Unable to clean
My brother printer model (mfc 620-cn) is unable to clean,unable to print. It has no paper or other objects jammed in it.It has ink ,does anyone have any ideas what maybe causing the problem.
  • 610 Answers
Probably refers to a clogged print head. in the long run it would be cheaper to buy another unit instead of repairing old one.
Posted on Nov 12, 2009
Testimonial: "thanks, I thought that would be the case considering printers are fairly cheap,Thanks for the info."
I have a Brother MFC-3360C printer and have an error. Clean Unable 51
Error 51 normally indicates a paper jam or a sensor problem. Check the paper path and the printer head movement zones (far left and right) for any foreign objects (even small pieces of paper). If there has been a paper jam, was the paper forcibly removed? If so, possibly one of the sensors has been knocked out of position or damaged. Dust, dirt, grease or spilled ink may also be contaminating a sensor. This is maybe one of the most elusive problems to solve..!
Apr 10, 2015 | Brother MFC-3360C All-In-One InkJet...
Print unable 51 code on brother MFC-5460 CN
paper jam or some sensor error, try to clean the sensor, locate the sensor under the pump, where the printer head park the dis assemble and get the sensor, then clean with water or alcojol..
Jul 21, 2014 | Brother MFC-5460CN InkJet Printer
I had never had an issue with this MFC 5440 CN until now,It was working perfectly and since a couple of days ago it does no want to print. All ink levels are OK, there are no pieces of paper stuck...
Ivan, see if there are some paper clips or other similar objects stuck somewhere around the paper rollers. There are micro-switches around the rollers, you may want to take a brush and clean up any dust buildup that may be causing these micro-switches to trick the printer into thinking that there's a paper jam of some kind
Dec 21, 2010 | Brother MFC-5440 Printer
My Brother MFC-5890CN also shows a message "Unable to print 36"
Machine Error 36 means just what said, either mechanical problem (not very likely due to age of machine), or loose part. Most often caused by ripped paper or a paper jam which results in a moved/smudged sensor, making the machine alarm.
But since the error can be temporary removed, it should be something loose that gets in the way when the printer head moves. Unfortunately, most likely the solution will be to have it serviced.
The error isn't unique for this model, but is an error used on almost all inkjets from Brother the last 4-5 years. Unless you really can find anything loose (or possibly help cleaning some with compressed air) you will have to send it in.
Jun 05, 2009 | Brother MFC-5890cn Color Flatbed...
Error : Unable to clean
Unable to clean means that the waste-ink "sponge" is full. If you've already checked for small paper part (which is very unlikely to cause this error message), the error is mechanical. Unfortunately, that's not something us users can change, but the machine would require to be sent to service. So if your machine is not within warranty, I'd doubt it'll be worth the service cost.
Jun 02, 2009 | Brother MFC-5840CN All-In-One InkJet...
Message unable to print 50
Machine Error 50 either means that there is a loose object inside the machine (usually piece of paper), or that there is a mechanical error which would need you to have the machine sent to service.
Jun 02, 2009 | Brother MFC 240C All-In-One InkJet Printer
Printer has unable to clean message
When trying to use your Brother machine you get the message "Unable to _____". The blank may be the word Change, Print, Scan or Clean and these words may vary from model to model.
This message is a general message and will appear for different reasons. It often indicates a paper jam or a mechanical issue. Complete the following to determine the possible issue.
Check for foreign objects, such as a clip or ripped paper, inside the machine.
Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
Then with the power on, pull the plug from the wall for several minutes. The plug it in and power the unit up.
Here is the manual:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_210C_420CN_EN_286.PDF
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 18, 2008 | Brother MFC 420CN All-In-One InkJet...
What is 'print unable 51' never had a paper jam!
Do the following:
Print Unable
XX
The machine has a mechanical
problem.
—OR—
A foreign objects such as a clip or
ripped paper is in the machine.
Open the scanner cover and remove any foreign
objects inside the machine. ( You might try cleaning the scanner glass.)
If the error message continues, disconnect the machine from
the power for several minutes and then reconnect it.
Try this and let me know what happens. Binary Bob
Nov 21, 2008 | Brother MFC 240C All-In-One InkJet Printer
Print Unable 50 Brother MFC5460 CN
So dont let me be a withness of murderer:
There is no paper sicking within the machine! The jam had lifted the encoder strip out of the ph. After you have fixed it simppy stick some very thin scotch tape onto the ph cover to avoid further liftings (that will happen quite often...)
same issue: (change the viwing size of your browser to enlage the pics)
http://www.fixya.com/support/t211210-brother_mfc845cw
Mar 17, 2008 | Brother MFC-5840CN All-In-One InkJet...
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
Electro Med Services...
