Question about Campbell Hausfeld 1800 PSI Electric Pressure Washer
1800 power washer will not run - power is getting to on/off switch
  • 68 Answers
Maybe just the pressure switch is stuck or you have trapped pressure in the lance. Try without the high pressure hose and then activate the pressure switch on the side of the pump as this may not be letting the machine to statr if its stuck.
Posted on Feb 07, 2010
Where would I go to get our pressure washer serviced? I live in the Saskatoon, Sask. surrounding area.
Does the electric motor keep running? If it does continue to run with the trigger in the spraying position, then your pressure switch and motor are OK. If the motor is running and the water is not coming out with pressure, then either your check valves are not closing properly or the pumping mechanism is in need of repair. I think those little electrics have a simple wobble plate design. Basically not worth the effort to fix them
Oct 09, 2014 | Karcher 16017720 K3.690 X Series 1800 PSI...
No power
usually if your unit does not start, the high pressure switch has failed to return to normal position, this can be caused buy poorly constructed switch housing or faulty micro switch.you will need to take it out of its casing and locate the plastic housing that has two wires inside. inspect this for functionality repair or replace and test unit before re-assembling CAUTION avoid touching any wires that may be live when testing!
Apr 20, 2014 | Campbell Hausfeld 1800 PSI Electric...
No power or pressure when switched on
as per your manual the pressure washer should only be used for a maximum number of minutes to keep from overloading the motor and causing it to seize. There should be a "RESET" switch or button due to a protection circuit built in to keep from damaging the unit. Please refer to manual for location of reset switch/button
Switch power on and it works and then it switches off and will not switch back on until you leave it for period of time and then it powers up again
This is an indication that it is overheating in the motor. When this happens, very carefully check the temp of the motor and see if it is too hot.
Mar 02, 2014 | Karcher 16017720 K3.690 X Series 1800 PSI...
Motor won't start
Make sure water is on. Try pushing test and then reset on the built in GFCI on the plug. If it's not a dead motor, when you hit reset, the motor should kick on for a second when you reset it.
Dec 31, 2017 | All-Power America All Power America...
Reset switch won't work
this is usuall caused by the high pressure cut out switch not returning properly. the high pressure cut out switch is a plastic assembly on the pressure head. open it up ,lubricate or file it to increase space. then test before re-assembling it, beware of possible exposed wires and chance of comming into contact with electricity. disconnect power while working in it!
Aug 25, 2013 | Campbell Hausfeld Electric Pressure Washer...
How do i enter in safe mode on my poweredge 1800 ?
If the server is running Windows, you can usually enter safe mode by repeatedly pressing F8 after you press the power switch.
You can also get into the dell utility, which lets you run memory and system tests. To access this, follow the on screen directions during boot up.
Jan 25, 2011 | Dell PowerEdge 1800 Server
My Honda 4.0 1800PSI Power washer only has hose pressure when it should have 1800 PSI
hi spray some silicon oil in inlet and outlet then run attach hose back do this everytime you store the washer away it is because the seals dry up always lube when storing.
Jan 15, 2011 | ALL POWER AMERICA LLC AllPower America...
Craftsman 1800 psi power washer won't start. Help! Thanks.
Try a new unloader valve,if it is stuck the motor can.t overcome the pump and will either die or blow a breaker.
May 10, 2010 | Garden
Campbell Hausfeld 1800 PSI Electric Pressure Washer Logo
1,029 people viewed this question
Top Campbell Hausfeld Garden Experts
John Trevino
Tim Venetis
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
