Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Paper jam my paper get jam and also it will not feed the paper threw tell me what to do my all in one i got it this xmax and used it very seldom
  • 832 Answers
So if its new there is warranty! call brother hotline of your country and ask for the procedure to give machine to service!
(If it does a lot of jamming there is nothing what you can do!)
Posted on Jan 08, 2008
Epson xp430 paper jam, but I can't find any jam!
They don't tell lies :>) Even the smallest piece of paper over the sensor will record a jam. This often happens when you have a jam and you pull the paper and it tears a piece off. Open all the doors, remove the paper tray, remove all the toner or cartridges and look with a flashlight. Always pull paper jam paper in the direction it was going, undo tensioner clips if present and pull paper evenly and slowly as not to tear the paper. If you do, keep the paper and find the piece that fits the piece that is missing.
Having said that, see the link
Paper Jam Problems - Epson XP-430 User Manual [Page 234]
https://www.manualslib.com > ... > Epson Manuals > Printer > XP-430 > User manual
Epson XP-430 Manual Online: Paper Jam Problems. If you have problems with paper jams, try these solutions: 1. Cancel the print job from your computer, if...
SOLVED: Error says paper jam, but there is not. What could cause this ...
https://www.ifixit.com/.../Error+says+paper+jam%2C+but+there+is+not.+What+could... Dec 18, 2013 - I have an Epson Artisan 837 all in one. It was working perfectly fine yesterday. Today it is telling me I have a paper jam. I went through the steps ...
How to solve paper jam or paper feed error DO IT YOURSELF ...
? 3:43
https://www.youtube.com/watch?v=kHHpVcSJvvA
Aug 16, 2016 - Uploaded by Easyprint-DZ Support
... of commons problem of printer . paper feed error or paper jam error. ... we gonna work on epson ...
Paper Does Not Feed Correctly - Epson
https://files.support.epson.com/htmldocs/pho22_/pho22_rf/trble_4.htm Paper does not feed. Multiple pages feed. The paper jams. Paper is not ejected fully or is wrinkled. Paper does not feed correctly when using the double-sided ...
Epson XP-430 ' XP Series ' All-In-Ones ' Printers ' Support ' Epson US
https://epson.com/faq/SPT_C11CE59201~faq-293729 Mar 24, 2016 - If paper jams when you load only one or two sheets, try loading more sheets at a time. Do not load more than the recommended number of ...
Epson xp430 paper jam Google Search
Oct 23, 2017 | Epson Office Equipment & Supplies
My printer says "close document feeder cover". I don't know where this is
It is talking about the flap that is on the very top just above where one puts in an original to auto feed on to the glass, this access cover is required to be open and closed by the machine because it feels something is holding it open or its switch that tells it such is stuck. Maybe a jam from last original fed into it..
The cover once open check around for paper fragment and inspect little levers that hang down, one is stuck or there is paper stuck in Document feeder
I have found that often label bits, paper clips, punch bits and small corners of paper often get in the path, I use a piece of laminate cut so it has a v or a point and feed it in the document feeder, manually inserting it in the direction a piece of paper normal travels in it.
Push it all the way threw not pulling back (bad for it) to do so poke the point threw, you will need the top cover open and lift off the glass, so you can grap the point and pull the laminate threw.
Nov 04, 2009 | HP OfficeJet d145 InkJet Printer
I had a paper jam and after I unjammed it the paper will no longer feed into the printer. It keeps telling me the tray is empty when it is full
Unplug from the power then restart the printer sometimes the paper is not in just right and when you restart the printer it will send any loose paper on threw the printer
Sep 29, 2009 | HP Photosmart C6280 Printer
THE FAX MACHINE TELLS US THERE IS A PAPER JAM AND WE KNOW THAT THERE IS NO JAM, DO WE RESET THE MACHINE, TRIED TO UNPLUG AND SHUT OFF NOTHING IS WORKING
the feed jam switch is stuck down. if you can pop it open and use canned air and blow inside where you feed the paper then where the paper comes out. this may pop it free... let me know
Jun 22, 2009 | Office Equipment & Supplies
Paper Jam, yet no paper in printer. The last sheet came out whole.
I have a canon mp210 and it's saying paper jam..there is no jam. Paper is going towards the right when trying to feed but does not feed.
May 17, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Epson cx3800 paper feed problem
no you might have a paper jam somewere and mabe you ink rollers are dry you might have to tell the printer to to a pre test and clean and if there is a paper jam it should be a slot on the back by the roller should be a tap that shows the tollers look for a pice of paper jammed somewere in the roller you migh have to take the paper out to inspct it for a paper jam and if none mabe the print heads are dry and it dosent feed the paper then could be it ok clean the print heads tell the printer to to a roller clean and then after that if no paper jam no were try printing a page take all the paper out and feed it manually and if it prints then some printer want feed if you have filled the paper tray up try putting less and then try
Jan 29, 2009 | Epson Stylus CX3800 Printer
Paper Jam
look inside the printer. if u cant find the problem then get a pencil and see if u can hit or feel any thing. thats how i solved my paper jam with out any help.
Sep 01, 2008 | Lexmark X2470 All-In-One InkJet Printer
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
