Question about Acer DX900 Smartphone
Phone 2 no service.. even if there is signal.. i tried other sim.. my phone 2 still cannot locate any signal...
Sgh-d407 no signal
Samsung SGH-D407 Flip Phone: No signal
Hello. It's possible that your cellular service area that you are located in, has low and limited connection available..
Call your service provider on a different phone to let them know that you are not getting service in all the areas you've tried. Indicate how far away from each location that you are unable to get signal from. If you can not get signal anywhere at all, this should also be addressed. They may even walk you through resetting your APN settings
In some cases, it could just be the building that you are located in that is blocking cellular service.
Sometimes, it could be a fault of the service provider. They may need to reset your connection on their side. If not, at least you can get them to try..
Other things you can do:
1) On your device: Make sure that your SIM card is perfectly sitting in its tray and on the connectors..
2) On your device: Make sure that your mobile cellular connection is enabled
3) On your device: Make sure that airplane mode is not enabled
Jan 27, 2016 | Samsung Cell Phones
No service detection
Try down powering mobile completely and turn it back on. Is it all the time or just in one location. Could be no coverage or shielded location.
Oct 29, 2014 | Cell Phones
Insert sim card is found in low signal
First:
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Second:
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Jan 12, 2013 | Samsung GT C5130 Mobile
Why I don't have network signal on my nokia 6600?
If you are not getting any network from your phone it my be be due to:* sim card issues* network / outage issues* phone issues
SIM Card issues:1. turn off mobile phone2. remove battery3. remove SIM card and memory card4. clean the SIM card from any dirt or dust5. wait for 2 minutes then plug back battery6. insert memory card and SIM card properly7. turn on mobile phone8. check if you will be provided with a signal from the upper right corner of your phone's screen. if not, try a different SIM card.
Outage:1. call your service provider and confirm if there are outages in the area or outages from the BTS where your SIM card is registered.
Phone Issues:1. if the phone is open line, try to enter a different SIM card2. try to insert the SIM card into a different phone, check if it will be provided with a signal3. if the second phone still dont get any signal and your service provider stated that there is no outage that may affect signal issues from your phone, check it from them if your sim card is still active.4. last resort is asking for a SIM replacement with the same phone number
Dec 11, 2011 | Nokia 6600
How to switch from offline to online
Offline mode only appears if the mobile phone is not getting the signal from its service provider.
*make sure that the sim is properly connected*reseat the sim card from the mobile phone*check account status for signal and connection availability*power cycle mobile phone
1. turn off mobile phone2. remove phone battery3. remove memory card4. remove sim card5. wait for 2 minutes before plugging back anything6. after 2 minutes, plug back battery7. insert memory card properly8. insert sim card properly s well, make sure that the sim is not dirty as well9. turn on mobile phone10. check the signal bar, it should be with signal this time and not offline
*after power cycling, phone should be working properly now unless the sim card is really faulty. you check if its faulty by calling your mobile service provider*
Dec 10, 2011 | Nokia E75 Cell Phone
No signal
Try this first
1. try to cover up any part of your phone with your bare hands. Look for a spot where the phone signal gets weaker if you cover a particular area. If that is the case, then you simply need to hold the cellphone in another position. 2.Second, try to change your position or location. There are many factors that affect cellphone signal strength, one of them is the space. If you are inside a closed location, go out and see any improvements in the signal. 3.Third, you can try to detach the SIM card from your phone and turn it off. After 5 minutes, put it back and see if the phone no signal problem is still going on. Or, you can change your SIM card if you have a spare one with another network say Verizon, Smart or At &t. If all these cellphone no signal tricks won't work, then your phone is probably broken. Bring it to a nearest cellphone repair center.
Jan 09, 2011 | Samsung Cell Phones
A-nokia 5130 signal problam
If you're encountering signal problem with Nokia 5130 try pressing the pound sign and press call. Allow at least 2 to 3 minutes to process your signal request. If the problem persist try checking the signal coverage of your network provider your location might be a dead signal zone. If the above steps has already been done and problem still occurs. You have to open the unit and check for the connection of the antenna to the board. The two most be properly connected to receive a high signal.
Oct 30, 2010 | Nokia 5130 Cellular Phone
No signals
go to phone-->operator selection--->manual....select docomo
Oct 05, 2009 | Nokia 5300 Grey Cellular Phone
Samsung sgh-e590 limited service
HI i have same problem with my samsung.
Sep 27, 2009 | Samsung E590 Unlocked GSM Phone
Phone does not get a signal anywhere.
ya ur guss is rite...might be antanna problemm...still i suggest u to restart ur phone without sim once...n again switch off and again switch it with sim card...
if u had ur phone in water contact??if so then plz contact the sony service center @ the earliest..
dont try to dismantle ur phone...just show to service center...
ne other prob's do tell me..N plz do rate me
cya
Apr 15, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Acer DX900 Smartphone Logo
79 people viewed this question
Top Acer Cell Phones Experts
Computer Repairing
Computer Repairing
Thomas Perkins
Thomas Perkins
richie46
Are you an Acer Cell Phone Expert? Answer questions, earn points and help others
