Question about Yamaha DSP-A1 Receiver
DSP-A1 SCREEN DISPLAY LIGHTS ,ALL GO OFF,LEAVING IT IMPOSSIBLE TO ASCERTAIN WHAT SETTINGS OR WHAT PROGRAM IM AT. LIGHTS ALL COME ON FOR ABOUT 3-5 MINS ,AT STARTUP,AND AMP. ALL WORKS FINE OTHERWISE EVEN WITH ALL LIGHTS OFF.
  • brew1 Feb 17, 2008
    Bought my DSP-A1 about 7 years ago and over the last 6 months the lighting problem has progressively gotten worse. First just one of the letters for the sound mode was not lighting up, then it progressed over the last month to the entire lighting going off after a few minutes. Everything else functions just fine.
    With the exception of the lighting problem, this baby is built like a brick $hithouse and has never given me any grief, other than wrestling it into the entertainment center shelf and making sure it has adequate ventelation since this puppy really throws out the heat.
    Mark Richfield WI 16 FEB 2008
  • rodney27 May 07, 2009
    hi, i had the same problem, some soldering and all is ok, however my main channels are playing low, any solutions
Over the years the solder joints on the display panel become bad due to the heat that the display puts out. The way to rectify this take the cover off and dis-assemble enough to get to the display. Then using a soldering iron re-solder all of the joints on the board. You should be able to see the joints that are bad as they will wiggle. If you are un-comfortable soldering then try to find someone that is. There is a your tube video on doing this as I learned tonight. I have not done this procedure yet, but I have had the same problem for over 2 years. The display does not even work any more. Now that I have learned what the problem is I will be doing this when I feel like unhooking everything.
Posted on Mar 02, 2008
Can i connect a powered subwoofer to center channel pre-out connection inYamaha DSP-A1
Jun 14, 2012 | Yamaha DSP-A1 Receiver
My DSP-A1 display screen quit lighting up. Everything else works fine-just no screen. Can it be fixed?
I had the same problem and it turned out to be the solder joints on the display panel. If you are reasonably handy at electrical stuff and have a fine tipped solder iron then you should be able to repair that problem. It took me about 10 minutes to get the display unit into a position where I could take a look at the joints. Then about 20 minutes to carefully re-solder each joint. It did however take me a while to remember how to put it back together so I'd recommend a slower disassemble and some note taking.
Aug 17, 2010 | Yamaha DSP-A1 Receiver
Can you help me connect my Yamaha hi-fi system? I want to connect my Yamaha ampliier DSP A1 to my Yamaha equalizer 630 but I don't how to.
Your EQ will be connected to the amp via one of the Tape loops. Connect rec out from the EQ to play in on the A1 Tape input,and rec out from the A1 to play in on the EQ. Then select Tape Monitor on the A1 to hear sound with the EQ settings applied. It won't affect the surround channels,only the main ones. You can also connect the EQ across the pre out and main in sockets for the front channel on the A1
Aug 13, 2010 | Yamaha DSP-A1 Receiver
Yamaha dsp-a1
you need to set the ntsf or pal settings for hdtv and s-video is video1 video 2 or video 3 seting on input on remote
May 13, 2008 | Yamaha DSP-A1 Receiver
Yamaha dsp a1
to get to the diagnostic menu on the machine press power button set menu + button and next key all at the same time which will take you to the diagnostic menu
Jan 26, 2008 | Yamaha DSP-A1 Receiver
Please Help about a Yamaha DSP-A1
The A1 has an internal self diagnostic program which you can go through to find the fault. You can access the diagnostic program by simultaneously pushing some buttons on the front panel. The Yamaha service manual for the A1 tells how to do it and what the diagnostic codes mean. You can get a copy of the service manual on the web from several suppliers for a small fee.
Jan 08, 2008 | Yamaha DSP-A1 Receiver
Av amplifier
The display problem is because the solderings on the back of the display are broken. To fix it you have to open the amp and redo the solderings (there are about 50 or 60 of them). There is a Youtube video that shows how to do it. I have fixed this on my DSP-A1.
I also have the problem with the motorized volume control. I have tried cleaning it, and it works for a few days, then it's stuck again. I guess I will have to replace it to have it fixed permanently. The part number is VZ621400, a new one costs about 40$.
Jan 07, 2008 | Yamaha DSP-A1 Receiver
Volume level dropping unexpectadly
Nov 18, 2007 | Yamaha DSP-A1 Receiver
DSP-A1 Power Off
i am no expert but i had simmilar problems and it turned out that some capacitors needed replacing
Oct 25, 2006 | Yamaha DSP-A1 Receiver
Yamaha DSP-A1 Receiver Logo
332 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
