Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
I only think its the color wheel on my samsung dlp hls4666W because different colors keep resonating and put out a glare or glow.
    Sergeant:
    Champion:
  • 257 Answers
It is not the color wheel problem, it may cause by digital board. Once the color wheel has problem, TV will turn on/off 3 times and then shutdown. Hope it useful for you.
Posted on Nov 12, 2009
Samsung DLP R&R Color wheel Model #HLR5078w
Samsung's digital light projection (DLP) televisions use a spinning color wheel to create the colors that are seen on the screen. If the color wheel becomes misaligned during use, it will become damaged and have to be replaced. Replacing the color wheel on a Samsung DLP television can be done at home, once a compatible-sized color wheel has been bought from a TV supply store.Replacing the color wheel yourself will void any Samsung warranty that might be in place, but is the only solution for getting the TV working again in as short a time as possible.
Put on the anti-static grounding strap to keep static electricity from damaging the internal components of the Samsung DLP TV. Turn the Samsung around so that the back is facing you. Make sure the Samsung is unplugged from the AC socket.
Use the Phillips screwdriver to remove all of the screws from the back panel. Put the screws aside. Pull off the back panel.
Loosen the two screws from each side of the projection bulb's case. Pull the projection bulb out. Put the projection bulb aside. Use the Phillips screwdriver to remove the two screws from the left side panel. Pull the side panel and the circuit board attached to it out carefully and put it down so that the cables attached to it have not been pulled out.
Take a picture of the power cable's position with the digital camera so that you can put it back correctly later. Pull the power cable out from inside of the Samsung's case so that the center panel is free to be pulled out. Remove the two large headed screws from the center panel with the Phillips screwdriver. Remove the top two screws holding the panel to the plastic case using the Phillips screwdriver.
5
Slowly slide the center unit out a few inches. Take a picture of the projector lens' positioning with the digital camera so that you can put it back correctly later. Unplug the two cables from the left side of the center panel. Unscrew the sensor switch using the Phillips screwdriver. Slide the center panel completely out of the Samsung and put it down on the clean cloth. Blow off the color wheel assembly with the compressed air.
6
Use the tweezers to remove the green plug from the top of the color wheel cover. Use the tweezers to remove the two cables at the side that are coming from the color wheel. Use the Phillips jeweler's screwdriver to remove the screws from the top, front and back of the color wheel cover. Slide the color wheel cover straight up to expose the color wheel.
7
Use the Phillips screwdriver to remove the three screws holding the color wheel to the color wheel assembly. Lift the color wheel up and out of the color wheel assembly and discard it.
8
Position the replacement color wheel in the color wheel assembly. Reassemble the color wheel and reassemble the color wheel assembly. Put the color wheel assembly back into position in the rear of the Samsung DLP TV. Reassemble the Samsung DLP TV. Plug the Samsung DLP TV back in for power. Turn the Samsung on and enjoy seeing the colors displayed properly again now that you have replaced the color wheel.
May 02, 2010 | Samsung HLR5064W DLP Projection TV
My Samsung 56 DLP picture lost is color and is making a buzzing noise which I suspect is the color wheel. The picture is now black
you need to change the color wheel
5
6
7
8
Feb 07, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Rattling sound from the Samsung DLP TV
Your Color Wheel is bad and needs to be replaced by a trained Samsung tech. There are adjustments that must be made after the color wheel is replaced. Part# is BP96-01579A
Jul 15, 2009 | Samsung HL-S5087W DLP TV
How do I change the color wheel on my samsung HL-P5663W. I have already removed the lamp and loosened screws for the lamp housing. Doesn't seem to want to come apart. Am I on the right track?
5
6
7
8
Jul 10, 2009 | Samsung DLP HL-P5663W 56" TV
No color and flashing screen on DLP
Jenn
I have the same problem, do you think it is the color wheel
Thanks Joe
Jul 02, 2009 | Samsung DLP HL-P5663W 56" TV
Color wheel for Samsung HLR5688WX DLP TV
5
6
7
8
Jun 30, 2009 | Samsung HLR5688W 56" Rear Projection HDTV
Buzzing noise on Samsung HL-R5667W DLP
You have a noisey color wheel. It is a little tricky to replace but not too bad. Also, there are several different versions of these for different models so be sure you use complete model number from sticker on side of set. Must remove light engine and will need extra long philips screwdriver (magnetic). That is to get color wheel cover off/on. When switching ribbon cable, notice it only has contacts on one side so make sure to put new one in same way. Good luck, Russmann.
Apr 20, 2008 | Samsung HLR5667W 56" Rear Projection HDTV
SAMSUNG HL-P4663W 46" DLP COLOR WHEEL PROBLEM
Hi...No need for a different jumper or different color wheel. It's an easy fix. Make sure your TV is turned off and remove the jumper with a pair of needle nose pliers. Just keep it in case you may need it in the future. I will post a picture to show you where the jumper is located.
Apr 09, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung DLP HL-R5667W
Color Wheel problem.. to generate colors on a dlp the light is shine through a motorized wheel. that has different color filters on it. this is a motor and anthing that moves will eventally wear out. i just replaced the color wheel on a samsung today. standard for this to go out in about that time. i believed our shop charged 250 to put a new one in. Willie@FORDTV.COM
Sep 23, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
85 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
