Question about Panasonic PT-52LCX65 44" HDTV
I Have green squiggle lines that are moving around on the screen. I can minimize the lines by darkening the picture and toning down the color which makes the picture too dark. Any idea what is causing this and how can it be corrected. Panasonic PT-52LCX65 44 in. HDTV.
YOUR TV HAS A CORRUPTER MICRO CONTROLER
YOU MUST GO TO A SERVICE CENTER THE SERVICE CENTER WITH A SPECIAL TOOL THATS AVAILABLE BY PANASONIC WILL REPROGRAMME YOUR EEPROM THIS SHOULD NOT COST MORE THAN 100 DOLLARS IT IS NOT NECESSARY TO OPEN TV
Posted on Jun 14, 2010
Full screen of vertical colored lines, What do I need to check?
Disconnect from computer and try it on another.
might be a video card issue, disconnexion will show if this is the problem. Does it do this when the computor is off?
If it is not a computer issue then try resetting to factory default.
It might be that the screen is going but this is usually evidenced by loss of picture or darkening rather than vari-colour lines
please amend and resubmit query
May 28, 2015 | Hyundai L70N 17" LCD Monitor - 16 ms 1280...
I have green vertical squiggles lines over whole screen
possibly the DMD chip goes bad, you can try to disassemble your tv, and take out the DMD chip, when carefully inspect its mirror, whether you found any lines or white pots in it.
if it had lines or white pots, you have to replace it.
Oct 26, 2014 | Samsung HL-S5087W DLP TV
Screen is displaying Red background color with glittery pixels effect around the figures
Please change the T-CON board, if it did not fix the problem, you may have a defective LCD Panel.
Apr 24, 2017 | Samsung LN52A650A LCD TV
The screen has a reddish tint to it. Seems like a color issue and not sure what to replace. The picture works fine but everyone is red. Not sure if there is a bulb to replace or what? Any suggestions? This...
You need a simple color adjustment. (Color Calibration)
You don't need to spend money on this. Try it for yourself.
Your main problem is that your color temperature is set to warm.
You need to change temperature to COOL or 6500K depending, on how it is labeled.
You will see improvement, but there is a little more...
Move "Color" DOWN from it's current position (probably at 50) to somewhere between 30 and 40. (Just a couple of clicks above where the color rapidly washes out.)
At this point there will still be slightly unnatural color to skin tones, but all the artificial "sunburn" and blaring red will be gone.
Last (as far as color goes) move the tint 2 to 4 clicks toward green. This added green tint balances the color so that the flesh tones become completely accurate and realistic.
For even better detail, continue your home calibration here:
http://www.wowvision.tv/main.htm
Jun 13, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Black squiggle lines appearing on screen
what happens if you connect the remote to the computer without any batteries are you having the same problem if so try a firmware upgrade if you still have the same issue it's certainly defective contact Logitech to find out how to get it replaced
Jun 08, 2009 | Logitech Harmony One Advanced Universal...
Single green line spanning across the screen horizontally
I was just watching TV and all of a sudden the screen minimized down to a single green line spanning across the screen horizontally. The label in the back says it was made in 1996 so it is an old tv. Can anyone help?
Apr 08, 2009 | Mitsubishi CS-27205 TV
The picture is green
your picture tube is wearing out . there is a way around it it will work for a while .you need to lower the drive for the green . on the board on the neck of the picture tube there are three adjustments marked red , blue, green on the front of the tv turn down the color all the way down . normally you would have a black in white picture but now you have a green and white find the screw adjustment marked green and carefully turn it down untill the picture is black in white and your fixed . adjust color back up .... dont do this repair unless you are confortable working around high voltages a wrong move inside a tv can kill you , this adjusment must be made with power on so you can see the picture as your going ... so this may not be for you . use your own judgement ........Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Mar 26, 2009 | RCA Televison & Video
Toshiba TP50G50 Theaterview picture is double with red color only
Your alignment is off. Go to the set up menu then convergence. hit right and you will be in the convergence menu. select the color that is not in alignment. The green line does not move. if blue and green are lined up the line will be cyan. if red and green are lined up the line will be yellow. when all three are lined up the color will be light. Best of luck!
Nov 16, 2008 | Toshiba TP50G50 50" Rear Projection...
Lines moving through out picture
can't give tech help ,but can tell you we have same problem and having a hard time finding an anwser /someone to come out to look . actually had a repair shop ask me to bring it in (yeah all 85 lbs.) will try calling place that repaired it when it was under extended warraunty thru best buy. took 1 mo to get the part back then. did you see my post on wiggly lines. good luck
Apr 04, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Green hot
Locate green screen control found behind speaker grill cover
and access panel lower front of tv......turn green screen ONLY
CCW a little.................T.
Oct 23, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic PT-52LCX65 44" HDTV Logo
138 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
