Question about Microsoft Xbox 360 Console
Putting discs int my console everytime just keeps saying clean your disc
    Genius:
  • 1,093 Answers
This is getting quite common, it happens because the receptors on the back of the DVD drive have heated up, you will need to get it fixed, to do this you should send it back in or you can use a good Xbox 360 Repair guide and fix it.
Posted on Nov 12, 2009
Xbox keeps saying unreadable disc everytime i put in saints row the third
erm this might be a firmware issue i suggest if your still under warrenty contact xbl customer support and they will reflash the firmware on the cd drive
Jan 06, 2012 | Microsoft Xbox 360 Console
It keeps saying the disc cant be read
Hello renee and welcome to FixYa. There are usally two reasons why this commonly happens. Firstly the disc you are trying to use is dirty. Using water or a lens cleaning solution clean your disc followed by drying with a microfiber or other soft cloth and wait until totally drying before reattempting. If this does not solve your problem you may have a dirty laser lens which thankfully is easy to access on the particular console. You will need to wipre the laser lens under the disc cover using the same method I mentioned to clean the disc. My son owns a GameCube as well and this has been the issue everytime. I hope I was of help to you and good luck.
Apr 25, 2011 | Nintendo GameCube Console
My xbox keep saying open and close tray and will not play disk
you need to purchase a lazer disc cleaner it looks and works just like a normal dvd disc but it has brushes on it that when put through the player brushes the dust of the laser lens this needs to be done on a regular bases to keep your lazer working to its optimum level and hense fixing your problem.
Inspect and clean your disc Take a close look at the bottom side of your game, movie, or music disc (the side without a label or image). Are there scratches? Excessive scratches or smudges can prevent your console from reading the disc. Clean your disc Hold the disc by the edges without touching the top or bottom surfaces. Using a soft, clean, slightly damp cloth, lightly wipe from the center of the disc outward.
· Note Use ONLY water to clean the disc.
· Once the disc is clean, load the disc into your console and see if the disc plays.
Dec 28, 2010 | Microsoft Xbox 360 Console
My xbox keeps saying open tray I brought it to a guy twice and no fix everytime I put a game or movie in it it reads and says open tray
Reasons
1, the disc may be dirty
2. the mian reason for this your xbox drive cannot read the disc , because the power of the lens is gone(not completely) ,
solution:
1. keep your disc inside the drive and switch off the console, again swith on try this 2 to 3 time
2. keep the console in vertical position or little slanding position(180 dg) make sure it does not fall
3. its better to buy hatddisc and load the game inside it , so that u lens life increased
4. change the entire drive
May 08, 2010 | Microsoft Xbox 360 Console
Xbox360 disc drive
Hi, it sounds like you have the" open tray" error that is very common with the 360s. How you fix this is you take your DVD drive apart and look at the laser assembly, there are 2 screws on the side of it, look at the one on the left. Turn this screw to the left a VERY little bit at a time and keep checking it every time you turn it until it stops the open tray error.
Aug 17, 2009 | Microsoft Xbox 360 Console
My xbox will not read any of my discs
If you do not hear your xbox disc spinning that means your disc drive is broken. You will need to order another one. if you are under warranty still go have microsoft fix it for free. If not u can order parts online to fix it yourself.
Feb 17, 2008 | Microsoft Xbox 360 Console
Ps2 keeps saying disk read error everytime disk is put in no matter what disk is put in what can i do to fix
  • Confirm the disc is inserted correctly into the PlayStation 2 console (label side should be facing up when the PlayStation 2 console is in the horizontal position).
  • Confirm the disc is clean. To clean a disc, use lint-free cleaning cloths made specifically for cleaning CD/DVD discs, sold at computer software stores. When cleaning the disc, we recommend starting from the innermost circle, and wiping out to the edge in a straight line. We do not recommend wiping in a circular motion, as it may create more scratches on the disc. [Note: Other materials, such as a paper towel or a T-shirt, may also scratch the disc. If there are any scratches, smudges, or fingerprints on the disc, it may not function properly.]
  • Try playing different CDs, DVDs, and games on the PlayStation 2 console to see if the problem exists across multiple discs.
  • To determine if the problem is with the disc itself, try playing the disc on a different PlayStation 2 console (or a PS oneTM or a standalone CD/DVD player, if applicable).
  • Confirm that you are not using any game modification devices. Unlicensed devices such as game modification devices can interfere with the proper function of the software. We do not recommend the use of any game modification devices or unlicensed products[1].
Dec 17, 2007 | Sony PlayStation 2 (PS2) Console
Problem With Xbox 360
You may have a laser problem or a faulty DVD drive, you could try a lens cleaning CD in the console or you could call Microsoft and explain your situation, the DVD is replaceable but it may be more work than you are willing to undertake.
If at all helpful, please rate, thanks!
Nov 24, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
19 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
