Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
Have lost key and need to replace right side bulb on wurlitzer 1015 cd one more time
  • Wurlitzer Expert
  • 567 Answers
Join jukeboxworld they have all your requirements great site
Posted on May 08, 2010
    Scholar:
  • 195 Answers
If the lock is a standard lock for the model of your jukebox then you should be able to get a replacement from the distributor.
Look on the back of the jukebox for a serial number plate. This will tell you the manufacturer and the model number etc. The jukebox could be a Wurlitzer, Rowe Ami, Rock Ola or Antique Apperatus.
Once the details are known you could get a key from www.victoryglass.com in the USA.
Regards
Alan Hood
ami-man
UK
Posted on Nov 17, 2009
How do I replace the column GE tubes on a 1015 Wurlitzer?
HI,
Here i have added picture of Wurlitzer 1015 rear side picture. from this picture you can identify which side you have to remove to see the tubes. In th picture you can see the tubes. two out put tubes. one rectifier and two pre amp tubes(black).
Wurlitzer 1015
Jul 24, 2012 | Wurlitzer Jukebox 1015 One More Time...
I have a used wurlitzer omt how do i find out the age of this machine
How do you know it is the top left bulb and not the top right bulb? The arch lights work as a pair. If one goes out they both go out.
Feb 13, 2012 | Wurlitzer Jukebox 1015 One More Time...
I need a glass bubbler tube for the lower left hand side of a wurlitzer one more time #1015 where can I buy these and how do you install them.
I stock all parts for the Wurlitzer One More Time machines. I have the bubble tubes in stock, with installation instructions. Please contact tech@wurlitzer-ohio.com.
Sep 16, 2011 | Wurlitzer Jukebox 1015 One More Time...
My wurlitzer 1015 cd jukebok carosel continually
There's a little light like a torch bulb light called the "light gate lamp" which you should be able to see shining at 6 oclock on the edge of the record carousel. It is on the lip where the serated toothed edge of the carousel passes through a small upright bracket. If you can't see it shining then that's your problem. Have a look in the original documentation and it shows a diagram how to change it.
Dave.
May 22, 2010 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 1015 CD 50 disk - florescent bulbs change
You have to rotate the tube 90 degrees until you hear a click, then it pulls straight out of the sockets at the top and bottom (towards you). In order to grip the tube Wurlitzer put a black plastic cap on the end of the tubes with a bit sticking out for you to get hold of. On models where the colour cylinder is flexable you can actually squeeze it in the middle and grab the tube that way.
Dave.
Nov 02, 2008 | Wurlitzer Jukebox 1015 One More Time...
Problems with Wurlitzer Jukebox 1015 One More Time key will not turn to open the front of the unit
I had the same problem due to the weight of the door, my solution was simple, as you turn the key gently push the door with your knee to relieve the pressure on the lock, simple but it worked.
Jul 31, 2008 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 1015 problem
Most likely the main fuse inside the wurlitzer itself - situated screwed into the lower right hand side of the amplifier panel.
Aug 16, 2007 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
214 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
John Robertson
John Robertson
Level 1 Expert
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
