Question about Kenmore 23012 Top Load Washer
Won't spin in rinse cycle - Kenmore 23012 Top Load Washer
  • 5,911 Answers
Check your lid switch. If the washer fills and agitates, but stops at the rinse cycle, or, if the washer fills, then stops and will NOT drain, this is a common symptom of a lid switch malfunction. The following link explains how to access and/or replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
A replacement lid switch (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price is about $20 - $30. Prices differ between these sites, so shop around for the best price.
This is a very simple repair, but if you have questions, please let me know. I hope this helps you.
NOTE: You do not need to drain the washer to replace the switch.
Posted on Nov 12, 2009
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Rinse and spin cycle keeps repeating at 11 minute time to 17 minute time and won't stop
Sounds like your washer does not empty enough water for the spinning to stop. Have you check that the filter(s) are not clogged?
Jan 23, 2013 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
My washer won't spin when its on rinse cycle
What is the complete model number of your unit?
Dec 05, 2012 | Kenmore 43142 Front Load Washer
Frigidaire FWT647GHSO when it gets to rinse first rinse cycle, it doesn't stop filling with water. It won't agitate or spin. It works well in the wash cycle, agitates and spins and advances
probably you've got something blocking the water pump from doing its job properly so check that the water pump is free running emptying all the water if not then there is a blockage in the pump normally ist a button, paper clip or other debris out of a trouser pocket eric
Dec 25, 2017 | Frigidaire Washing Machines
Washer won't spin after rinse cycle
Hello Dorothy - Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose.
Sep 29, 2012 | Frigidaire FEX831CS Top Load Stacked...
Final spin /rinse cycle won"t stop
It's usually a control board problem. sorry for the bad news :(
Jul 07, 2009 | Maytag EPIC MFW9700S Front Load Washer
Maytag neptune won;t rinse
Check latch mechanism for alignment. Often operation of machine loosens latch mechanism causing internal switch for "door open (or ajar)" preventing rinse or spin cycle. Opening and closing door presses latch mechanism closing internal switch allowing for continue processing to rinse or spin cycles.
Mar 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Kenmore 23012 Top Load Washer Logo
80 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
