Question about Sony KDS-70R2000 70" SXRD TV
Bulb is out. how mant replacement bulbs do i need
  • Sony Master
  • 5,138 Answers
ONE--- Call Encompass Parts 1-800-638-3328
Posted on Nov 13, 2009
How do I replace bulbs on model DS5603 Mod G electric fireplace
Do you need to replace the upper or lower light bulbs?
For both, first open the door of the fireplace. For the upper light, locate the upper bulb bracket (above the door). Bend the bracket down. Unscrew the old bulb and replace it with 7 W clear chandelier or candelabra bulb with an E12 base. Bend the bracket back up to its original position. Close the door, if only the upper bulb is out.
You will need a Phillips blade screwdriver to replace lower bulbs. Open the door (if it wasn't already open). Locate the screw that holds the log set in the center of the ember bed. Remove that screw and the log set. Locate the bulbs that are behind the log set and determine if one or both bulbs need to be replaced. Unscrew the bulb(s) to be replaced. Screw in the replacement 60 W clear chandelier or candelabra bulb with the E12 base. Replace the log set and press firmly against the glass. Replace the screw that holds the log set. Close the fireplace door.
The procedure to replace the bulbs is on page 4 of the service manual. It is also on pages 10-11 of the Owner's Manual. The documentation is available from Dimplex: http://www.dimplex.com/en/customer_support/technical_and_troubleshooting . The direct link to the service manual is http://www.dimplex.com/cms/publications/7400650000R04.pdf . The Owner's manual is here: http://www.dimplex.com/cms/publications/7206570100R09.pdf .
I hope this helps.
Jan 12, 2017 | Heating & Cooling
Tip
Brake Lights Dull or Flickering - All Cars
Dull or Dim Brake Light Repair: If your car has a dull or dim brake light it is dangerous to you and other drivers. A dim brake light is a mystery to most people because the bulb is working, just not correctly. First confirm a new and correct brake light bulb has been installed. Next, turn the ignition key to the "on" position and have a helper depress the brake pedal. With the bulb installed touch a grounded test light to the outer bulb holder ring. If the bulb brightness changes the bulb socket ground has high resistance and needs to be repaired or replaced.
Flickering Brake Light Bulb Repair: A flickering brake light bulb can be very distracting and annoying. A brake light flickers because the power or ground is being obstructed momentarily. The most common cause for this condition is a loose fitting bulb socket. To check for this condition remove the brake light bulb in question, while a helper hold their foot on the brake pedal move the bulb around slightly in the socket. If the bulb flickers replace or repair the bulb socket as needed to regain proper brake light bulb operation. If the brake light bulb socket tests ok wiggle the brake light fuse and wiring at the brake light bulb socket, brake light switch and turn signal switch (American cars). If the brake light bulb flickers repair the component or wiring as needed.
Preferred Procedure: Always replace brake light bulbs with manufacturers recommend replacement bulbs. If you cannot find the correct replacement bulb part number consult an auto parts store for additional manufacturer information.
Common Problems
When brake light bulbs are replaced with the incorrect bulb causing no or dim brake light operation
If the brake lights stay on continuously it could mean the brake light switch has failed or an adjustment is needed.
on Dec 18, 2009 | Honda Civic Cars & Trucks
Need a diagram on how to replace light bulb in clock in EL Falcon dash.
To replace the clock light bulb on 2001 Honda Accord, you will need:
  • Screwdriver
  • Replacement bulb
  1. Remove the clock assembly in the 2001 Honda accord. Pry the clock assembly off by wedging a flathead screwdriver into the edge and prying off the cover. Work your way around until it comes off.
  2. Remove the old bulb by pulling it out of the socket. Dispose of the bulb.
  3. Replace the bulb with an equivalent bulb. Simply push the bulb into the slot. Be sure to take the bulb with you when you purchase a new bulb so you get the exact bulb. Purchase a bulb with the same voltage. Although a bulb with different voltage may work, it can burn out more quickly.
  4. Replace the clock assembly. Line up the clock assembly over the bulb and press firmly on both edges to attach it back to the 2001 Honda Accord dash.
Tip:
  • Place masking tape on the edges of the dash around the clock assembly to protect your dash while you are removing the assembly with the screwdriver. Remove the masking tape when you are finished replacing the clock light bulb on your 2001 Honda Accord.
Jul 05, 2011 | Falcon 4420
Need to change bulbs in headlights on a 2004 kia amanti
LOOK IN GLOVE COMPARTMENT FOR OWNERS MANUAL.LOOK IN THE BACK INDEX OF MANUAL LOOK FOR BULB REPLACE IT WILL SHOW YOU HOW TO REPLACE HEADLIGHTS BULBS BULBS ARE HALOGEN YOU NEED TO USE CLEAN LATEX GLOVES WHEN HANDLING AND REPLACING BULBS BECAUSE OIL FROM YOUR FINGERS OR HANDS WILL CAUSE HALOGEN BULB TO OVER HEAT AND BLOW AND HALOGENS BULBS VERY EXPENSIVE. THEY CAN RUN PRICE RANGE FROM $10.00 - $20.00 DOLLARS.
Jun 15, 2011 | Kia Amanti Cars & Trucks
How do i replace the odometer cluster on a 2001 Buick Century? Odometer only light up if i hit dashboard, Then it goes out.
You dont need to replace the cluster you just need to replace the bulbs, by hitting it the bulb filment thats bad make a connection, if you remove the cluster and look at the rear of it you will see the bulbs, there are many bulbs some for the battery light and oil light, so use a flash light and when you remove a bulb shine light through the hole and see if it the correct bulb or if its a symbol bulb, most of the time the lighting bulbs use a diffrent color socket, what you do is untwist the socket then it pulls out and the bulb is on it, you then pull bulb out of socket and install new bulb on socket and twist back in, you dont need to replace the whole cluster and the bulbs are sold at any parts place, take one out and match it up it should be part # 194 bulb.
Dec 12, 2010 | 2001 Buick Century
Change out a taillight
You want to change the tail light bulb?
The process for replacing tail light bulbs is the same in all models. If you have a burnt-out tail light bulb, you may need to replace the brake light, the reverse light or the turn signal. The procedure to replace each of the bulbs is the same.
    Instructions
    1. Open the Hummer's rear swing gate. This will expose the edge of the vehicle's tail light assembly. You'll see two small Phillips head screws that hold the tail light assembly in place. Put on your gloves.
    2. Remove the two screws from the tail light assembly. Pull the tail light out and inspect the back for two bulbs. The top bulb is the brake light and turn signal. The bottom bulb is the reverse bulb. Determine which bulb you need to replace.
    3Rotate the bulb's socket counterclockwise to disconnect it. Unplug the bulb from its socket.
    4Push the replacement bulb into its socket firmly. Insert the socket back into the tail light. Turn it clockwise to secure it in place.
    5Place the tail light into its cradle. Hold it with one hand and replace the Phillips head screws with the other.
Dec 03, 2010 | 2008 Hummer H3
How do I change the lamp? Lamp came with no directions. This is a HD72.
Hello there,If your movie projector light bulb has stopped working, there are some simple steps to take to get your movies playing again. The hardest part may be finding the correct replacement bulb. There are so many different models with their own specific bulb. Here are some steps to follow to replace your burned out light bulb.
  • Locate the bulb in the movie projector. You may need to use a screwdriver to open the bulb compartment. Check your owner's manual for proper procedures.
  • Step 2.Remove the movie projector light bulb or lamp. The bulb must be cool before you take it out. Use a tissue or cloth to remove the bulb because the glass bulb is very fragile. Do not throw away your bulb yet, you may need it to help find a replacement.
  • Step 3.Find replacement bulb. The Better Lamps website offers a wide variety of light bulb models. From their homepage select the brand of movie projector you have and using the model number from your old bulb, buy a replacement.
  • Step 4Replace the movie projector lamp or light bulb. Do not touch the bulb with your skin. This can transfer oils from you onto the bulb resulting in a hot spot which can make the bulb burst. Use a tissue or cloth to handle the new bulb to screw it back into place and then replace the cover.
  • Jul 31, 2010 | Optoma HD70 DLP Projector
    How do I open the top of the projector to replace the light bulb?
    Hi, Follow :- http://www.wikihow.com/Replace-a-Projector-Lamp There is a Video as well on the same page.If you wish to Purchase the Bulb, you could consider :- http://www.partstore.com/minisites/projectorLamps/HowToReplaceProjectorLamps.aspx Let me know, if needed further assistance, Hope i helped you. Thanks for using ' Fixya ' and have a nice day!!
    Feb 10, 2010 | Televison & Video
    Need to replace headlight bulb in honda civic 2003
    How To Install Replace Headlight and Bulb Honda Civic Sedan 01-03 1AAuto.com
    Dec 31, 2008 | 2003 Honda Civic
    Replacement of Bulb PT-43LC14
    Just get a bulb off ebay, make sure the listing shows that it includes instructions or ask the seller. Its and ez replacement with a philips.
    Sep 29, 2008 | Panasonic PT-43LC14 43" Rear Projection...
    Sony KDS-70R2000 70" SXRD TV Logo
    27 people viewed this question
    Top Sony Televison & Video Experts
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
