-   Washer won't spin no matter how large or small the load. It makes a humming noise and goes through cycle but will not spin.-   azboone
Mar 02, 2009
-   Will not spin - makes load clicking noise....2nd time this has happened since I purchased this washer - WILL NOT BUY ANOTHER WHIRLPOO-   Guest
Feb 15, 2009
-   tub will not spin. makes a clicking noise as if gears are not engaged.-   mark_wms
Nov 29, 2008
-   Washer will not spin, makes growling sound, some clicking, what is the problem-   oh58d
Sep 28, 2008
-   Belt burns at spinning cycle. Not spinning at all. -   chameco100
when this washer spins, it sounds like something is rubbing against something. That is the best way...
(More)
when this washer spins, it sounds like something is rubbing against something. That is the best way I can explain this. It is louder than a regular spin sound but still spins good but I know this means something is going wrong.
Was in great working order before being removed from 15 months storage, now all functions work...
(More)
Was in great working order before being removed from 15 months storage, now all functions work except the cage won't spin during the spin cycle but the pump noise works during the cycle.
Simpson deta heavy duty washing machine The agitator does not reverse and goes one direction only...
(More)
Simpson deta heavy duty washing machine The agitator does not reverse and goes one direction only what can it be?
washer spotted spinning and draining on the last cycle. Will not restart. Has a whining ticking sound.
Comment by Guest, posted on Apr 09, 2008
washer in not spinning making a whirring clicking sound, noticed that plastic cylinder shaped object "pully" is loose on shaft of motor and slides back in forth between transmission and motor
