Question about Crosley CR249TA Turntable
This is a question for my daughter who lives in Japan. She has a Crosley turntable she bought from Urban Outfitters. The stylus arm has suddenly started skating over the record, ie won't play anything. She has checked for dust on the stylus and it is clean.
  • 379 Answers
I have no experience of Crosley turntables, however, stylus arm skating across the record surface on any turntable is normally due to the counter balance weight being incorrectly adjusted. In order to track across a record properly, the stylus must press down on to the record very lightly. If there is too little pressure, skating is what tends to happen. Too much pressure can cause distortion of the sound and excessive wear of the record.
At the pivoting end of the stylus arm, there should be a counter balence weight. This is normally adjustable (but not always - depends on quality and features of the particular turntable), and is used to set the pressure the stylus applies to the record surface, measured in grammes. The manual that came with it should tell you how to adjust it, but for most turntables stylus pressure is between 1 to 3 grammes.
If you dont have the manual, have a good look at the pivoting end of the stylus arm to see if soemthing is obviously wrong, or if not whether there is something with numbers on it that can be turned or slid. This is likley to be the counter weight. Try adjusting it.
Within reason, the stylus weight isnt critical so a "trial and error" approach wont do any harm.
Posted on Nov 12, 2009
Testimonial: "I have forwarded this to my daughter, not sure if it is the answer, but it sure sounds like it. Thanks for the quick response. Love the beagle."
Why is my brand new crosley turntable keepsake hunter skipping tracks?
The turntable may not be level. Also, the stylus could be damaged or defective. The stylus pressure may not have been set correctly in production or may have been affected by shipping.
May 05, 2014 | Crosley Keepsake USB Turntable
Why is my crosley turntable skating across records?
First feel with your finger at the tip of the stylus. It should be sharp. If it's not report it back to the place where you bought it.
If it's sharp, then the weight on the end of the arm might have moved, meaning there is no pressure to the stylus. You can look up what it says in the manual about stylus pressure.
The other way is to test and adjust. If the weight has numbers on it set it about the middle of the numbers. Then try a record, if it skates, stop and increase the weight by moving to a higher number, not much, then test the record again. You keep doing this till the stylus stays in the groove. However don't increase it that much so it rumbles when in the groove. If that happens reduce the weight slightly and test. I find it best to test with headphones on.
May 05, 2014 | Crosley Audio Players & Recorders
Looking for cartridge/needle/stylus...
If you type Crosley Cartridge into Amazon, the type you need will turn up. Price around $20.
Apr 24, 2014 | Crosley CR6007A Turntable
Crosley Turntable is playing too slow.
try cleaning the motor and oil with a drop of wd40 do not get it on belt
Feb 16, 2014 | Crosley RADIO CR6249-BK DELUXE KEEPSAKE...
Turntable EU Plug volume has suddenly decreased?
There are several possiable answers to this. One the cartridge might have died. 2 the pre-amp might have died (in your amp). 3 a bad connection.
Dec 10, 2012 | Audio Players & Recorders
What is the replacement needle for crosley cr74
Here i have added two links which will take you to the needle for Croslye CR 74. There you can also fined the code for the item
LP Gear stylus for Crosley
LP Gear 78 RPM stylus for Crosley
Dec 09, 2012 | Crosley CR74 Turntable
Tone arm retracts before recording is complete (CR-245)
actual old units (not sure about modern nostalgics) sometimes had a lever that said 7 or 12 inches for 45's or 33's this would tell the mechanism when to set down the arm. If your unit does not have something like this then it sounds like an internal failure that would require it being opened by a tech or sent in for warranty repair.
Feb 10, 2009 | Crosley CR249TA Turntable
BSR turntable arm slides across record
There can be a number of reasons for this.
Have you checked that the stylus tip has not broken off? this is a common cause and will require a new stylus.
Jan 17, 2009 | Crosley CR248 Turntable
Turn table
Hello Runaround. If out of warrenty and you got the 'want to' unplug the AC, lock the stylus arm,open unit up and unplug your interconnect ribbon cables one at a time & reseat them this includes the socketed ICbds as well. If the speed adjust is mechnical check for an obstruction. Good luck!
Jun 02, 2008 | Crosley CR248 Turntable
Crosley CR249TA Turntable Logo
554 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
