Question about Archos 605 Digital Media Player
My archos 7 boots up ok but then the interface is not responding... i can re set and use the paperclip method and even remove the battery but it is still frozen on reboot..it may work once in six attempts... the unit is 1 week old can you suggest cheers Bernard Miller
I didnt solve the problem,,,, i did a full format of the hard drive and then downloaded the firmware to re install everything but the problem was still there.... i contacted archos who suggested that it had a hardware problem and i would need to send it to them..... as yet im deciding if i want to go for a replacement or a repair, as i have installed the plugons and would loose them on a new machine...
many thanks
Bernard
Posted on Nov 13, 2009
Archos 97 carbon tablet has frozen, cannot turn off or nothing have tried holding power key but still unresponsive
it is dead easy. just get a paperclip and open one side of it, now look on the side of the 97 there is small hole between the USB port and the flash sd card, insert the paperclip end an hold until the system resets itself.
All will come back to life after pressing the power button..
No data wil be lost, I have done it lots of times.
Jan 26, 2013 | Archos 97 carbon 16GB 9.7" Capacitive...
Tip
How to copy your commercial DVDs to the ARCHOS 7
With an 800x480 pixel-wide resolution and a 7" TFT LCD screen, the ARCHOS 7 can absolutely provide users with the best cinema experience on the go. You can watch your movies in full width, which will give you the same viewing comfort as a TV in your living room. Your video watching experience on the go will never look so good.
Because of the excellent cinema experience, and its huge capacity - both 160G and 320G versions are having enough room to store movies, more and more users would like to copy their DVD collections to the handheld device. To copy a commercial DVD to the ARCHOS 7, you need a program called Pavtube DVD Ripper to rip it into ARCHOS 7 compatible file formats, like AVI, MPEG4, AVI video, and WMA, AAC, WAV audio. The following paragraphs will detail the steps of how to rip DVDs for playback on ARCHOS 7, if you are searching for such a solution, just read on it to get what you need.
First of all, you can download Pavtube DVD Ripper here.
Step 1: Load DVD files
Click "DVD Rom", "DVD Folder" or "IFO/ISO" to import DVD files to this program. This utility allows users selecting their needed chapters to convert, and you can right click on a title, and then do selections on the popup window, like "Uncheck All", "Show Chapters", etc. By the way, usually, the one with the longest duration time is the main movie, so just tick off this one would be OK.
Step 2: Select output format for ARCHOS 7
Click on the pull down menu of "Format", and then all the format profiles will be listed out as below, just select "Archos" firstly, and then choose a format for ARCHOS 7, here I select "Archos 5/7 WMV Video (*.wmv) for instance.
Step 3: Set advanced settings
Click "Settings" button, then you are able to adjust video and audio parameters like codec, bit rate, aspect ration, bit rate, frame rate, sample rate, and audio channel in the following interface. Basically, the default settings can ensure the output quality to be good, so, if you do not have special requirements, there is no need to change the settings.
Step 4: Click "Convert" button to start DVD ripping
Once your DVD is ripped, you can find out the output files via clicking on "Open" button, and then drag the file over to your ARCHOS 7 for playback.
For more: http://www.pavtube.com/dvd_ripper/
on Feb 24, 2010 | Televison & Video
How do you change the battery on an archos 7 320gb
The ARCHOS 7 has a removable battery. You can purchase extra batteries fromwww.archos.com.Caution: if the battery is incorrectly replaced or short-circuited, this could resultin damage to the product and/or serious injuries to the user. Replace onlywith an original Archos battery.To replace the battery, follow these steps:
Jan 24, 2012 | INOi Audio Players & Recorders
Every time that i click on my favorite icon,my archos 7 re boot it self,shut down then start back up.will not let me get into my favorite's files. any solution.
Hi, when this happens it usually means the operating system is corrupt, the best thing to do is to reflash your Archos, you obtain the required software and then plug into the USB port and then using the proprietary software to reflash the internal memory on the Archos to replace the operating system, and restore it to functionality, if you ONLY copy over the system files you will keep all you old settings.
You need to go to the Archos website to obtain the Firmware also there is s "How to" reflash your Archos 7.
http://forums.techarena.in/operating-systems/1150953.htm
Above is a "How To" link...
www.archos.com/support/support_tech/firmware.html?...g... -
Support link above.
Mar 02, 2011 | Archos 7 Internet Media Tablet
The calculator is giving me wrong answers even though the method is correct. i need to know how to reset it back to normal so that i can be able to calculate the time value of money. if i calculate the PV...
Resetting the calculator using the keyboard To completely reset the calculator and erase all user memory, follow the procedure below.
  1. Press and hold [C]. Press and hold the first key from the left ([N]) and the first key from the right ([FV]) on the top row.
  2. Release all three keys at the same time.
  3. The calculator will go blank, and then display "CORP HP 2000."
  4. The message will disappear and the calculator will display "ALL CLEAR."
  5. Press the [ON] key to clear the message.
Resetting the calculator using a paperclip To halt the calculator and reset the keyboard, follow the procedure below.
  1. Turn the calculator over and remove the battery door.
  2. Insert a paperclip into the small round hole located between the batteries. Insert the paperclip as far as it will go.
  3. Hold for one second then remove the clip.
  4. Press the [ON] key.
  5. If the calculator is still not responding, try one of the other methods
The batteries must be removed for at least 24 hours to drain the capacitor completely
Please comments back that your problem solve or not so may i further help u..
Aug 18, 2010 | HP 10bII Calculator
Archos 604 wifi
Are you sure the battery is charged? If so, try detach and retach the battery. Also try to attach to your computer via the usb cable and the 604 should turn on by itself, if nothing happens you need to send back to Archos for repair.
Jan 11, 2008 | Archos 604 WiFi Digital Media Player
MY ARCHOS PLAYER WONT WORK
Just watching a movie and my archos just froze in mid play , did a switch off to rest it and guess what it wont restart , ses ARCHOS in green at the start but wont reeboot have tried the reset button inside but no joy what so ever , any tips or advice 'or shall i just ship it back to Archos ....
Jan 05, 2008 | Archos 605 WiFi Digital Media Player
Archos 405 Portable Media Player
Found it on tha FAQ at Archos website. It worked on mine.
Best regards
My Archos 605 is freezing or stops responding during playback, or when recording, what should I do?
First take a look if your battery is fully charged.
You can also make a long press on the on/off button for 15 seconds; it will switch off the unit and your data will be not erased
If your device continues to stop and freeze, you have the possibility to format it from the settings menu; you can do this into settings, then select system and repair and format tools.
Before doing this, you have to save all your files on your computer
Dec 10, 2007 | Audio Players & Recorders
Archos 605 in demo mode
We called tech support and you fix it by doing a reset on the base of the device. We used a paperclip to push the button. Hope this helps!
Oct 28, 2007 | Archos 605 Digital Media Player
Archos 605 Digital Media Player Logo
95 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
