Question about Dell PowerEdge 4600 Server
Beeps tengo un servidor dell power edge 4600 que esta emitiendo pitidos por problemas de un disco fallado (RAID) no tengo instalado el software Dell OpenManage ?como lo desactivo fisicamente para que no emita pitidos
4 Suggested Answers
nblady
  • 206 Answers
SOURCE: Quitar Password de Bios de Pc Dell Optiplex GX100,
Hope you can read this. if not, GOOGLE...TRANSLATE.
Removing the PSWD jumper is the correct method of clearing the BIOS password. Removing the battery resets the CMOS.
Remove the power from your computer. Remove the battery. Remove the PSWD jumper. Wait!!!!
Keep power off the computer for at least 30 minutes, overnight is better.
Replace the battery. Plug the computer in. Do Not Reconnect the PSWD jumper.
Now reinstall your operating system and drivers. When finished, restart your system. If everything works and you want to redo the BIOS password, shut the computer down. Unplug the power. Remove the battery. WAIT.
Replace the PSWD jumper. Replace the battery. Plug in the power. Restart the computer, hitting "F2" as it starts....to open the BIOS setup page. Reset your password here. Esc to continue, Yes to save.
Good luck
Posted on Feb 24, 2010
Mikenet2620
  • 106 Answers
SOURCE: No puedo instalar Small Business
Si el sistema operativo no reconoce tus disco, y ya has creado un arreglo nivel 1 o 5 y en la bios si puedes ver los dicos, el problema es posiblemente que necesites cargar los drivers de la controladora. Si puedes ver el modelo de la controladora (visible en el post) dirigete a la pagina de hp.com/support escoje el pais USA para que tengas acceso a todos los drivers, descargate el ultimo driver de tu controladora y cuando este instalando windows presiona f6 para cargar los drivers
Posted on Aug 30, 2010
josema_sv
  • 512 Answers
SOURCE: mi servidor power edge 2600
Hola, efectivamente hay una falla del ventilador, el LED naranja lo confirma, lo mas probable es que sea necesario reemplazarlo.
Posted on Mar 02, 2011
No funciona bien mi computadora de mesa
Primero verifique para ver si puede arrancar en modo seguro presionando F8 varias veces justo cuando se inicia el equipo hasta que el menu de inicio aparece. Cuando el menu de inicio aparece seleccionar "modo seguro con funciones de red". Si puede arrancar todo el camino hasta en el modo seguro, entonces usted tiene un problema de controladores. Lo mas probable es que usted tendra que instalar la tarjeta de video o los controladores del chipset de modo seguro.
Buena suerte!
Jun 11, 2012 | HP Computers & Internet
Crystal eye aspire5732zg
ir a la pagina de acer suport y reinstalar los drivers, si se trata de problemas software, es caso de que la camara no funcione y los drivers estan instalados, sera nesesario cambiar esta. si tu computadora no funciona bien pues reconectala con recovery ****, esto es un disco que haces despues de instalar la computadora por primera vez, si no lo has hecho aun, puedes hacerlo con acer recovery manager y clickear encrear disco de recuperacion, si tu OS desaparecio, aparecera una nota en la pantalla negra que dice NO BOOT, o BOOTMGR Missing, en este caso solo te queda llevarlo a los tecnicos de acer para que reinstalen el OS + los dryvers de acer, Ahora esto acurre cuando el HDD esta defectuoso o se ha quemado; espero que te sirvan los hints
Nov 13, 2011 | Acer Aspire One PC Notebook
Compre una imac m6498 pero cuando la prendes aparese una carpetita con una carita seguida de otra con un signo de interrogacion que puedo aser para que funcione
Normalmente el simbolo que mensionas sale caundo el sistema no purde encontrar el disco duro. Pera verificar si es el disco duro que esta fallando o no, completamente apages la computadora. Oprime el boton de poder e imediatamente oprime el boton "Option" y mantenga la tecla selecionada. Esto le senala al sistema que quieres ver todas las seleciones para butiar. El sistema debe mostrar un imagen del disco duro si no esta fallado. Si lo ensena, puedes selecionar el disco duro con el mouse o usando las teclas de direciony oprimes el buton "Return" or "Enter".
Si ningun imagen aparece o mas importante, si no muestra el imagen del disco duro, eso indica que el disco duro ha fallado y necesesitara re-emplaso. El sistem de OS X necesitara ser re-instalado con todos sus aplicaciones tambien.
Jul 18, 2011 | Apple iMac G4 Desktop
Tengo una impresora brother dcp 130c me da error 43 me pueden ayudar
Aqu? est? una lista de art?culos que pueden estar causando el problema 1. Hay un conflicto dedispositivos en el equipo que la impresora deja de funcionar despu?s de un per?odo de tiempo determinado. Esto se conoce como un conflicto decontrolador de dispositivo 2. El cable detransferencia de datos USB 1.0 y no 2.0 que esto puede causar problemas de transferencia de datos y hacer que el usuario tenga que volver a instalar varias veces 3. Su equipo tiene el softwaremal instalado para HP 4. Por ejemplo, si ha actualizado recientemente a Windows 7 o incluso degradado a Windows XP, elsoftware tendr? que cambiar junto con el sistema operativo. Prueba estas soluciones a cabo antes de determinar si se trata de un problema real conel hardware de la impresora
Jan 23, 2011 | Brother DCP-130C InkJet Printer
Trobleshooting p0073 DIFINICION CIRCUITI ALTO DEL SENSOR DE TEMPERATURA DEL AIRE AMBIENTE AAT EXPLICACION El modulo de control electronico ecm a detectado una condicion de alto voltage en el circuito...
El código P0073 es descrito como el sensor de temperatura del aire ambiente del circuito de entrada de alto. Que consiste en el circuito del sensor de temperatura del aire exterior.
El sensor esta instalado frente al radiador, detrás de la rejilla. Probablemente el problema es que el sensor ha fallado o que el cableado presente algun corto en el mismo o cables deshilachados. Inspeccione los cables y conectores que lleva a la sonda. También puede hacer referencia a un manual de reparaciones de Jeep Liberty para obtener información específica, pero también se puede utilizar un multímetro digital (medidor digital ohmios voltios) para verificar la ohmios del sensor.
Espero que esto sea de ayuda (recuerde calificar esta respuesta). Buena suerte.
Nov 23, 2010 | 2004 Jeep Liberty
No puedo instalar Small Business Server 2000 en mi servidor HP Proliant DL360 G3, el software no reconoce los discos duros del servidor. Que tengo que hacer para que me reconosca los discos duros?
Aug 29, 2010 | HP Compaq ProLiant DL360 G3 Server
Problemas de transmision automatica
hola que tal, tengo un saab 9000 1988 y tengo problemas con la transmicion aveses me hace los cambios y abeses no, si abansa para atras y para adelante pero me abienta los cambios cada que quiere,,, alguin tiene idea de que pueda ser?? nesesito ayuda ya estoy desesperado...
Aug 02, 2009 | 2001 Hyundai Accent
Notebook Sony Vaio VGN-FJ270
La única manera de hacer esto es hacer una recuperación de sistema en el disco, si se asume que esto fue fijada realmente y funcionamiento. ¿si no, usted tiene un respaldo para estos datos?
Oct 23, 2008 | Sony VAIO VGN-FJ270/B Notebook
Porque mi placa se recalienta tanto donde se encuentra el procesador y la tarjeta de video
Hola te recomiendo un sistema de este tipo, ami me pasaba y con esto se soluciono ese problema http://www.bit-tech.net/hardware/cooling/2012/09/26/thermaltake-water-2-0-performer-pro-reviews/1 9ab6aa7c-9dc3-4642-ab5a-d10391656423.jpg
Oct 01, 2008 | Intel D865GBF Motherboard
Disco duro serial ata
Hola VooDooNOFX
Gracias por la ayuda
No estoy configurando los dos discos duros apartes ni haciendo raid a los dos juntos.
El D.D. de 80 gb IDE ya esta parcicionado y formateado (40 c/u, FAT32), tiene windows xp sp3. Uso teclado PS2.
En el D.D. 250 gb serial ata quiero particionarlo en cuatro partes e instalar windows vista, las otras tres particiones para datos.
Voy a hacer esto: Desconecto el D.D. 80 gb IDE y dejo solo instalado el D.D. serial ata de 250 gb para partionarlo y formatearlo con windows vista; primero sin desactivar la función de raid en la bios y luego desactivandola; que opina.
Sep 16, 2008 | MSI Microstar KT6 Delta (MS-6590)...
Dell PowerEdge 4600 Server Logo
97 people viewed this question
Alun Cox
