Question about Singer 3116 Simple
When my needele comes down its hitting the plate instead of going through the hole to pick up the thread from the bobbin. How can I readjust it?
    Problem Solver:
  • 5 Answers
There should be a screw to release the needle from the arm, it's possible the needle is crooked and the screw is holding it in at a wrong angle. Try removing the needle and then reinstall is making sure if there's a flat edge on the top of the needle that it aligns with the flat side of the entry hole, it may take a flashlight to see if there's any difference on the machine entry hole. If that doesn't work, you may need to try adjusting the plate as well, all of these things can get just a little out of alignment making for trouble. Hope this helps.
Posted on Nov 12, 2009
I can not pick up the thread[string] from under the machine,both the strings on the needle and under the machine should be on top of the table to start sewing
If this is your first time sewing on a machine then:
Once you make sure the needle is threaded and the bobbin is sitting correctly in the bobbin casing, and you have installed and manipulated the thread according to your manufacturers instructions:.
Holding the end of the thread that you threaded through the needle, use the wheel (right hand side of the machine) and rotate it toward you pulling the thread that you are holding gently toward you.
The bobbin thread should give you some restriction and the end of the bobbin thread should have come through the hole in the needle plate (the metal plate that sits under the presser foot on the table of your machine.
Hope this has helped.
Jan 21, 2015 | Sewing Machines
I am using a Juki DDL 8700 thread to tight & not pulling through needle & cactching bottom thread
needle too small or machine out of time. to time machine theres a mark on needle bar. lower needle bar till mark shows and raise bar till even with bar guide. take off feeder plate so u can see needle in relation to hook. when mark on needel bar is even with bar guide the hook should be 1/16 fron passing the needle. if not loosen 3 screws and trial and error it to get it right. use a small screwdriver and tighten just on screw when u hab aglined the hook to needle. do a full rotation and watch where needle is and needle bar mark. needel should be as clost to hook without touching.
Dec 30, 2014 | Juki DDL-8700
How do I change the bobbin in a Janome sewing machine?
There is a small plastic plate where the needle goes down through the foot, remove this cover and you will see the bobbin. Remove the bobbin and refill or selecting another bobbin turn it so that when you pull the thread the bobbin turns anti-clock-wise, slip the bobbin into the black plastic casing, pulling the thread towards the small red arrow at the bottom of the casing, slip the thread between break in the silver metal sleeve pulling it to your left between the 2 pieces of metal this is where the tension on the thread is. You have now changed your bobbin. With the plastic plate still off, hold the top thread with your left hand and with your right slowly turn the wheel, this will send the needle (holding your top thread) down into the bobbin casing and will pick up the bottom thread, pull on the top thread and bring the bottom thread up through the hole in the plate. Replace the plastic plate and recommence sewing. Good luck
Sue
Sep 24, 2014 | Janome Sewing Machines
The needle is hitting the needle plate (and breaking, of course) instead of going through the hole to the bobbin
I am wondering if it could be an issue with the type of needle you put in there. I am having trouble with a sewing machine tension and the store people told me that you have to use the manufacturer/ original style bobbin (it's engineered to fit the gadget 'Just so').
I know on my non-computerized Brother sewing machine, that I can change the needle position to L/M/R and I see it move when I move it left and right.
I guess you've probably checked all of the other settings on your machine?
Is the presser foot coming unscrewed?
Mar 03, 2014 | Brother PE770 Computerized Sewing Machine
Machine just quit picking up bobbin thread and sewing in the material. It is just making holes in the material.
Needs a new needle right way around, most likely. And check the threading on both bobbin and top of the machine. It makes a big difference which way the bobbin turns in the bobbin case.
Needles need to be replaced every 2-8 hours of sewing time, on average, or about 1 needle per garment. A needle that has hit the presser foot or needle plate is "dead", and needs to be replaced to (and eventually, you'll need to buff out the rough spots on the presser foot, and needle plate).
Common causes of skipped stitches (stitching that looks like
_ _______ _ _ _______ _ _____________ instead of _ _ _ _ _ _) or of not picking up the bobbin thread are: dull or damaged needle, needle in backwards, needle not fully up in the needle clamp, needle too small a size for the thickness of fabric, dirty machine, misthreaded machine, and way, way, way down on the list, machine out of time.
Jan 14, 2014 | Singer Sewing Machines
How to get the thread from the bobbin through the needle plate slot?
hi.
http://www.singerco.com/uploads/download/498_4205_4210.pdf this is the link for the singer website manual download for your machine. full instructions for threading teh machine start at page 30.
basically you thread the topend and needle, place the bobbin in the holder with a few inches of thread under the needle plate, and when you start the machine the needle comes down and picks up the bobbin thread and takes it back up through the hole in the needle plate.
i can recommend reading the full manual, as there are a lot of little tips on how to get the best out of your machine.
hope this helps.
Jul 12, 2011 | Singer Inspiration 4210 Mechanical Sewing...
I have a Confidence 7470 purchased in May 2009. I was sewing tulle today and the thread kept snapping while sewing. I assumed it was catching in the tulle. The last time it snapped, the thread jammed in...
Sounds like your machine is off timing, When the machine is properly timed, you should see the hook passing behind the eye of the needle when the needle is on it's upward stroke. If this is not correct the machine will not pick up the bobbin thread. You may have to take it in for adjusting, unless your a bit machnical.
May 11, 2011 | SINGER 7470 Sewing Machine
How to get bobbin thread to come through to the top
On a front loading bobbin the thread must be going over the top to the right clockwise and hanging down. Then take the bobbin case holding it so that the finger like thing is pointing up. Place your bobbin in the case and pull the thread up through the **** on the side until it snaps into the little hole at the top of the ****. Now turn the case around holding on the flat metal flap and wiggle the case in the bobbin case holder in the front of the machine with the finger still straight up and push gently until you hear it snap in place. Turn the hand wheel one complete turn holding the top thread under the presser foot to the left and you will see the thread going down to pick up the bobbin thread. If you have done the correctly and it still isn't picking up the thread then it is most likely a timing problem and should be fixed by a repairman. They have to line everything back up so that the hook on the bobbin case realigns with the needle so the stitches will lock. Usually when the fabric has been pulled too hard bending the needle or it hits the needle plate and gets out of alignment or someone runs over pins while sewing this causes the timing to be off. I hope I have answered your question. It's probably not anything you are doing wrong and was probably done before you got the machine. Let me know what happens or if you need any more help.
Sep 20, 2010 | Euro-Pro 473
How do you thread thre bottom bobbin on a singer 533?
Drop the bobbin in, holding the the of the thread between your left hand fingers, making sure the bobbin will turn clockwise as you pull on the thread, manually turn the wheel to make the needle go down and up again, as it comes up it will bring the bobbin thread up through the plate hole. There you are, close the plate, good sewing
Aug 10, 2010 | Singer Drop-In Bobbin 758B-28BH Mechanical...
Bobbin holder seems to be broke and needle breaks
Here are several things to try.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
If there doesn’t seem to be a problem with your needle, try the following:
* Check your pressure foot and make sure it’s attached securely.
* Change your pressure foot Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins a needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew. You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate and make sure it's securely in position.
* Change your needle plate. If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle – right, left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin. There could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
Also, before you start to sew a seam, hold the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope these solutions help you.
Sep 20, 2009 | Brother XL-2230 Mechanical Sewing Machine
Singer 3116 Simple Logo
76 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
