Question about Campbell Hausfeld Air Tools & Compressors
Psi won't go higher 25 psi - Campbell Hausfeld Air Tools & Compressors
    Problem Solver:
  • 7 Answers
Sounds like a faulty pressure regulator switch. Or someone has adjusted to nearly nothing. If it has an adjustment screw on the pressure switch, turn it clockwise a little a time. If this doesn't work, I would replace the pressure switch.
Cabinetman54
Posted on Nov 19, 2009
I have a 2003 yamaha ttr 125 i need to know the tire pressure for the front and back stock tires
Depends on how it's loaded and what you are using it for, on or off road and what tyres you have
As a rough guide
On road psi
F= 25-29 ( higher for more load)
R= 29-32 ( higher for more load)
Off road opinions vary according to who you believe
front and rear anywhere between 14 to 25, depends how it handles on the terrain you are on.
Caveat, I don't have a manual, I would double check with a tyre fitter to be sure
May 18, 2014 | Yamaha Motorcycles
Husky 26 gallon air compressor parts
Worn piston/rings, or valving issue. Got a parts book?
Dec 16, 2013 | Air Tools & Compressors
What is the Freon capacity on my 2002 Saturn SC1. It has a 1.9 liters engine, 4 cylinders.
THE ACTUAL FREON CAPACITY IS UNIMPORTANT. WHAT IS IMPORTANT IS THE PRESSURES WHEN THE SYSTEM IS RUNNING. THE LOW SIDE SHOULD BE 25-35 PSI, THE HIGH SIDE APPROX 250 PSI. THE HIGHER THE AMBIENT TEMP, THE HIGHER THE HI SIDE PRESURE. USE PROPER TOOLS TO CORRECTLY EVACUATE AND CHARGE THE SYSTEM. AVOID OVERCHARGING AS TOO MUCH FREON IS WORSE THAN NOT ENOUGH.
Apr 01, 2013 | Cars & Trucks
Mitsubishi delica airco
Sounds like your a/c compressor is worn out. When the internals get sloppy, they won't build pressure.
Oct 02, 2012 | Mitsubishi Cars & Trucks
On my 1996 ss impala what low side pressure should I see on the a/c with the system running
It all depends on the outside (ambient) air temperature. Your A/C low pressure switch is designed to turn the compressor off at 24 Psi. and turn it back on at 45 Psi. Most systems will normally run at between 25 and 40 Psi when the system is running on HIGH blower and "MAX" or "RECIRCULATE". A system that is fully charged may run at 25 Psi when the ambient temperature is 75 Deg. (F) and may run at 40 Psi when the ambient temperature is at 90 Deg. (F). (it can be even higher if ambient temperatures are higher than 90 Degrees.)
To properly diagnose a malfunctioning A/C system, the HIGH side pressure must also be checked. Restrictions in the system can make the low side pressure look normal while the high side pressure is high enough to blow hoses apart. (400+ Psi.)
Sep 04, 2011 | 1996 Chevrolet Impala SS
What should the pressures on the low and high side of the air conditioner read ?
low side should be about 30 psi at idle speed, high side 120 to 180 psi depending on ambient temp. higher temp, = higher pressure, as you increase engine rpm to say 1000 low side should drop to 10 to 15 psi & high side should increase about 30 psi. If high side goes over 280- 300psi you have contamination (air) in system or over charged with refrigerant. you will need to recover freon, evacuate & recharge system with proper amount of refrigerant. If the low side drops below 0psi or into vacuum then the refrigerant level is low, you will have to check for leaks , repair leaks & refill refrigerant.
Hope this helps
Paul T
Jun 01, 2011 | 1997 Chevrolet Suburban
Looking at a 2001 XL800, is there any specific thing I should be looking for, common problems ect.?
Notorious for broken power valves, simple compression check should tell you unless both are broken, if there is a 15 to 25 psi difference between the 2 cyl chances are the one with higher comp is bad. Those valves change the port timing and are controled by the ECM. In short, the higher the EX port the lower the comp and vice versa IE the lower the port the higher the....
Sep 05, 2010 | Yamaha 12V Air Pump
Where is low side of a/c system to cahrge with 134
The low pressure side of the r134a system is always located on the thicker pipes vs. the thinner pipes leading away from the compressor.
So, just followi the larger diameter piping from the compressor until you come to a quick connect fitting that attaches to the hose quick connector that is attached to a can of r134a.
The pressure reading should be 25 psi to 45 psi on the low side when the compressor is turning and the a/c is on.
If it's higher than this, the compressor may not be turning, and the normal non turning psi is 75psi to 100 psi or so on a hot day.
Aug 26, 2010 | 1999 Jeep Grand Cherokee
Air Tools & Compressors Logo
57 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
