Question about NEC Mitsubishi Diamond Plus 230SB (Black) 22" CRT Monitor
The screen is just showing a rainbow effect going from top to bottom. Do I need to get a new one?
Rainbow colors from bottom of screen to top corners
Check its degaussin posistor. Replace it. This component can be located at the main power regulator section.
Picture of the suspected component attached.
May 23, 2012 | RCA TruFlat 27F520T 27" TV
The picture is showing multiple images with red, green and blue rainbow effect. The picture is also bowed on the top and bottom
This is whats called a convergence failure. You will need to call in a repair shop or goto sites like www.TvRepairKits.com hthat ave the parts to fix this yourself. Its a common failure on projection TV sets.
Aug 07, 2011 | JVC AV-56WP74 56" Rear Projection...
Rainbow screen aiwa tv,, screen shows different colors like rainbow// brushing a magnet infront of the screen fixes the issue temporary
Picture tube is magnetized. Manual degausing is required. already you have done this.
Since you say it is reappearing, you have to check the following.
1. Relocate the TV or relocate if you have placed any tower speakers
or home theater speakers close-by.
2. Check whether auto degauss functioning OK. In the MENU
check whether you switched off auto degauss option. If it is OFF
enable it to ON.
3. Finally re orient the direction of your TV and watch the rainbow
effect. Switch OFF TV, wait for 20 mts, and again switch ON.
Repeat the process. It should disappear.
Magnetic toys or any other devises using magnet will cause this problem.
Aug 11, 2010 | Aiwa TV-S2011 20"
Rainbow showing up at bottom and top of screen creating double and triple vision
IM GUESSING ITS A LAPTOP SCREEN OR COMPUTER IT COULD BE SOME WATER TRAPPED INSIDE OF THE SCREEN LIKE CONDENSATION WHICH COULD MAKE A PRISM OF LIGHT LIKE WHEN YOU SEE A RAINBOW BECAUSE ITS SUNNY AND RAINING
Oct 08, 2009 | Philips TV Tuner Video Capture PCI Card -...
Rainbow effect at top of screen
This is a convergence problem that can be as simple as poor solder connections on the pins of the convergence ICs or defective ICs. If you wish to attemp the repair yourself, please let me know and I'll look up the parts and provide additional details and instructions. Also, please confirm your model number.
Thanks,
Dan
Feb 18, 2009 | Samsung HLN617W 61" Rear Projection HDTV
I have a rainbow effect on my television screen.
the deguesing is not working of your tv.or maybe you have a load speaker near the tv. take it away near the tv it damage the color of your tv set.
Nov 15, 2008 | Televison & Video
Rainbow on the screen
Do you have any larger speakers close to you tv. Or any magnets been neer it. If you unplug it for a while the tv should have remove the rainbow
Aug 28, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Rainbow
Rainbow effect has more to do with color wheel style and speed.
Jan 31, 2008 | LG RU-44SZ51D 44" Rear Projection...
Phillips 60PP920217F bows in on top and bottom
convergance amp ic are bad.
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 28, 2007 | Philips 60PP9202 60" Rear Projection...
NEC Mitsubishi Diamond Plus 230SB (Black) 22" CRT Monitor Logo
89 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
