Question about Hotpoint First Edition WMA22 Front Load Washer
Washing machine broke
I Have a first editon hotpoint wm51 front load washing machine i have not had it long and i recently put it on a cycle but it cut the electric of then when i put it back on put the wash on as normal and went out shopping when i got in the wash was still on and hadnt moved very much thru the cycle and it continues to do the same it fills with water and dosent go thru the cycle or it clicks thru but the washer does nothing it leaves the water in the machine and i have no idea how to fix it we have tried leaving it a couple of days and we took of one of the waste pipes to check if its blocked but we have no idea what to do we dont know where the filter is there is nothing on the front at the bottom on this machine and we dont no where it could be blocked as that is what it seems to us.Also for a while now one the wooly wash setting the end spin has not been working but the orthers were b4 so i dont know if that was part of it breaking? Also a few people have said it could be the programer but this again means nothing to me pls help me!
  • 1 more comment
  • tdunnaway Jan 09, 2008
    hi i have got my husband to try and do as you said he took the clips of checked pipe but again there is still a problem there is no plastic ball that we can see so we are still stuck with a broken washer thanks for tryin to help but i dont know if u noticed my model is wm51 is urs the same? does anyone know how to fix my washer?
    hi i spoke too soon allthough my husband didnt find the ball he did get some dirt ect from out pipe and it seems this blocked it up because now doing a wash with no clothes and so far so good so fingers crossed and u helped fix it thanks very much
  • Anonymous Mar 25, 2014
    I think the inside of the washer got water in it due to a pipe breaking behind it. I took off the back and let it dry for a couple of days but the dial continues to click around thru all of the cycles and the washer does not work. Please advise.
    Thank you.
I have the same machine and had the same problem. It turned out that the outflow trap which contains a plastic ball had filled up with junk out of pockets etc and also with strands of fabric from cloth nappies. If you remove the drain hose assembly(unplug the machine first!!) by unscrewing the jubilee clips on the hoses(this is inside the rear panel of the machine at the bottom) you can rmaove the outfloe trap take the ball out and empty out all the junk. Check that the hoses are clear as well and then check no junk remains where the part attaches to the bottom of the drum.
Put everything back together and run the machine for a full cycle with no clothes in it this should remove any left over bits of junk.
I have had to do this four or five times in the two years I have had this machine but it runs fine and washes perfectly until too much jnunk is in the trap, then it has the same symptoms you describe, wont finish the cycle, wont spin. On one occasion it poured water out of the powder tray, again same problem!!
If the machine has stopped full of water you will have to abort the programme unplug the machine, plug it back in then open the door catching the water in a large container then follow the procedure above. Water will drain from the hoses when you take them off have some towels handy!! Good Luck, Al from Manchester
Posted on Jan 08, 2008
Where is pressure chamber bottli in hotpoint first editon 1000 wm19?
to get to it you need to remove the plug so there is no power to the machine????
take off the top
turn upside down ,
put the screws into the lid as you take them out
remove the dial screw at the back
remove soap dish.. 6 screws
unclip the door seal
take of the front 6 screws
follow the pipe from pressure switch down
there it is to take of and clean there is 3 screws
now you need a dumpy screw driver
May 18, 2014 | Hotpoint First Edition FEW12 Front Load...
Hotpoint wm51
get a new lock they are cheap
Apr 15, 2014 | Hotpoint First Edition FEW12 Front Load...
my hotpoint first edition 800 wm51 wont spin?
Nov 17, 2010 | Washing Machines
I have a Hotpoint washing machine model wm51 and the machine fills with water but stops and will not go into a wash cycle
could be heater fault listen to it if it works it should sound like a kettle warming
up it takes a while
Mar 02, 2010 | Washing Machines
Hotpoint fault?
Check the drain and circulation hoses for partial blockages as usually this causes such problems. Also make sure you using program with full speed spin cycle (solid spiral sign just before the dot pointing the end of chosen programme)
Mar 01, 2009 | Hotpoint WMA30 Front Load Washer
Hotpoint wma22 fills with water but won't wash or spin
Suspect motor brushes need replacing.
Simple task accessed by removing the top of the washer and releasing the clips holding the brushes into the motor - clip on back of brush - to remove the brush assembly.
Replace complete brush assembly.
Feb 16, 2009 | Hotpoint First Edition WMA22 Front Load...
Hotpoint WM51 Washing Machine keeps tripping the electric
I had this problem; it was the motor arthing out on the body. It took a repair man half an hour to sort and it cost me £35. Hope this helps. Domo.
Jan 24, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Ok that rules out the heating element. There are a number of possible causes so bear with me while i go through them.
Can you open the door? If so leave it open then turn on the machine. Does it trip?
Jan 23, 2009 | Hotpoint First Edition FEW12 Front Load...
Wash Cycle Guide has rubbed off my machine
In your browser bar, type in HOTPOINT UK
Then in the drop down menu, click on Hotpoint uk
then click on After sales
Then click on Download instruction books.
Put your model of washer in box in capitals, and down load to your hard drive or printer..
Thanks.Plz rate my solution and feel free to leave a comment
Jan 08, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Washer door won't open (hotpoint first editon 800)
I have just had exactly the same problem. 10 seconds of washing, fuse blew, replaced it, cycle completed but now the door lock is stuck on. Like you I tried a new cycle but this has done nothing. In the end (and I'm not suggesting that this a remedy to the problem) I unplugged the machine - pulled the door handle til a gap appeared at the top of the door and forced it open by working a pair of scissors in to the gap and pulling. Of course as soon as I shut the door again and turned on the power the lock light came straight back on the and the door was locked tight. Sorry but this is the best I have come up with short of calling some one out.
Aug 13, 2008 | Hotpoint First Edition FEW12 Front Load...
Hotpoint First Edition WMA22 Front Load Washer Logo
175 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
