Question about Kenmore 30464 / 30465 / 30469 Gas Single Oven
Why does the Oven take so long to light?
We just bought a foreclosure and I cleaned the oven really good. I know its been sitting for at least a year not being used. After turning the oven on it takes 8 or more minutes for the gas bar to light to heat the oven, do you know why? I don't know the model number.
    President:
  • 1,015 Answers
It sounds like it might be a sticking gas control valve for the oven or the hot surface igniter for the oven might be weak. You will need to turn the oven on and off completely several times until the problem happens. When I say completely I mean turn on the oven control and watch the igniter start to glow. Then when the oven burner comes on(should within a minute) shut of the oven control and wait for the igniter to stop glowing completely and burner to shut off completely. Then repeat the process again. If you try it about 10 times and nothing happens then the problem will be difiicult to identify. If you turn on the oven control and the igniter comes on but the gas burner does not then try giving the gas control valve(located in brolier/storage compartment) a tap with a wrench. If the burner suddenly comes on then the control valve was sticking. Try repeating the shut down/turn on process again. If it does not do it again you may have fixed the problem...if it does you will need to remove the igniter and test it with an ohm meter(should read at least 500 to 800 ohms). If the igniter is testing good and glowing brightly then the gas control valve would be the suspected problem. And remeber to be very careful when doing these testing procedures so you do not hurt yourself.
Posted on Nov 12, 2009
I don't know how to clean the oven
Hello OTCHENASH...
Make & Model would be really really really helpful here!!!
if It's a NEW STYLE self cleaning oven... read the new manual.
or
if It's a OLD STYLE self cleaning oven... read the old manual.
It makes a HUGE DIFFERENCE...
Any advice here could fly right in the face of what you
owners manual dictates
You TYPICALLY remove the shelves.. and prep the interior with a warm sponge... to pick of loose particles.
Sets the controls for clean... return WELL after cool down.
Make sure the interior surface is cool to the touch... and
ONLY THEN :
Clean up the ash with a damp sponge!
Clean and return the shelves... and you are good for your next mess.
If it is not SELF CLEANING... get out the HAZ-MAT suits..
Again... remove shelves food, etc.
Open windows... Read the CAUTIONS on the label...
Follow those directions VERY CLOSELY... Else...
Get dressed and go out and by a new oven.
Happy hunting!
Mar 27, 2016 | Ovens
I've got a self cleaning oven don't know how to work it what do i do
Hello there!
It depends over a lot ot sets of those self cleaning oven...
IS there any instruction manual for that device, there must be, search over the internet i really dont know what could i suggest to you if i dont have any details. Good luck! =)
Sincerely
Aleksandar Adzic
Apr 16, 2010 | Frigidaire FEB27S5A Electric Single Oven
Our oven is a year and a half old, and I noticed after I self cleaned it the top part was burnt. Also, The door always clicks and the light goes on and off anytime the door is even touched. To top it off,...
sounds like you have bad hinges. this holds the door shut tight.sounds like they are sprung.sometimes if you are persistant on calling the manufacture they will pay for the service or part of it.dont give up climb the ladder.
good luck!
Mar 10, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Kenmore gas oven does not reach operating temperature
If your oven is 20 years old the temperature sensor system might no longer be accurate, if you have access to a temperature measuring device that can confirm that the oven is not reaching 350 then run it up and check that its not just your indicator light system. Some oven burners have air control and yours may have accumulated oven soil over the years. If your burner. Is behind a short wall like mine is, use a mirror and torch to check. A clean can bring things back to standard. Flame heat is from a good mix of. Gas and Air...
Dec 05, 2017 | Kenmore Ovens
How would you clean an oven if you didn't have hot water or electricity? We clean out foreclosures that usually do not have water or power available, I need something that will clean the oven and the...
There are several products that you can use, you can get spray on cleaners, or ones that you paint the interior with, after letting stand for a while, you rinse and wash the interior with cold water.
Check on line for OVEN CLEANERS OR CLEANING PRODUCTS.
Please rate my solution.
Thanks.
Oct 19, 2009 | KitchenAid Ovens
Oven will not heat after self cleaning
We used the self cleaning feature on our RBS305 Built In Electric oven and afterwards it would not heat. replaced the Fuse-Thermal part Nr 9759243 (which is the new part number. (Shown as Nr 37 on the Parts list for the oven parts). Cut all Power to the oven off and it was very easy to pull oven out with help of my wife. Removed back, bought a new part for 49.55 plus tax. Put in new part, replaced back and oven works like new. I am a 73 year old senior so when I say it is fairly easy to replace you know it is. Hope this helps someone
Dec 11, 2008 | Whirlpool RBS305PD Electric Single Oven
Moffat Self-Cleaning Oven will not self-clean
did you try setting a start and stop time with the time knobs? i had the same problem til i set 3 hrs on the start and stop, then let it sit (after locking the door and turning the knob to clean). after it was warmed to cleaning temp, the light for cleaning came one...
Nov 10, 2008 | Ovens
Amana Electric Oven Issue
My oven never reaches the proper temperature sitting for baking. Controls for the oven only is push buttons. How can I adjust this. This has been going on since I have bought the Amana
Oct 27, 2008 | Amana AOCS3040 Electric Single Oven
Kenmore 30464 / 30465 / 30469 Gas Single Oven Logo
329 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
