How do I reset the default paper size? - Office Equipment & Supplies
    Guru:
  • 480 Answers
Which model printer??
go in control panel printers and go in advance printing options??
Posted on Nov 12, 2009
How do I reset my SX215 to factory settings
When you are in the application that you are going to print from. Go to the menu bar, click on File - Page Setup. Here you should be able to change the paper size you wish to print out in. If you want to set the paper size by default to A4, then you will need to (Windows7) click on the Start button - Devices and Printers, select the printer that you want to change the paper size, right click on the printer - Printer Preferences, a dialog box appears, select the paper size you want in the paper size drop down list, click - Apply - OK. This should then have set the paper size to A4 by default.
Feb 26, 2015 | Office Equipment & Supplies
Canon Pixma MP500 Reset PAGE SIZE to A4
Set up the parameters you want A4 Paper orientation etc then go to profiles in printing prefences and ADD to profile.. delete any others that preced this set of parameters
Please tae my help++++Thanks for using FIXYA
May 09, 2010 | Canon Pixma MP500 All-In-One InkJet...
Papper gets stuck while printing,shows on the scren paper size,41.3 unexpected paper size.
Make sure the paper stops in the paper tray are set to the correct paper size. If one of them is not in the correct location the printer thinks it is a different size of paper. Also make sure the selector on the tray is set to the correct size. If all these are good you should reset all the settings to default.
Mar 08, 2010 | HP LaserJet 4100 Printer
Says no paper - but there is paper - was working fine now all of a sudden - have done all the trouble shooting and resetting.
Solved at last!!!
The problem isn't mechanical... I just realized that the "no paper" error posts when the software is trying to print to a paper size not supported by the printer. Go to Page Setup and make sure Paper Size is set to Letter.
In my case, the document I was trying to pring was set to Paper Size: Custom, probably because it was a scanned document and it didn't default to Size: Letter automatically. Hope this solution helps someone end their frustration...
Jun 26, 2009 | Brother MFC-8860DN Printer
Epson RX650 Paper Size Default
right click the printer icon, or bring up the printer program for settings and the paper size button or tab should give you a list of paper sizes and you can set it to the a4 size for your default setting....hope it helps you...shia
May 22, 2009 | Epson Stylus RX650 All-In-One Printer
How do i set paper sizes on my canon ir2016i printer
Open the paper drawer
Remove the paper
There is a blue paper size plate,that keep the paper in the correct posision,Push it to the front and downwarts.The paper plate should come loose from the tray.Put it back in the openning for the A4.The openning for the A4 papersize is mark inside the paper tray.
Now set the blue papersize dail to A4 paper .
Then you are ready to copy with A4 paper.
Feb 19, 2009 | Canon iR 2016i Black and White Copier
Lexmark T632 says "Load MP Feeder Letter
Hi Pqpoppa,
Check the paper size setting in the printer. Set it to the paper size you normally use such as A4 and the default tray. Check the default paper size in the printer driver in your computer and the default tray. Finally, check the paper size of the document you are printing. If all these match, it should not try to be smart and ask you to feed paper.
Rgds
S88
Nov 03, 2008 | Lexmark T632 Laser Printer
Load mpf paper
Your printer is set to default to the Main Paper Feeder, which is probably set for letter size paper. You must tell it to feed cards. On your Windows Desktop, left click mouse on START. left click on CONTROL PANEL, and left click on the PRINTERS icon. On the PRINTERS screen, RIGHT CLICK on your Dell printer icon. On the drop down menu, left click on PRINTING PREFERENCES. On the PRINTING PREFERENCES window, left click on the PAPER/QUALITY tab. Under TRAY SELECTION, choose the PAPER SOURCE where you want your business cards to feed from. Left click on APPLY button. Next, left click on the ADVANCED button. On the ADVANCED OPTIONS window, use the drop-down box next to PAPER SIZE to choose the paper size you want to feed. Press OK button. The PRINTING PREFERENCES window will now reappear. Left click APPLY, then OK buttons. After you have printed your cards, be sure to restore the printer defaults back to their original state, or the printer may jam because it must be programmed for the paper size being used. If you reload letter paper without resetting the paper size, the printer will think there is still card sized paper in the tray, and it will issue a jam or error code until the paper size is set properly.
Jul 30, 2008 | Dell 3100cn Laser Printer
69 people viewed this question
k24674
