Question about D-Link AirPlus DI-524 Wireless Router
Port Fowarding Issue
I am trying to foward the ports of my Xbox 360 so my router allows Xbox Live. I get to the Advanced----> Virtual Server screen but I cannot find the "Private IP" I assume this is the IP that belongs to my xbox but I cannot find it anywhere. I was wondering if you could help me find it.
    Novelist:
  • 101 Answers
Hi Noshhit,
On your Xbox, go to the dashboard, move along to the 'system' tab (the furthest right tab), then go down to "Edit Settings" and you will see your IP info in basic settings. Your Ip is there.
Good Luck!
Posted on Jan 07, 2008
I want to change nat type from strict to open when I play Black Ops. My router is a Thomson TG585 v8. How can I do that? Thank You in advance
Step 1: Get your Xbox 360's IP address from the system blade and choose network settings. Then edit settings should show your Xbox's IP.
Step 2: Go into your routers configuration window thru Internet Explorer. In the address bar type in your routers IP address. It should be default at 192.168.1.1 or 192.168.2.1. When you're prompted for a password you have found it =P. If you haven't changed it the username and password should both be admin, and admin.
Step 3: USING DMZ When you enter into your router config window, you need to find the Tab DMZ, it should be under applications and gaming if you are using Linksys. Once you find the DMZ tab, click enable and type in the last digits of your XBOX into the box below. Yes when you do this you are opening all the ports on your Xbox, which is insecure, but show me someone that has hacked into an xbox 360?
Step 4:Using Port Fowarding After you have enabled DMZ, find the Port Fowarding tab, should be under advanced routing. For the name type in XBL or whatever you want, and for port range put 87 to 89, choose UDP, then your XBOX last digits, and enable. Then do 3073 to 3075 choose TCP, then your XBOX last digits, and enable. Then again do 3073 to 3075 choose UDP, then your XBOX last digits, and enable.
Step 5:Using UPnP This is just incase. Go into UPnP fowarding and enter in the same stuff you did for Step 4.
Step 6: Now logout of your router config. Unplug your router and modem from the power, then plug in the router 1st, wait 30 seconds. Then plug in the modem and wait at least 2 minutes. If you don't do these hard restarts it might not work!
Step 7: Restart your Xbox and go to the system blade, choose network settings, then test connection. This may take a bit, but when it gets down to NAT type it should say OPEN. If not, sorry. You can just undo all the settings we changed, you can just uncheck enabled on the port fowarding. or if you want to restore your router to the factory defaults just push the reset button on the back of it.
Once again this may not work for everyone, but it worked for me and my friends, so good luck.
Feb 27, 2011 | Video Game Consoles & Games
My xbox is connected to my internet via connecting my xbox to my laptop. I tried changing the nat settings by doing all the methods, you name it: port forwarding, DMZ, UPNP, and it STILL DOES NOT *******...
I know what you're going through as it is common on Belkin routers. There are actually some good solutions to this found on youtube for simple instruction to help demostrate but I'm gleaned you already have done some of the advanced steps. Here is my question did you ever set your xbox 360 with a static ip address and then add it to the firewall/virtual server settings. You put the static ip address in and the xbox 360 ports.
Dec 22, 2010 | Zyxel P660HW-D1 Router
I have a Linksys WRT160N wireless broadband router. When I get on Xbox Live it says that I have a strict NAT type and I want an open NAT type. I have already enabled the DMZ, UPnP, and put in the proper...
try this :
1. Log into the router using 192.168.01. or 192.168.1.1
this is done using a browser window such as Internet Explorer or Firefox.
2. go to Application & Gaming
3. In the box on the right column us wan to enter the device ( example: Xbox)
4. you need to enter the start and end port next ( example: 88 and 80
5. then your protocol ( example: tcp ,UDP, or both
6.the IP address if next
7.check enable
8. then save
9. here is the site with an example page to configure your router.http://homecommunity.cisco.com/t5/Wireless-Routers/Xbox-360-NAT-issues-solved-WRT160N-v3/m-p/310658?comm_cc=HSus&comm_lang=en#M163159
Aug 21, 2010 | Linksys WRT160N Wireless Router
Hi, How to format external hard disk whose file system shows as RAW. Under my computer the drive is shown as Drive F but any attempt to open the drive gives an error to format the disk. While attempting...
OK try this
<MAKE SURE YOU SAVE SETTINGS>
after done - then cold reboot both Router and Xbox
XBOX go to the system blade, choose network settings, then test connection. This may take a bit, but when it gets down to NAT type it should say OPEN.
Aug 21, 2010 | Western Digital Passport 320GB External...
I can play online with with my xbox 360 with some friends but not others. I think it may be because of my nat.
Verify you have uPNP enabled on the router and that should do the trick.
Your router may not support it, so if not, you can setup a port fowarding rule for TCP port 3074 to forward to the IP address of your xbox 360
Jul 14, 2009 | Zyxel P660HW-D1 Router
How to create a port on my router
please follow the steps are given below,
1.Type 192.168.1.1 on your browser's address bar. You will see a login dialog box .
2.Type your username & password and login to device.
3.A web page will appear , you can go to security section & select virtual servers.
4.From virtual servers section you can create port you want either TCP or UDP.
best regards,
Krishan
May 09, 2009 | U.S. Robotics (USR5450) 802.11g/b Wireless...
Zoom X6 Adsl Router
You must assign a static IP address on the Xbox 360 that it is outside of the Zoom X6 router's DHCP pool. Also, the Xbox 360 must be in a DMZ. This will prevent the firewall of the router from blocking connections to the Xbox 360.
  1. Assign a Static IP address on the Xbox 360 console:
    • Power on your Xbox 360 and go to the System area.
    • Select Network Settings and then Edit Settings.
    • Select IP Settings. The Edit IP Settings screen opens.
    • Select Manual and then enter the following settings:
      • IP Address: 10.0.0.150 (or any 10.0.0.x IP address, where x is between 100 and 250)
      • Subnet Mask: 255.255.255.0
      • Gateway: 10.0.0.2
    • Select Done, to go back to the Edit Settings screen.
    • Select DNS Settings. The Edit DNS Settings screen opens.
    • Select Manual and then enter the following setting:
      • Primary DNS Server: 10.0.0.2
      • It is not necessary to enter a Secondary DNS Server.
    • Select Done.
    • Power down your Xbox 360.
  2. Access the Zoom Configuration Manager:
    • From a computer that is connected to the Zoom X6, open a web browser and type http://10.0.0.2 in the address line and then press Enter (or Return).
    • Enter the User Name and Password (in lowercvase letters):
      • User Name: admin
      • Pasword: zoomadsl (where "l" is a lowercase letter L)
  3. Create a Virtual Server rule to put the Xbox 360 on a DMZ:
    • In the Zoom Configuration Manager, click on the Advanced Setup icon at the top page.
    • Click on the Virtual Server/DMZ button.
    • On the Virtual Server/DMZ page, enter the following settings:
      • Internal IP Address: 10.0.0.150 (or whichever Static IP address you selected per Step 1)
      • Protcol: DMZ
      • Start Port: 0
      • End Port: 0
    • Click Save Changes
    • Click the Enable box, if you have this option.
    • Click Write Settings to Flash
  4. Plug the Xbox 360 Wireless Networking Adapter in to the Xbox 360 console. If you are not sure how to do this, please refer to the manual that came with the Adapter.
  5. Select the Zoom wireless network on the Xbox 360. (Note: The following steps assume you have a working wireless network with WEP or WPA security enabled and you know the Key and SSID of the network. If you have not done this, please refer to theFAQ on setting up a wireless network with the Zoom X6.)
    • Power on your Xbox 360 and go the System area.
    • Select Network Settings and then Wireless Network.
    • Enter the SSID of your network
    • Enter the Security Key for your wireless encryption. This must be either WPA or WEP. If you use WEP, you must enter the HEX digits for the Key you are using.
    • Power the Xbox 360 off, wait a few seconds, and then power the Xbox 360 back on.
    • Go to the System area.
    • Select Network Settings.
    • Select Test Xbox Live Connection. If everything is configured correctly, all the tests will show Pass.
  6. Congratulations! You can now enjoy your Xbox 360 with Xbox Live.
May 23, 2008 | Zoom X6 Adsl Modem/router Rohs...
Cannot sign up for xbox live
have you tried running the troubleshooter (if so, wat did it say?)
Apr 13, 2007 | Microsoft Xbox 360 Console
D-Link AirPlus DI-524 Wireless Router Logo
59 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
