Question about True GDM-72 Refrigerator
Where do i find the starters for the florescent lights on a true gdm-72
  • adamsaire May 11, 2010
    The ballasts(starters) should be under the front access cover below the doors. After removing the front cover there may be another small covered box where they may be located.
    Scholar:
  • 79 Answers
They should be located under the front access cover below the door. Under that cover there may be another smaller covered box that they may be located in.Make sure you disconnect the power source before removing any covers.
Posted on Nov 12, 2009
Why gdm 72f cap tubes
That freezer is meant to have a stable load an example is storage. A supermarket application would require a tx valve.
Apr 28, 2014 | True 72 cu. ft. / 2039 liter Commercial...
Replace gdm capillary tubes
Shouldn't normally need replacing. Reclaim the gas, cut the capillary end at the drier, and force dry nitrogen thrugh the suction side to clear any blockage in the capillary. Fit a new drier, braze the capillary end and vacuum the system before regassing
Apr 26, 2014 | True GDM-72-RC Refrigerator
How to put hardstart kit in compressor GDM-72
depends if it is only a two wire hard start.. then wire it parelel with the run capacitor . place line to line and load to load . load goes to compressor and line to power which is usualy realy the neutral for a 120v compressor since the hot runs to a overload and straight to the compressor
Sep 13, 2013 | True 72 cu. ft. / 2039 liter Commercial...
Where are the Freon nodules for a True GDM-72 cooler?
SEALED SYSTEM REPLACING COMPRESSOR ON COMMERCIAL FREEZER
Aug 08, 2013 | True 72 cu. ft. / 2039 liter Commercial...
True 3 door refrigerator model#GDM-72 door does not self close
hi, I lost a part of the true cooler model gdm-72 door part that let the door side itself to close
Nov 01, 2012 | True Refrigerators
True gdm 72 goes below 20 degrees
Usually a blocked condenser fooling the thermostat into running overtime. Possibly thermostat fault but less likely
Apr 14, 2012 | True 72 cu. ft. / 2039 liter Commercial...
True GDM-72f freezer Fans don't start
Thermo fuse has failed on the core plate, tells the freezer its cold enough to start blowing air, you can bypass it but not recommended. hope that helps, Russ
Jun 11, 2011 | True 72 cu. ft. / 2039 liter Commercial...
I like the wire diagram from 3 door freezer swich to lights inside
http://www.truemfg.com/index_en.aspx?language_id=1&event_id=401
Go to "Support" and then do the "Ask the True service Dept." They will need your model and serial numbers and they will send it to you.
Jan 11, 2010 | True 72 cu. ft. / 2039 liter Commercial...
GDM-49
http://www.truemfg.com/pdf/InstallManuals/GDM/gdm_english.pdf
Go to the above web site. It should be the installation manual for your unit. It has lots of good stuff.
Hope this helps
Nov 13, 2009 | True 49 cu. ft. / 1388 liter Commercial...
Interior Lighting on True Refrigerator Unit
A starter may be located in the top area inside the cooler. Not all true coolers have starters. Check the connections where the light pins slide into. Also may need new ballast.
Jul 24, 2008 | True GDM-9 Beverage Cooler
True GDM-72 Refrigerator Logo
145 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
christian nielsen
Are you a True Refrigerator Expert? Answer questions, earn points and help others
