question about Frigidaire FRS23KF7AB Side by Side Refrigerator
Frigidaire not making any ice...
My water was recently shut off due to a water pipe problem. The icemaker has not worked since the water was turned back on. The water dispenser works fine but I am getting no ice. The icemaker appears to be going through the cycle however no water is entering the tray. Help!!!!
  • wharvey Dec 27, 2008
    I have an LG side by side. The water was turned off for about 12 hours and when the water was turned back on ,the ice maker dosen't produce ice. I checked the water line going to refer ice maker and it is free flowing. I even turned the ice maker switch off for 24 hours and then back on, still no ice. HELP !!!!!!!
  • 90 Answers
Check inlet tube behind icemaker and make sure its not froze up. If so, it may just need to be thawed out but if it happens again you will need to replace water valve.
Posted on Jan 08, 2008
Frigidaire frs6lf7fm. Ice maker dispenser, the auger won't turn (tested with ttay out). It makes ice and dumps it into the bin no problem. And the water side is fine.
[FIXED] Icemaker auger motor won't turn - ApplianceBlog
www.applianceblog.com/.../18196-FIXED-Icemaker-auger-motor-won-t...
Apr 16, 2010 - 9 posts - ‎2 authors Does the auger motor need to be re-set or something? I wonder if it shut itself down to prevent burnout (because it had been unable to turn the ... FIXED Auger won't turn to dispense ice.
Jun 1, 2014
Ice maker auger will not turn
Mar 17, 2013
FIXED Ice Auger won't turn
Sep 3, 2012
GE Icemaker: Makes Ice, Doesn't Dispense In Door?
Apr 19, 2005
More results from www.applianceblog.com
Oct 01, 2015 | Frigidaire Refrigerators
Kitchenaid Superba Ice Maker quit
If you add some water there, yourself. It should make some ice for you, untill the water runs out.
Try this
http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
Sep 08, 2008 | KitchenAid Superba Architect KSCS25INSS...
The icemaker was making ice but is not now. We
You could have a air block bleed at inlet on fridge.
Be careful and shut off water then unscrew line at fridge put in a bucket and have someone turn the water on for a few seconds. Your line may have become kinked or the water solenoid valve went out not likely. good luck
Jul 16, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
Icemaker is not making ice.
First, check to see if you have an adequate water supply. The valve connected to your cold water pipe may be obstructed. Next, does there seem to be any sounds comming from the icemaker? Also check to see if the lever that controls the amount of ice is stuck all the way up. If this is the case simply push the lever down. Generaly, ther are not many serviceable parts in the ice maker. A bad timer might also be the culprit.
Aug 20, 2009 | Refrigerators
Frigidaire ice maker not working
The first step you need to do is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board. If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker. You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Thank you for contacting Fixya.com
Aug 11, 2009 | Frigidaire FRS6R5EMB Side by Side...
Did a cleaning cycle and afterwards turned the unit on, however when the on cycle is depressed the cleaning light comes on and it begins to both make ice and clean. The condencer runs but not enougth water...
manually drop hot water inside the freezer area, the freezer area have a little hole with a pipe laying to the tray down. as for as i concern the drainage pipe is closed due to ice. but if u drop hot water inside the freezer area it will unblock the pipe. and the friedge will work better then before..
good luck
shafky
Jun 19, 2009 | GE Monogram ZDI15C Automatic Icemaker
Ice Maker
Check the back of the icemaker & verify that the icemaker was plugged in. Check that icemaker is turned on. Check that the water supply was not turned off. Check the water supply tube at the icemaker for ice blockage if the water supply is blocked cleared the ice away. IF Ok with both items checked. Then pull the plug on the refrigerator for about a minute, so that it can reset itself. If you still have no ice within the next twelve hours then the problem will either be with the inlet water valve or the icemaker itself. However, I really doubt that since it worked prior to service. I'm pretty sure it has to do with the first steps mentioned. Hope this helps. Please post your findings
May 05, 2009 | Frigidaire FRS26ZSG
Frigidaire FRS26ZRGW8 ice maker stopped working
on your icemaker you can tell if its a internal problem or a water valve ,,,,, 1st feel inside for any ice ,,, if ice is in icemaker the valve is working ,,, pull fingers on icemaker to get it started and watch it, if it makes its cycle and fills again the the icemaker itself is bad ,,, contact me and i will see if i can help with part or parts / larry
Dec 08, 2008 | Frigidaire FRS26R4A Side by Side...
Frigidaire Icemaker not making ice.
That on/off arm...you should be able to move it and it will likely make a small click when the switch goes on or off. That arm controls the ice making. There is also a float, is it working freely? It has a switch too. Ultimately, the water is controlled by a solenoid valve. It may be defective. Many of these units are removable to test the switches with a multimeter. Turn off the water and remove to test. Some parts are available...some parts are by the unit only.
Dec 24, 2007 | Frigidaire FRS23KF7AB Side by Side...
Frigidaire FRS23KF7AB Side by Side Refrigerator Logo
291 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
