Question about Philips Televison & Video
Philips 20pf5121 no picture only thing on screen is channnel number. Had previous problem going standby to on.
2 Suggested Answers
jrweighing
  • 183 Answers
SOURCE: Philips 20PF5121/58 - problem: Very long start.
This is most certainly a capacitor in the power supply that has gone low in value, hence a low startup supply rail voltage. I would be looking in this area. Tell tail signs of faulty capacitors are from their tops bulging up with possible brown liquid discharge, or if their plastic base inserts give first with the pressure, these pop out from the can.
Posted on Feb 13, 2010
Testimonial: "Quite right! I've found and replaced 3 popped caps in power supply (same values and higher voltage ratings). TV is now OK! Thanks a lot!! "
Philips flat tv 20pf5121/01
Make sure no one has turned the sound down all the way, set the mute, turned the sound off in the setup mode, etc.
Oct 30, 2013 | Televison & Video
Ive lost my remote so need a replacement or universal so i an switch the tv to the dvi-i input
Im not familiar with your T.V byt you can get a universal remote control for that just go to electronic store then ask if they have a universal remote for your T.V make sure you memorize your T.V brand and model..
Jul 14, 2011 | Philips 20PF5121 20 in. EDTV-Ready LCD...
SONY KP-61SH10, NO PICTURE, NO SOUND. THE STANDBY LIGHT CONTINUOUS BLANKS. CAN YOU TELL ME WHAT IS WRONG WITH TV.
there could be a number of things going on here.
first suspect, is the lamp. Unless you had other symptoms previously. More info from you would be key in helping you out further.
lamps do need to get replaced after around 4000 to 8000 hrs. 2-3 yrs.
Mar 29, 2010 | Sony KP-61HS10 61" Rear Projection...
Philips 20PF5121/58 - problem: very long start. It can stay 5 min or more (to 15-20min), with green indicator blinking, then turns on and then works OK (the picture and sound are not distorted). If i...
Feb 13, 2010 | Philips 20PF5121 20 in. EDTV-Ready LCD...
HLR5667w Samsung.. Screen showing green stripes on SD cable channels. Works normally on HD channels. Not the Cable.. other tv's work fine. Go from one SD channnel to the other and image from previous...
mi reproductor de mp3 Yp-u3 enciende y de apaga rapido y me aparece en la pantalla resource data y the players is off eso sucede desde que le di formato en el mismo equipo por favor ayudeme.
garcias
Dec 21, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
Philips 42pf5521d - no picture, blinking green light
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting the number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Aug 17, 2017 | Philips 42PF5521D 42 in. HD-Ready Plasma...
Philips tv for repair
As you say that it works for 5-10 minutes it clearly indicates that all parts are 100% ok. problem is loose contact mostly in power supply& IF IT IS OK then loose contact in horizontal section. Good luck.
Sep 16, 2007 | Televison & Video
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
