A bit represents how many digits in binary code . i want to know how many digits are in a binary code .
  • 33 Answers
1 digit is one bit, either 1 or zero in binary, so 8 bits shows 8 digits (10001011)
Posted on Nov 12, 2009
Why there is 1024 bites in 1kilo bite... ?
because it is derived from binary base system and the data in the memory chip is either 0 or 1 for each bit. The memory is actually bytes this depends on the data bus used 8 bits = 1 byte on an 8 bit data bus. 16 bits - 1 byte on a 16 bit memory data bus.
each lot of bits being bytes sits at an address. So 1 kilo byte of memory is stored in 1024 memory addresses. this uses 10 address lines. If you add one more address line 2^11 you get 2048 memory stores . As the 11 th bit can be 1 or 0 but allows access to another 1024 memory addresses.
  • 2 ^0 =1
  • 2^1 =2
  • 2^2 = 4
  • 2^3 = 8
  • 2^4 = 16
  • 2^5 =32
  • 2^6 = 64
  • 2^7 =128
  • 2^8 =256
  • 2^9 =512
  • 2^10 = 1024 = 1 kb
Feb 17, 2016 | Cars & Trucks
Tip
The Fisher & Paykel Smart Drive and EcoSmart electronic washing machines are...
The Fisher & Paykel Smart Drive and EcoSmart electronic washing machines are equipped with fault detecting software to help easily determine the cause whenever a problem occurs. Not like other electronic washing machines, these ones do not have displays to flash the code, but rather use the eight (8) light-emitting diodes (LED) of the Wash Progress indicators to indicate the fault code. The eight (8) LEDs stands as an 8-bit binary number (zeroes and ones) that must be decoded and then converted to the decimal number system to get the fault code.
The fault code can be decoded by determining which Wash Progress LEDs are lit. Once determined which of the LEDs are lit, write down the 8-bit binary code; 1 for lit LEDs and 0 for the off ones. For example; the final wash, rinse, and spin LEDs are lit; the binary code is 00001101. This in turn can be converted to the decimal number system by multiplying each digit with its corresponding place value then adding up the result. From left to right, the place values are 128, 64, 32, 16, 8, 4 , 2, and 1 respectively. Therefore, the decimal equivalent of 00001101 is 128(0) + 64(0) + 32(0) + 16(0) + 8(1) + 4(1) + 2(0) + 1(1) = 8 + 4 + 1 = 13; the fault code is 13.
on Apr 17, 2010 | Electrical Supplies
Tip
Decoding Fisher & Paykel Electronic Washing Machine Fault Codes
The Fisher & Paykel Smart Drive and EcoSmart electronic washing machines are equipped with fault detecting software to help easily determine the cause whenever a problem occurs. Not like other electronic washing machines, these ones do not have displays to flash the code, but rather use the eight (8) light-emitting diodes (LED) of the Wash Progress indicators to indicate the fault code. The eight (8) LEDs stand as an 8-bit binary number (zeroes and ones) that must be decoded and then converted to the decimal number system to get the fault code.
The fault code can be decoded by determining which Wash Progress LEDs are lit. Once determined which of the LEDs are lit, write down the 8-bit binary code; 1 for lit LEDs and 0 for the off ones. For example; the final wash, rinse, and spin LEDs are lit; the binary code is 00001101. This in turn can be converted to the decimal number system by multiplying each digit with its corresponding place value then adding up the result. From left to right, the place values are 128, 64, 32, 16, 8, 4, 2, and 1 respectively. Therefore, the decimal equivalent of 00001101 is 128(0) + 64(0) + 32(0) + 16(0) + 8(1) + 4(1) + 2(0) + 1(1) = 8 + 4 + 1 = 13; the fault code is 13 which is a pump fault.
Once the code is determined, search the web for the meaning and indicate it when requesting for an online assistance to facilitate a quick and precise response.
on Apr 14, 2010 | Fisher and Paykel GWL11 Top Load Washer
Explain how to convert the binary number 01101 into decimal and convert it into decimal.
the binary system are made only for ones and zeros, when you try to "add one digit" in the binary system, you must add an 1 in the right-sided zero of the binary code, that means that when you want to count up in binary, it should be:
00000 = zero
00001 = one
00010 = two
00011 = three
00100 = four
00101 = five
and so on.
to go up to next number you must add a "1" in the place close more to the right, once this digit has reached its two states (binary= first 0 then 1) the same process occurs in the next digit , but it only rise from zero to one once the right one has reached its two binary states.
the binary digit 01101 stand for: 13 (decimal)
Mar 04, 2015 | Office Equipment & Supplies
Ps3 router connect
a bit is a computer term which can be either 1 or zero. so a 40 bit password would be something like 1100011000011101100110010100101011001010 or any other combination of 40 1's and 0's.. familiarity with Binary numbers would help here.. not easy to remember though.
Hexadecimal is another method used to help simplify binary notation and we use the digits 0-9 and the letters A-F to represent a grouping of 4 binary digits or 4 bits. so the 40 digit string above could be represented as 10 Hexadecimal digits as follows
C61D99499ACA - which is a little easier to remember. ASCII is a standard by which we use 8 bits ( 8 binary digits or 2 hexadecimal digits ) to represent the numbers, letters and symbols on our keyboard... using a 5 letter password such as Bird? ( including the question mark) would be the equivalent of the following hexadecimal representation
42 69 72 64 3F or the binary/bit representation
0100001001101001011100100110010000111111
Hope this helps.
Nov 23, 2013 | EnGenius EUB9707 Wireless N Mini USB...
How to convert octal numbers into binary numbers
Each octal digit represents three binary digits. Simply convert each octal digit to three binary digits and string them together.
0o = 000b
1o = 001b
2o = 010b
3o = 011b
4o = 100b
5o = 101b
6o = 110b
7o = 111b
As an example, to convert 351o to binary:
3o is 011b
5o is 101b
1o is 001b
so 351o is 011101001b
Sep 12, 2013 | Audio Players & Recorders
How to convert binary with point to decimal
1) Look at the following numbers before trying to convert binary to decimal. Each of them represent the value in a binary number from left to right.
128-64-32-16-8-4-2-1
2) Look at your binary number, for this example lets use 10010010. For each one add the corresponding number from step 1, the number you come out with is the conversion.
So: 10010010 -> 128+16+2 -> 146
10010010 = 146
Jul 03, 2011 | Office Equipment & Supplies
Fault code 131 and 132 on bmw e46
EGR valve (Incorrect signal)
131 CAN time out (instr
2)
Input binary
stream bit data (0-
12V)
CAN message between DME/EGS
not received within expected time.
132 CAN time out (instr
3)
Input binary
stream bit data (0-
12V)
Nov 26, 2010 | BMW 323 Cars & Trucks
What is the binary representation of the decimal value 22?
binary is a real cool way to record numerical values
for future reference, a binary sequence represents multiple values being added to produce the total.nthe value of each unit is dependent on its location in reference to the farthest figure to the right.
EX:"011010" means "0+16+8+0+2+0"
so 22 would be "10110" in binary code (16+0+4+2+0)
Please rate this post as fixya!!!!
Mar 23, 2010 | RAD Data Communications RAD WEB RANger-II...
Java code for adding octal, hexadecimal subtracting binary,
Hello desireejane,
One method is to do the following
  1. Convert the octal, hexadecimal or binary to decimal.
  2. Add or Subtract the decimal normally
  3. Convert the result back to octal, hexadecimal or binary.
  • Convert the octal to decimal:
public static long octalToDecimal(String octal) throws NumberFormatException {
// Initialize result to 0
long res = 0;
// Do not continue on an empty string
if (octal.isEmpty()) {
throw new NumberFormatException("Empty string is not an octal number");
// Consider each digit in the string
for (int i = 0; i < octal.length(); i++) {
// Get the nth char from the right (first = 0)
char n = octal.charAt(octal.length() - (i+1));
int f = (int) n - 48;
// Check if it's a valid bit
if (f < 0 || f > 7) {
// And if not, die horribly
throw new NumberFormatException("Not an octal number");
} else {
// Only add the value if it's a 1
res
+= f*Math.round(Math.pow(2.0, (3*i)));
return res;
Mar 24, 2009 | Sun Java Programming Language (cdj-275)
Televison & Video Logo
97 people viewed this question
Top Televison & Video Experts
Electro Med Services...
