Question about Canon PIXMA MX310 All-In-One Printer
The fax maching is neither allowing to receive or send faxes....it keeps putting up a message that says recommend new B-CRT....don't know what that is and it looks to be plugged in properly
  • dr_vicky2009 Nov 12, 2009
    My fax machine is not hooked up to the computer as far as I am aware...still not sure what a B-CRT is
    President:
  • 1,126 Answers
Here is a link to Canon for your Pixma MX310 Users Guide. The file needs to be downloaded and then installed. Look under Replacing a Fine cartridge for suggestions to correct this issue.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=15603
Hope this helps....Please let me know your progress.
Posted on Nov 12, 2009
  • Tim Swiercinsky Nov 12, 2009
    B-CRT refers to Black Ink Cartridge.
Keeps saying recommend new CRT. What is a CRT, have looked through manual but cannot find anythjing relating to this message
Hi!
CRT is the cartridge and if it says recommend new one you need to install a new cartridge!Hope it helps!!
Sep 13, 2011 | Canon FAX JX200 Fax / copier Plain Paper...
How do i change outgoing answer phone message
Solution for Fax1360, if this does not work please let me know as this process should be the same.
Recording an outgoing message (OGM) on an external TAD 7
Timing is important in recording this message. The message sets up the ways to handle both manual and automatic fax reception.
a Record 5 seconds of silence at the beginning of your message. (This allows your machine time to listen for the fax CNG tones of automatic transmissions before they stop.)
b Limit your speaking to 20 seconds.
c End your 20-second message by giving your Fax Receive Code for people sending manual faxes. For example: 'After the beep, leave a message or send a fax by pressing *5 1 and Start.'
Recommendation: recommend beginning your OGM with an initial 5-second silence because the machine cannot hear fax tones over a resonant or loud voice. You may try omitting this pause, but if your machine has trouble receiving, then you must rerecord the OGM to include it.
Christy
Sep 26, 2010 | Brother Inkjet Fax Machine Fax1460 Plain...
Cannot send Fax Memory Full
The most easier way is to disconne, the power suplly cord.Wait few seconds and connect again.
Jun 22, 2010 | Canon FAX-L100 Plain Paper Laser Fax
New B CRT Recommend
B CRT is the Black cartridge and can allmost be bought anywhere!Ask Your local canon Dealer perhaps!Good Luck!
May 04, 2010 | Canon FAX-JX200
Hi, I got a message: received in memory - recommend new b-crt
The b-crt is the black ink cartridge, when you put in a new one, it will print the fax for you.
Jun 22, 2009 | Canon PIXMA MX310 All-In-One Printer
Problem with faxing
Goi to
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15603
put "recommend a new c-crt" in the question box. Select the ERROR LCD: RECOMMEND NEW C-CRT answer and follow the instructions to clear the cyan cartridge error. This should take care of the problem. Let me know if this doesn't work. Thanks.
May 08, 2009 | Canon PIXMA MX310 All-In-One Printer
How to send fax from computer ?
Please follw the below steps:
To Fax From Your Word Processing Program1. Some software products, such as Microsoft Word, allow you to fax a document without opening your fax software.
2. Open the document that you want to fax.
3. From the File menu, select Print. The Print window opens.
4. Instead of printing to your default printer, look for an option that allows you to Print to Fax. Select this option and click Print.
5. You will be asked to provide the recipient's fax number and other assorted information as with a fax program.
6. The fax message compiles, the modem dials. If the connection is made with the other modem, the fax will be sent.
To Send a Fax From Fax Software1. Prepare the document that you want to fax.
2. Prepare a fax cover sheet, if desired.
3. Open your fax software - such as Microsoft Fax or Microsoft Exchangemag-glass_10x10.gif.
4. Look for an icon or menu command that allows you to send a fax - such as Send New and Send Fax. Click on that item.
5. Follow instructions for entering the fax number of the recipient and any other requested information. Be sure to include area codes and long-distance information if needed.
6. Indicate whether you wish to send a cover sheet.
7. When asked to attach the file, follow instructions to attach the file that you want to fax.
8. When ready, click Send. The fax will begin to compile the information and, when ready, will dial the remote fax machine.
9. When the connection is made, the fax will be sent.
Thank you.....
Dec 08, 2008 | Office Equipment & Supplies
Problem sending & Receiving Fax Imageclass D880 Canon All in one printer
#0018 indicates there was a problem with dialing, but it should show for sending faxes only. Since you can neither send nor receive faxes, and are getting a message saying "no signal", make sure that the phone line is still securely connected to both the L (line) jack on the machine and the phone jack in the wall. If it is, plug another phone into the accessory jack on the machine, and check to see if you are getting a dial tone. It seems like the machine is not able to communicate through the phone line.
Oct 10, 2008 | Canon imageCLASS D880 All-In-One Laser...
Recieveing
If all else fails try the manual mode:(Press Receive Mode to select
FAX ONLY, FAX/TEL,TAD:ANSWER MACH. orMANUAL.)
Manual Reception
Pick up the handset while the phone is ringing.
2 Press Fax Start if you hear fax tones (beeps).
3 When the LCD shows RECEIVING, replace the handset.
(best used when you are expecting a fax and know that the incoming call is a fax)
If you are like most people you probably also have a phone with an answering machine or voicemail setup on your home phone. If this is the case you may want to set the reception made to
TAD:ANSWER MACH.
May 28, 2008 | Brother IntelliFAX 2800 Laser Fax
Canon PIXMA MX310 All-In-One Printer Logo
98 people viewed this question
old marine
old marine
