Question about Dryers
NO HEAT............HELP!! Hi i have a hotpoint TC71P Tumble Dryer which is working fine except for no heat, its just cold air, would this be the element or the thermostat as i dont want to order the wrong thing and i dont wat to get ripped offf again by my local shop. please help desperate mum with no tumberler!!!!
    Problem Solver:
  • 13 Answers
Without testing the element it would be difficult to say exactly.there are 2 possibility.it could be the element or it could be the sensors at the back of the machine.you have to remove the 2 connections to the sensors. and test them they both should be closed.the element should have low resistance value.you need a vom to do the test.you have to understans to use the meter.
Posted on Jan 07, 2008
Hi I've Got A Hotpoint Aquarius CTD40 Tumble Dryer
that isn't a model number,open the door to the dryer,look around the opening where you put the clothes in and send the full model number,
Dec 21, 2017 | Hotpoint Dryers
My tumble drier seems to work fine but it is only blowing out cold air even when it is set on a hot setting
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101--==-
Aug 29, 2011 | Dryers
Hi my hotpoint first edition tumble dryer not getting hot,the drum is turnig fine but just no heat!!!
heatman101
Jul 27, 2011 | Hotpoint NVLR333EE Dryer
My tumble dryer is blowing cold air only. I had a new thermostat put in between 1 and 2 years ago, so hoping it's not that and something else. Can you help me please?
heatman101
Mar 21, 2011 | Hotpoint Dryers
Hi My hotpoint dryer will tumble but no heat is generated the air outlet is clean and free from obstruction can you help me
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 30, 2010 | Hotpoint Dryers
HELLO THERE MY HOTPOINT TC71P DRYER IS JUST BLOWING COLD AIR WAT CAN I DO?? REGARDS LEE
here is the first video that might help
You-Tube video "Vx9JMZRRKrg" placeholder (do not delete)
Dec 21, 2009 | Hotpoint Dryers
I have a hotpoint aquarius condenser tumble dryer
This sounds like the thermostats or heater
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Nov 06, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint CTD40P tumble dryer only runs cold.
hello check the heat sensors first good luck
shaun
Aug 04, 2009 | Dryers
Maytag MDG16CSBWW heating problem
I have a Miele Novotronic T560C. The tumble drier is working fine except the air circulating is cold - it does not heat up at all. What could the possible reason for this and/or solution?
Oct 05, 2008 | Maytag MDG16CS Gas Commercial Dryer
Dryers Logo
176 people viewed this question
Top Dryers Experts
Marvin
Marvin
