Question about Sanyo Televison & Video
We have a SAnyo HDTV LCD Model DP19649 and can't
We can't seem to program the channel selection to skip certain channels. The channel scan memory setting menu is confusing and I can't get it to disable certan channels. Any advice?
    Problem Solver:
I have a sanyo dp-19649 tv and it's hooked up to a panasonic sound bar model# sc-htb10,and it's hooked up to a sony blueray dvd player. the sony player works on the sound bar but the tv doesn't.
Posted on May 19, 2011
Toshiba LCD TV/DVD 15LV505 lost channels. Rescan = fewer channels. Now in Setup, when I press the remote down-it skips the Channel option. What must I fix/change in Settings to get the Channel option?
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
Dec 08, 2016 | Toshiba Televison & Video
I have a manual, but cannot remove unwanted channels on my DP19649. How do I do this????
As far as I understand, some TV's don't have the skip channel feature. If your TV has the 'Skip Channel' feature, you first select channels that have no signal (either a blue screen or snowy screen) then press the up -down arrows to select the 'Skip' and Ok button on your Remote. The Manual should explain how it is done.
Oct 18, 2014 | Sanyo DP19649 LCD TV
How do I remove channels ?
Select the channel you want to eliminate, select one by one, and skip them by pressing the skip button on the remote control. Skipped channels will not appear later.
My Sanyo TV won't scan every channels that my other TV's scan!
check weather some of your channel was deleted in the program. just add those channel so you can make auto scan programs.
Oct 07, 2012 | Sanyo DP46849 46 in. HDTV
How do i get reception with only a cable connection...no box. i don't know what settings to have the tv on.
In the main menu select "CABLE" AND NOT AIR.
With the cable connected to the coax fitting then turn set on and look for AUTO PROGRAM------engage that and the set will scan thru all the available channels.
If it misses any you can with the remote direct enter a channel and in the main menu "add" it to the up down memory.
It is also helpful to "skip" out channels you do not want in the up/down memory-----this is in main menu also.
I usually skip out the Golf channel and others I never watch.
Let me know if you have questions.
Dec 07, 2011 | Toshiba 51H84 51" Rear Projection...
I know this tv has digital capabilities, so i don't need to get the digital box, what do i need to watch my local channels? i have directv but does not include local channels (ie. fox, abc, nbc).
Hello
To tune the local channels do the following.
1 Press the MENU key on the remote control to
display the Main menu.
2 Use the CURSOR "UP" or "Down"
keys to highlight
Manual Channel Search. Press ENTER.
3 Use the CURSOR "Up" or "Down"
keys to select Cable,
Air (Antenna), or Digital Add-On.
After the search is complete, the HDTV will exit the
menu system and return to normal TV viewing.
IMPORTANT FACT: This HDTV maintains only one database
of digital channels. Therefore, when you search for
cable channels, the database of antenna digital channels
will be deleted. You will only be able to receive those
ClearQAM channels your cable company provides.
NOTE:"Not available" will appear on the screen
when an option is unavailable.
TUNING MODE UNAVAILABLE MENU OPTION(S)
Analog RF Digital Caption
Digital RF None (all Menu options available)
Video 1 Manual Channel Search, Channel Scan
Memory, Digital Caption
Video 2/3 and Manual Channel Search, Channel Scan
HDMI 1/2 Memory, Digital Caption, V-Guide
OK.
Feb 08, 2011 | Sanyo DP32648 32 in. LCD TV
Will the standard coaxial cable input on a Sanyo DP19649 accept the 480i digital output from "TV2" of a DISH network ViP722K satellite box?
This will absolutely work!!! You will just want to make sure that your tv is set to channel 60 or 73.
Sep 22, 2010 | Sanyo DP19649 LCD TV
I cannot program channels on my Dynex Model: DX-LCD32-09. What should the settings be for auto scan?
I JUST GOT A 26 NCH DYNEX FLATSCREEN AND AS I WAS WATCHING FOOTBALL IT JUMPED,SKIPPED CHANNEL'S OR WHAT NOT FROM 1014 TO 46.2 ON ITS OWN. WHAT IS WRONG?? OR WHY WOULD IT DO IT??
May 29, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Need to program a GE Universal remote for Sanyo HDTV DP19649. Sanyo codes listed by GE don't work. Thanks!
http://www.remotecodelist.com/remotes/old-index.html
in this page you need read step by step for solved you problem...
bye
Mar 07, 2010 | Sanyo DP19649 LCD TV
Element Electronics FLX2211B 22 in. LCD TV will reset every time
I have run into the same problem with a different model (32 inch from Circuit City). You may have found that there is almost no support from the co or web. I do not have an official solution but have some work arounds that have done the job for me.
WA#1 = after a channel scan tune to a HD/digital channel before you turn the set off. You need to do this each time for several times, because the set when turned on to a regular cable or analog station will default to skip all channels. After several times the set should remember your channels.
WA#2 = after a channel scan, go to the skip channel section of the menu, and if your remote has the colored buttons on the bottom scroll through the channels using the red and green (up and down on this menu) buttons. This apparently helps the set remember not to skip your scanned channels.
These are not glamorous solutions but appear to trick the TV into not re-setting the skip function for the channels.
Best of luck.
May 02, 2009 | Element Electronics FLX2211B 22 in. LCD TV
Televison & Video Logo
460 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
